Old 04-08-2010, 01:35 PM   #1
butterbeard OP
butterbeard's Avatar
Oddometer: 9
Eek Fork Tube Bolt Stripped! F800GS
Well, yesterday I was attempting to remove the springs from my forks on my F800GS. When I tried to remove the bolt on the top to get the inner sanctum of my forks, the left side fork bolt stripped while using a 19mm 12 point socket. For some reason this thing was torqued way past 100ft lbs, this I know because I was using a torque wrench to unbolt it.
I thought this thing was only supposed to be torqued to 20nm?
I guess my real question is there any place to purchase one of these other than BMW? They are asking $67. I am trying to talk to Marzocchi as well. Already checked BikeBandit.
Current Ride:
'09 F800GS
butterbeard screwed with this post 04-08-2010 at 01:59 PM
butterbeard is offline   Reply With Quote
Old 04-08-2010, 03:00 PM   #2
itsatdm
itsatdm's Avatar
Oddometer: 4,856
I hope you loosened the top fork clamp before removing the cap. The clamp will compress the tube onto the cap. You might look at thet 2008 husky 610. They went to the no adjustum forks after BMW bought them. Then again they are now owned by BMW.
Old 04-08-2010, 03:26 PM   #3
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Yeah, you have to loosen #4 in the pic below before you try to loosen #26, since #4 clamps down at the very top top of the fork where #26 threads in. Keep #20 at the bottom tight though, to keep the fork tubes from spinning or falling out of the triples as you loosen #26.
Old 04-08-2010, 06:49 PM   #4
butterbeard OP
Oddometer: 9
DOH! Fixed. Have to buy a new one now. Sheit. Thanks!
Current Ride:
'09 F800GS
Old 04-08-2010, 06:51 PM   #5
Firefight911
Firefight911's Avatar
Oddometer: 997
If only BMW had put it together properly, it wouldn't have been an issue. DOH!!!!
The forks are not supposed to be flush.
Ride Safe, Ride Often, RIDE!!!!
Firefight911 is offline   Reply With Quote
Times are GMT -7.   It's 11:07 PM.
