Old 09-12-2012, 05:39 AM   #211
Mudguts OP
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,107
In the sakurama thread he uses a ice engineering tube tack clamp , I don't have one but I will make one a couple it will take about five minutes not including going the the brearing wholesalers. Photos to come
Oh Mr Sakurama Man what an awesome job
Mudguts is offline   Reply With Quote
Old 09-13-2012, 02:29 AM   #212
Mudguts OP
Mudguts's Avatar
Oddometer: 2,107
So TIG Torch still has not turned up , so I've spent the day mocking up the exhaust out of 40mm plumbing fittings .
cost about $40 still cheaper then cutting up a heap of stainless. Also when to the locak KTM dealer and got a freebee
350EXC header ( badly bent on the front bend which i cant use anyway ;)
Old 09-13-2012, 03:08 AM   #213
tileman
tileman's Avatar
Oddometer: 870
With all those curves get a big bottle of argon if your going to run a internal argon hose like Mr Sakurama when welding :loll
I do like the design and the way you made it.
Hence, damn you!!!!!!!!!!
spendy speny weeky for me...................
If ignorance is bliss, why aren´t more people happy?????
tileman is offline   Reply With Quote
Old 09-13-2012, 03:23 AM   #214
Mudguts OP
Mudguts's Avatar
Oddometer: 2,107
Yeh got a D size and spent a good hour on YouTube so I'm like fully sick TIg welder now .
Also found a motorcycle exhaust manufacturer that has gone out of business , he is letting me go through all his bends
And get what I want.
My header will go from 45mm to 60+ mm I,m basically copying the Akro header it will be just a little longer
I might have it inter -changeable between standard muffler / wings and Akro (60mm)
Mudguts screwed with this post 09-13-2012 at 03:30 AM
Old 09-13-2012, 03:31 AM   #215
Mudguts OP
Mudguts's Avatar
Oddometer: 2,107
Might wash the bike tomorrowv
Old 09-13-2012, 04:47 AM   #216
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,469
how much ground clearance do you loose?
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 09-13-2012, 04:55 AM   #217
Mudguts OP
Mudguts's Avatar
Oddometer: 2,107
About 10-15mm , not to bad but I have an extra 25 up front and 10 out back ,
I can maneuver ita bit were I,d lose 5-10 mm
Old 09-13-2012, 06:16 AM   #218
schattat
schattat's Avatar
Oddometer: 1,442
Nice, looking forward to seeing it tomorrow
RNS - Rallye Navigation Solutions
Yamaha WR450F Rallye Spec
schattat is offline   Reply With Quote
Old 09-14-2012, 01:24 AM   #219
Mudguts OP
Mudguts's Avatar
Oddometer: 2,107
Another day in the shed playing
Old 09-14-2012, 01:27 AM   #220
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 777
I've been toying with the idea of a rally fairing, but then I would have to sell my SM setup. Does that thing give you any real protection from the wind at highways speeds?
tattewell is online now   Reply With Quote
Old 09-14-2012, 02:11 AM   #221
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,469
i found this build last night and got to thinking about it today. you dont reckon that pipe will melt aye
Old 09-14-2012, 02:28 AM   #222
DRjoe
DRjoe's Avatar
Oddometer: 5,096
Old 09-14-2012, 06:26 AM   #223
Mudguts OP
Mudguts's Avatar
Oddometer: 2,107
Na she'll be right I'll wrap it in tin foil the plastic will melt bonding to the foil making a composite lite weight exhaust
There's no way the bike will burn to the ground
And the TIG torch is somewhere between Perth and QLD no where it is suppose to be
Old 09-14-2012, 07:02 AM   #224
Mudguts OP
Mudguts's Avatar
Oddometer: 2,107
This stuff does not melt but it smokes up nice funnley enough i was smoking this before i came up with the idea of using tin foil and talking to my mate charlie ,
how had seen his mate walter white or Heisenberg what he calls him self We have both been WINNING latley ,
Old 09-15-2012, 12:06 AM   #225
tileman
tileman's Avatar
Oddometer: 870
Who? where?
Times are GMT -7.   It's 09:38 AM.
