Old 03-30-2010, 11:54 AM   #1
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 30,423
Any one used a Time Sert over the fender kit?
I need to do one on my trooper. It spit out a plug and doinked up the threads when it popped up and down before I stopped. Friggin shitty PO mechanic! All but two of the other plugs were finger tight!
i got all of them changed but the one that is easiest to get to thank God!
Looking for someone who has used a time sert who has some uh....time on the repair to let me know how it holds up and if they work as stated.
PLEASE don't tell me to remove the head, no friggin way. Id jerry rig it and sell it first. BTW its a 1999 3.5 with OHC so no friggin way will I remove a head to repair plug threads!
I hear theses got real popular with Ford techs on the V10 motors because they are notorious for spitting plugs from stripped threads.
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it.
RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT
Sniper X is offline   Reply With Quote
Old 03-30-2010, 01:35 PM   #2
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 30,423
bump for info...fingers crossed!
Old 03-30-2010, 01:46 PM   #3
Mini Trail
n°°b
Oddometer: 1,832
My dad a very simple and elegant solution to stripped spark plugs. He tapped them out to fit a plug with a a bigger thread. Time Serts are strong, expensive and not real easy to install.
Your cycle had a bell on it.
Mini Trail is offline   Reply With Quote
Old 03-30-2010, 02:13 PM   #4
WoovsHoovs
RUN SILENT
WoovsHoovs's Avatar
Oddometer: 3,830
They work ok-the main concern is adequate access, and of course cleanliness.
WoovsHoovs is offline   Reply With Quote
Old 03-30-2010, 02:52 PM   #5
NDEBT
NDEBT's Avatar
Oddometer: 4,530
This is the tools we use on the Ford modular engines. It is kind of a pain it the ass and unless you can borrow the tool kit from someone it may not be worth it. The tool kit cost around $400.00 IIRC.
http://www.lislecorp.com/uploads/ins...58DFB6E2A0.pdf
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. -Mark Twain
NDEBT is offline   Reply With Quote
Old 03-30-2010, 05:36 PM   #6
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 12,890
Sniper, how about asking this in the Garage section - might get more feedback there? Good luck with your fix!
PS, try Old's Cool too - just tell them you are working on a bike you found in your grampa's shed (maybe, say, a Henderson) and they'll be on it like a bum on a ham sammich!
Remodeling. Please check again later.
Mista Vern is offline   Reply With Quote
Old 03-30-2010, 05:50 PM   #7
dagwood
Idiot Royalty.
dagwood's Avatar
Oddometer: 35,376
Send a message via AIM to dagwood Send a message via Yahoo to dagwood
had one in my z1 900 years ago when traveling. not many options to pull the head. it never gave me any issues and i over revved the piss out of it. so I left it alone.
just my experience.
CA Stu; Of course, I am a simpleton.
dagwood is offline   Reply With Quote
Old 03-31-2010, 05:49 AM   #8
cagiva549
whats a cagiva
Oddometer: 2,454
I have attempted to use HeliCoil sparkplug thread repair inserts a couple times and failed both times . The threads cut fine and the insert is fine but I didn't get proper alignment in the head and the sparkplug gasket would not seal . Glad they were small engines that I could buy cylinders for cheap . Back in the old days I did tap out a couple heads with taper seat plugs to a larger size plug and keep on running with no problums . The tap would cut the plug gasket seat too so alignment wasn't an issue . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
86 Goldwing my geezer ride
cagiva549 is offline   Reply With Quote
Old 03-31-2010, 05:57 AM   #9
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 9,555
I used something very similar from Napa called a "Sav-a-thread kit"
It consisted of a threaded sleeve -- threaded on the ID for the stock plug and threaded on the OD for the supplied tap.
It worked by using the supplied reamer to enlarge the bad hole, then use the supplied tap to cut the new threads, then thread in the sleeve. Finally you used a supplied tool to tap the top of the threaded insert to supposedly spread it apart a bit and lock it into the hole. It worked fine as far as I can tell, and has held together for almost 5 years. However, I would not recommend using one as there is nothing to ultimately stop the insert from threading up or down in the hole other than the little knurls on the top that supposedly spread apart when tapped with the special tool. It's almost time to replace the plugs on that car and I'm dreading what is going to happen when I pull that particular plug.
I would definitely recommend a time-sert -- they have a shoulder on the top and the tap/reamer tool cuts a counterbore for the shoulder to screw into positively locating the insert preventing it from threading down into the hole during future plug installs. Plus the counterbore/shoulder gives a better sealing surface where the sav-a-thread kit had to be installed with RTV.
DON'T use a helicoil.
DO disconnect your ignition system and crank the starter motor after drilling/tapping to blow the chips out of the hole. Also duct tape some vinyl tubing to a vacuum and stick in in the cylinder.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Cobbie Award Winner
LuciferMutt is offline   Reply With Quote
Old 03-31-2010, 08:04 AM   #10
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 30,423
Good feedback, I had heard about both those tips you gave at the end of your post there! thanks and I thik Ill order one next week.
Thread Tools
Times are GMT -7.   It's 02:41 AM.
