Old 04-01-2010, 03:46 PM   #1
Frank06 OP
Oddometer: 211
Airhead Exhaust Nuts - Copper or Regular Anti-Seize?
I've successfully loosened the exhaust nuts on my '81 R100RT using JT's neat wrench (immovable when cold, not bad at all when warm!) Does it matter which type of anti-seize to use?
thanks,
Frank
Frank06 is offline   Reply With Quote
Old 04-01-2010, 03:56 PM   #2
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 7,935
I used the non-copper stuff about six months ago and just took off my nuts (no jokes guys ) a few days ago to install new headers... the non-copper stuff clearly wasn't doing much and it did take a heafty puch to break free the nuts...
I say copper from here on in.
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 04-01-2010, 03:59 PM   #3
AKjeff
AKjeff's Avatar
Oddometer: 4,433
I just did this long overdue item on both my airheads today. I used hi-temp nickel anti-seize I had on hand from another project. It's a little expensive, but I figure it's cheap insurance, considering.
It's good to 2400F, probably overkill.
"We can choose to know better or choose to be bitter." OldRoadToad
My Airhead Project
AKjeff is offline   Reply With Quote
Old 04-01-2010, 05:13 PM   #4
Frank06 OP
Oddometer: 211
This bike sat for quite a while before I bought it. The PO would periodically start it, changed the oil annually but never really drove it much the past 5 years or so. I didn't know if the nuts had ever even been off. No way they would budge this winter when cold but I read where someone said after the bike ran they practically fell off. Thankfully mine were in this category.
I found this thread after posting my question; I think I'll use copper.
thanks folks
http://www.advrider.com/forums/showthread.php?t=212510
Old 04-01-2010, 07:15 PM   #5
norton73
drinkin'
norton73's Avatar
Oddometer: 8,075
Felt like I hit the lottery this afternoon. On my recently aquired '81 R100RS I need to replace the pushrodtube seals. I asked the PO if he'd ever removed the exhaust nuts and he said no.
Little Kroil last night, blue tip wrench this afternoon, and off came the nuts, threads ok.
On my other bikes, I have a tube of Mopar Nickel antiseize that I've been using for years.
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 04-01-2010, 07:18 PM   #6
rkatapt
Indo-Kraut
Oddometer: 257
Send a message via MSN to rkatapt
Don't have any long term stories but, when I put the exhaust nuts back on I used copper anti seize. Supposed to be good up to 1800 degrees. The head will melt before it gets that hot.
rkatapt is offline   Reply With Quote
Old 04-02-2010, 03:26 AM   #7
r2adv
r2adv's Avatar
Oddometer: 526
Exhaust nuts
Definitely Nickel antisieze. I loosen mine and redo at the end of the season when she's tucked away for the winter.
Horizontally opposed to a vertical twin world
R12GSA, R100 GSPD, R80G/S, R75/5, R90S
r2adv is offline   Reply With Quote
Old 04-02-2010, 08:10 AM   #8
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 7,935
The non-copper, non-nickel stuff I used (that didn't work) was rated to 1600 degrees... not to say the head went above 1600... just that it didn't work!
Old 04-02-2010, 08:44 AM   #9
chiefrider
Chrome won't get you home
chiefrider's Avatar
Oddometer: 1,920
I've been using the copper stuff without problems.
I check the valves every oilchange, and I spin off the exhaust nuts everytime I pull the valve covers because I find it easier to get the little valve cover nuts started with the exhaust nuts out of the way.
I wirebrush the exhaust threads and apply fresh antiseize each time I do this.
Tom in Salem
I have found that all ugly things are made by those who strive to make something beautiful, and that all beautiful things are made by those who strive to make something useful. --Oscar Wilde
chiefrider is offline   Reply With Quote
Times are GMT -7.   It's 12:10 AM.
