Old 04-10-2010, 01:17 PM   #1
BarryT OP
Oddometer: 672
Airhead Mikuni question
My R75/7 has a tendency to want to die when braking up to a stop sign or braking to a stop in general. If you rev the engine and return the throttle to zero when it is idling in the garage is settles back down to idle, but when you are riding and have to stop (pull clutch in reduce throttle and brake) idle idles down to about zero and stalls. I was wondering what this could be.
My 1st guess is
Float Level
Second guess is Idle mixture
Besides that issue it idle/runs smooth.
-Barry
2006 Buell Ulysses
BarryT is offline   Reply With Quote
Old 04-10-2010, 09:01 PM   #2
mykill
odd
mykill's Avatar
Oddometer: 1,166
Trend or event?
Just started happening or been getting progressively worse?
If it is an event, think about what changed and when.
Most likely it is a trend. Assuming all other factors are set up right, timing, valves, etc. Older carbs may have worn float needles, replace the needles before you start bending stuff. If needles or floats are wrong it will never be right.
Carbs can be mis-adjusted by a high speed setting masking an incorrect mixture setting. It is worth getting the mixture to smoothest/ fastest then bringing the speed down to the correct RPM then finely tuning the mixture again.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 04-10-2010, 09:50 PM   #3
drhach
gorillamanufacturing.com
drhach's Avatar
Oddometer: 2,492
Your thierd and fourth guesses might be intake leaks and a binding throttle cable. Those are both things that have caused similar issues with mine.
1976 R90/6
1972 XLCH
2010 Triumph Thunderbird SE
drhach is offline   Reply With Quote
Old 04-10-2010, 10:23 PM   #4
BarryT OP
Oddometer: 672
I dont think its intake leaks or binding cables. Its only when I do a hard stop (gas sloshing in the bowls). If I do a light stop or its in neutral and not moving it returns fine. Couls this still be worn needle or would it being doing it all the time with worn needles. The idles been like this since I got the bike. I have put on new coils, electronic ignition new wires and plugs cleaned carbs new timing change and seals, removed the carbond from heads and piston tops and it still does it...
_Barry
2006 Buell Ulysses
Old 04-11-2010, 01:22 AM   #5
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
I assume that revving it the garage means it's not at its full operating temp. Thus, the mixture screw has to be adjusted when the engine is at operating temp (at least 10 miles of riding). The mixture tends to lean out when already hot so my guess if your have a rich mixture, reason why it can't hold its idle speed when already at operating temp.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 04-11-2010, 06:56 AM   #6
BarryT OP
Oddometer: 672
I will give it a try, but it does this warmed up or cold and ONLY when making a hard stop (the clutch is of course pulled in). I was just thinking that all the gas in the floats, if to low is sloshing forward and the engine is starving for gas, but I will give the mixture a try.
-Barry
2006 Buell Ulysses
BarryT screwed with this post 04-11-2010 at 07:02 AM
Old 04-12-2010, 01:50 AM   #7
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
It would do that at operating temp if you're revving high then suddenly release the throttle with clutch pulled in. The idle just isn't stable enough to hold. Either too rich or lean (my guess is the former). Check the color of your plugs for a good indication.
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 04-12-2010, 07:10 AM   #8
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,843
Disclaimer: I have not worked on Mikunis. BUT, most carburetors are sensitive to proper float levels, since the jets are buried in the fuel to a certain level, and depend on air pressure/vacuum to pull the fuel up into the venturi.... most main jets are indeed in the middle of the bowl for a reason: fuel sloshes forward on braking, and back on acceleration. You don't want major changes in fuel levels at either extreme, hence the "middle of the bowl"...!!
I would check your floats, and per the advice above, do it after you have done a plug chop. Run the bike like you do, pull the clutch and cut the ignition (off) without letting it idle, and pull over to have a look at your plugs. They tell a good story: light khaki tan is perfect, white is too lean, dark tan/brown is too rich. Try adjusting your float levels to correct what you are seeing.
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 04-19-2010, 10:02 PM   #9
Middleweightboxer
Middleweightboxer
Middleweightboxer's Avatar
Oddometer: 681
Mikuni's once set properly seldom change(float level, jet wear etc). If carbs were running good and then started exhibiting the problem and the carbs are not gummed up then, 1) adjust the valves, this is the first thing to do with an airhead when you have idle problems. 2) Check timing, your description makes me wonder if your timing is not correct at idle. 3) adjust cable slack, set idle balance and air screw. An out of sync condition would make the condition you describe.
Bill
Tiger 800XC, R1, FZ1, RD400, CB400F
R80ST, R90S, Monster S2R, Penton 125 JPS, T25T
Middleweightboxer is offline   Reply With Quote
Old 05-07-2010, 08:40 PM   #10
BarryT OP
Oddometer: 672
I will give that a try tomorrow before the snow starts again. The valves are perfect and have been quadruple checked and it isnt the timing. It has a brand new chain and it did this with the electronic ignition and the points. At idle my plugs are black as night. I have taken the airscrews out pretty far and it is still showing rich. I do have the correct jets so that isnt it. Maybe the float level is to high? I did make sure that my slides were resting on the idle needles at idle and my idle is about 950 rpm when warmed up. Im getting really frustrated. This has been a problem since I bought the bike.
Barry
2006 Buell Ulysses
Old 05-07-2010, 09:12 PM   #11
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,040
Are you sure there air screws? Most mikuni pilot screws control fuel.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 05-08-2010, 08:53 AM   #12
mykill
odd
mykill's Avatar
Oddometer: 1,166
If you are adjusting the mixture screws while the engine is running and they do NOT change the idle speed/ smoothness with a half turn in either direction then you have the wrong idle jets for your application.
Fastest/ bst idle should have your mixture screws between 1 and 3 turns from seated. if it is rich throughout then you need to try the next smaller idle jets.
Old 05-08-2010, 08:55 AM   #13
BarryT OP
Oddometer: 672
The instruction manual says air screw.
2006 Buell Ulysses
Old 05-08-2010, 12:41 PM   #14
BarryT OP
Oddometer: 672
Well i leaned out the air screws quite a bit and the plugs went from ridiculously black to a clean black so I am thinking that I have a super rich condition at idle and it may essentially be flooding when I go from half throttle to idle. I did increase the float level because I thought it was starving for fuel. So I am going to bust the carbs back apart and put the float level to spec and adjust the idle screws from there.
2006 Buell Ulysses
BarryT screwed with this post 05-08-2010 at 02:52 PM
Old 05-09-2010, 06:48 PM   #15
Middleweightboxer
Middleweightboxer
Oddometer: 681
Remember you are dealing with air screws so screwing them is richer and out is leaner. Check your pilot jet sizes - 30's should be about right for your bike.
Bill
Times are GMT -7.   It's 02:19 AM.
