Old 04-15-2010, 12:36 PM   #16
CHRIS_D
CHRIS_D's Avatar
Oddometer: 950
Originally Posted by Toddwmac
For those of us that appreciate the guidance...please don't.
Folks Powercell can be short but he knows his crap. Research his past post, he's a major KTM guy and I would personally take his advice seriously.
Yes I too have adjusted my cables, installed a G2 and even mechanically set my throttle (using set screw on the throttle bodies) to 1.5K RPM. I also have removed my secondary, so this may be why I haven't been experiencing any problems.
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 04-15-2010, 12:48 PM   #17
killurtv
free range moron
killurtv's Avatar
Oddometer: 640
[quote=CHRIS_D]Folks Powercell can be short but he knows his crap. Research his past post, he's a major KTM guy and I would personally take his advice seriously.
+1, BIG TIME!!! He does know what he is talking about, I have followed his advise on several occasions and all has worked out sweet.
one day I will learn, until that day... fuck it.
2001 HONDA XR650R
killurtv is offline   Reply With Quote
Old 04-15-2010, 02:01 PM   #18
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,855
G2
I installed mine with the 400 cam but like others have removed the secondary butterflys so I have had no problem what so ever with my cable adjustments.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 04-16-2010, 10:39 AM   #19
Toddwmac OP
ADV addict
Toddwmac's Avatar
Oddometer: 288
As a follow up, I ended up taking a "hybrid" approach (Hate that term these days). Anyway, I called 2 dealers and both agreed that the barrel adjustments for this amount of play were fine. They made sure to state to be sure to leave 2-3mm play and adjust with the motor off. I also consulted the 690 manual since it does talk about adjusting the throttle. It calls out the barrel adjustments but it also talks about the KTM diag computer.
I did the adjustments at the adjusters and after a day on the trail and time in the city, all is well. The bike ran great but I will bring it up to the tech during my 1st service (300 miles from now) to make sure all is good.
Todd
KTM 08 990 ADV
HD Duece
WR 250R
Lost but don't care!
Toddwmac is offline   Reply With Quote
Old 04-16-2010, 01:21 PM   #20
Fluffycat
Fluffycat's Avatar
Oddometer: 124
I think Jody H meant the adjusters up by the twist grip, as the fine tuners. There is another adjuster down by the throttle bodies for cable slack.
Cable slack on the 990 amplifies the poor fuelling/jerkiness that many complain about. Just adjust it to factory spec.(Off my head 3-4mm). You don't need a diagnostic tool for cable slack!.
If i get just one more bike i will have more bikes, then i can get one more bike.
Fluffycat is offline   Reply With Quote
Old 04-16-2010, 02:02 PM   #21
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,395
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 04-18-2010, 09:42 AM   #22
Blue&Yellow
but orange inside...
Blue&Yellow's Avatar
Oddometer: 754
Right, I've now done it myself. It is not rocket science and there's not need for a big orange specialist. Just adjust like you normally would and leave a little slack, easy.
Blue&Yellow is offline   Reply With Quote
Old 02-06-2011, 12:07 PM   #23
sabink
Oddometer: 116
It's not all about slack.
I took some time today and looked at the idle motor, throttle valves and cables. I think I understand the need to command the idle motor to release the throttle valves. Please take a look at the pictures and video and comment if I'm on the right path.
When adjusting the throttle grip free play we can do it using one of the two adjusters in the front or on the rear throttle cable. The problem seems to be that if we adjust the return (front) cable too short we can resist the idle motor and prevent it from opening the throttle enough for correct idle. The front cable must be long enough so that pushing the grip backwards it stops on the resistance point in the grip itself.
You can see on this video how with wrong adjustment the idle motor transfer movement on the grip.
http://www.youtube.com/watch?v=ioJTMVQmgoE
So the idea is to shut off the power when the motor is in it's test cycle and stop it on its disengaged state. Then adjust the throttle so that we cannot pull the bottom (return) cable when twisting back the throttle grip.
Here is a video how I think we can do that. Sorry for my bad English.
http://www.youtube.com/watch?v=2G8ejlxCyFU
PowerCell, what do you think? Will this do the trick?
I'm attaching a picture with the wrong adjustment that puts force on the idle motor.
sabink is offline   Reply With Quote
Old 02-06-2011, 12:16 PM   #24
sabink
Oddometer: 116
And this is the adjustment that I cannot put any force on the idle motor. It's a bike specific do not expect to be the same slack on your bike. I also have a G2 cam installed.
Old 02-06-2011, 02:30 PM   #25
mookymoo
Mookish Mook
Oddometer: 4,393
If you watch the video sabink posted above - you will see why its not a simple matter non the 990.
The EFI is not like a carb.
Here, I embedded it - but do go read sabink's post
mookymoo screwed with this post 02-06-2011 at 02:40 PM
mookymoo is offline   Reply With Quote
Old 05-27-2012, 01:43 PM   #26
Torquemada
Torquemada's Avatar
Oddometer: 26
Resurecting an old post. I had someone mess with my return cable tension adjustment so I had to find a way to set it all on the road. Hopefully this is helpful. Experts will chime in if it isn't I'm sure. Hopefully with some technical detail.
I referenced the video above from sabink and it would seem I got it right. In fact I'd say it's less fussy than before. I focused on paying attention to the unique sound the throttle stepper motor makes at position 0. To get a better feel for that I looked very closely at the throttle grip for when it moved (like 1mm back and forth) and stop it just at that moment.
WARNING: IF YOU ARE NOT COMFORTABLE WITH DOING THIS, DON'T. TAKE IT TO YOUR DEALER. YOU DON'T WANT TO DAMAGE THE THROTTLE STEPPER MOTOR.
SETUP
1. Handlebars straight ahead.
2. Ignition key OFF
3. Emergency cutoff switch OFF
4. Ignition key ON
LOOSEN CABLES FOR ADJUSTMENT
5. Loosened both cable adjusters appropriately. Not too much that they would be pushing against each other at the throttle cam.
POSITION THE SERVO MOTOR WITH EMERGENCY CUTOFF SWITCH
6. Emergency cutoff switch ON
7. Listen closely to servo motor sound and switch to OFF. Repeated 4 and 5 until I was sure.
RETURN CABLE ADJUSTMENT
8. With right hand roll throttle grip to closed position
9. With left hand tighten return cable adjuster (front) just until I feel it pull the throttle cam.
10. With left hand loosen return cable adjuster (front) about 3/4 to 1 turn.
11. Let go of the grip and tighten the backup nut on the return cable adjuster.
THROTTLE CABLE ADJUSTMENT
12. Tighten the throttle cable adjuster (rear) to spec (3 to 5mm) as per the owners manual.
FINISHING PROCEDURE
13. Ignition key OFF.
14. Emergency cutoff switch ON
15. Start it. Ride it.
TEST RIDE AND FOLLOW-UP ADJUSTMENT
It might seem like overkill but I then rode it for the first couple miles smoothly rolling on and off the throttle in the first couple gears to make sure everything was alright and give the bike ECU a chance to learn or complain, stall, cough, backfire, whatever. It rode fine but a few miles later I needed a little more slack taken out of the throttle cable so I repeated steps 1-4,6-7,12-15 again to get it.
Like I said it responded great after I performed all of the above
Torquemada is offline   Reply With Quote
Old 03-14-2013, 10:03 PM   #27
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,201
I am going to try this ^^
Mine stalls chronically when the weather is hot & I close the throttle abruptly.
Thanks.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 03-18-2013, 12:43 AM   #28
Zombie025
Oddometer: 109
Reassemble throttle cable
Hi,
i took my 2010 990R apart a while ago, waited for spare parts and now i lost my memory
Can someone please explain (best in pictures) how to reassemble the throttle cable to the throttle body, i'm lost in what was up and which one was down. I know from pulling the grip i shall see it, but want to avoid time consuming mistakes. Thanks for helping a noob
Zombie025 is offline   Reply With Quote
Old 03-18-2013, 07:24 AM   #29
JTXT
Oddometer: 83
Tune ECU
Tune ECU has a function that was added not too long ago to allow you to force the idle stepper motor to zero so you can properly adjust your throttle cables.
JTXT is offline   Reply With Quote
Old 03-22-2014, 12:24 AM   #30
grant22
grant22's Avatar
Oddometer: 476
Just passing on my recent experience adjusting throttle cables. It may or may not be agreeable, but I will state the facts.
I too recently bought a G2 for my 990 which created additional throttle free play for a total of about 3/8". Way too much and made riding of any type a pain in the arse.
I called my local ktm dealer and told them I wanted to come in and pay them to connect to the computer and properly adjust the throttle cables. The lead tech got on the phone and said, 'let me save you some time and money.' He explained that as long as I don't adjust against the stepper motors, there's nothing worn with adjusting some free play out of the cables.
He said to measure my free play, keep the ruler there on the grip, and adjust a little bit at a time until I'm at 1/8", give or take. Just don't go any further.
I went ahead and tried it and it worked. Bike is much more controllable now and have put 1000 miles on since with no ill effects.
The tech said he'd love for me to come in and spend money, but said there was just no need for it.
grant22 is offline   Reply With Quote
Times are GMT -7.   It's 12:56 PM.
