Old 07-05-2010, 02:10 PM   #61
Rone OP
Rone's Avatar
Oddometer: 58
Haan Wheels
Today a box was delivered from Haan Wheels Sport.
R 1200 GS '08 en G 650 X Challenge '08
My RTW XChallenge
Rone is offline   Reply With Quote
Old 07-06-2010, 12:25 AM   #62
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,797
Another satisfied Haan Wheel customer ;)
I will get them to lace up my rear hub later this year. Did you just send them your old hubs, they cleaned them up and laced them. Did they need to drill out any spoke holes?
Sibirsky Extreme 2009 BOOK and DVD available HERE
Moroccan Extreme 2011 DVD available HERE
www.sibirskyextreme.com
Colebatch is offline   Reply With Quote
Old 08-14-2010, 05:25 AM   #63
luc boxer
luc boxer's Avatar
Oddometer: 17
Thumb
Rone
luc boxer is offline   Reply With Quote
Old 08-14-2010, 09:42 AM   #64
Coho911
Coho911's Avatar
Oddometer: 1,241
My GOD that is a beautiful bike.
I DEMAND ride reports.
2007 KTM 640 Adventure 'Bricktop'
----> LC4 Info Thread <----
So many places to go and see, so little time...do it whenever you can, cause too late comes fast. - Coho
The internets BEST Site for Image Hosting ---> Smugmug <--- SAVE $ 5.00 on smugmug membership with this COUPON - hUuJ7EHBKXWDU
Coho911 is offline   Reply With Quote
Old 09-17-2010, 12:07 PM   #65
Rone OP
Rone's Avatar
Oddometer: 58
It is long since I gave an update. In about one month I start my journey through Africa.
There were still some things I wanted to make or modify.
  • Because I need to cook on my trip, I need fuel for my stove. I will take a bottle of 1 liter with me and I found a Fire Extinguisher Bracket from a car to carry the bottle. I mounted it on the subframe.
My RTW XChallenge
Old 09-17-2010, 12:08 PM   #66
Rone OP
Rone's Avatar
Oddometer: 58
  • Before I had mounted a center stand so it would be easy to take out the rear wheel when I would have a flat tire. The center stand was too heavy. So there I wanted a simple and especially lighter solution for it. So I made a second side stand at the right side.
My RTW XChallenge
Old 09-17-2010, 12:25 PM   #67
Rone OP
Rone's Avatar
Oddometer: 58
  • On my trip I will ride about 35000km. I think that it would be right to take a chain wheel and 2 sprockets with me. The chain wheel is a steel 47 T original BMW part n° 27717716859. The Sprockets 14 T are coming from Stephan Scheffelmeier. To take these with me, I made a bracket on the pannier rack. I will not take a chain with me. I hope that I can find a chain 520 in Africa.
My RTW XChallenge
Rone screwed with this post 09-17-2010 at 12:36 PM
Old 09-17-2010, 12:40 PM   #68
Rone OP
Rone's Avatar
Oddometer: 58
  • There was still some place behind the lift pannier rack (below the silencer) so I ordered a tooltube. I had place enough for the Mega Tube. I needed also make a bracket to mount the tooltube on the pannier rack.
My RTW XChallenge
Old 09-17-2010, 12:53 PM   #69
Rone OP
Rone's Avatar
Oddometer: 58
  • Because the aluminium spacers for the wheels (original BMW) are too soft, I ordered new spacers at Stephan Scheffelmeier because these are made from stainless steel.
My RTW XChallenge
Old 09-17-2010, 01:08 PM   #70
bigdon
Oddometer: 2,073
Don't forget to locktite those nuts!
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 09-17-2010, 01:15 PM   #71
Rone OP
Rone's Avatar
Oddometer: 58
  • I needed to find a solution to take enough water with me. I will use a Camelbak Mule NV with an extra 3 liters reservoir. So this makes 6 liters on my back. This is not enough, so I will carry more water on the bike. I found little and very strong jerry cans of 1 liter at Fuelfriend.de. I will carry 4 of them on the bike. Two at each side of the rally engine guard and two at each side of the pannier rack. I made brackets to fix them fast and (I hope) safe.
My RTW XChallenge
Old 09-17-2010, 01:36 PM   #72
Rone OP
Rone's Avatar
Oddometer: 58
  • When I will have a flat at the front, I also need to put the front off the ground so I can take the front wheel out. For that I made also a simpel thing. I mounted a bracket in front of the rally engine guard where I can put in a tube. When I drive, I need to carry the tube also. You can see on the last pictures where and how I carry the tube. Why there ? You will see it in a next update ....
My RTW XChallenge
Old 09-17-2010, 03:57 PM   #73
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,382
Some nice innovations there. Love the Blue Excel wheels!
Have you weighed luggage racks, rear rack, extra side stand, front stand, water brackets, bash plate and your bags (empty) ?
I guess you've done this route before so you know where you're going and what is needed?
Have a safe trip!
Old 12-01-2010, 07:42 PM   #74
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,302
Originally Posted by Rone View Post
The original wheel clamps are modified so the better cartridges could be fit to the original fork.
the adjustment for compression is now at the bottom.
the adjustment for rebound is now at the top.
The travel of 298.5 mm is reduced tot 280 mm so that the motorcycle is not too high for me.
Rone,
Just to make sure I am following you here. Instead of swapping the wheel clamps, you just had them machined out, and used the existing Xchallenge stancion tubes? Or did you remove the wheel clamps from the Xchallange Stancion tubes, have them machined, and then have them installed on the shiver stancion tubes?
Rob
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 12-15-2011, 08:37 AM   #75
Ian640
Oddometer: 243
It is a Ohlins from TT. They are special made for TT, so they are different to the one you can buy from Ohlins.
I also placed a spacer inside of it to make the bike a little lower.
Hi Rone,
How did you fix the Ohlins reservoir mount to your TT subframe? I have an Ohlins and the TT subframe and they don't look compatible.
Thanks,
Ian.
Ian640 is offline   Reply With Quote
Times are GMT -7.   It's 03:45 PM.
