Old 04-11-2010, 07:19 AM   #1
sstewart OP
sstewart's Avatar
Oddometer: 1,058
Pre-filter
If I run a pre-filter on my 950ADV will I have to re-jet carbs?
sstewart is offline   Reply With Quote
Old 04-11-2010, 09:12 AM   #2
Qwik
Adrenaline Addict
Oddometer: 6,947
I didnt and the bike runs great. They are a bit lean from the factory and the prefilter will fatten them up too.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 04-11-2010, 09:31 AM   #3
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
I would say that yes, it will run without changing the jetting. and it also falls into the "it depends" bin... in that if you are at sea level then it will run OK on the bottom, might surge a little in the middle but it will tend to be overly rich at the top... if you are beyond sea level, then it just gets worse.
So, no you do not have to rejet to run a prefilter, however it will run better if you do.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 04-11-2010, 09:34 AM   #4
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,198
Riding in heavy rain
What about using a pre-filter in very rainy conditions?
I know the original snorkel was curved backwards so it was difficult for water coming from the front of the bike to get into the air box.
Should I be concerned with using the pre-filter when riding in very heavy rain at highway speeds?
Q~
Old 04-11-2010, 09:43 AM   #5
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
Thumb
Q~
I live and ride in all conditions in Washington State.... most know what we are famous for (hint, its wet and falls from the sky rather frequently). I have over 12k miles on my prefilter and it has absolutely been flawless in all conditions from 100+ desert to 20 degrees to 40 and raining buckets... even in river crossings it has been just fine. I "tested" its ability to reject water after.. um.. testing the depth of the water with the bike (falling over)... after clearing the engine all was just ducky... not a problem.
Old 04-11-2010, 10:40 AM   #6
jsrider
Oddometer: 3,495
H2W won't say it, so I will: If you combine a pre-filter with one of his jet kits, you will be very happy.
jsrider is offline   Reply With Quote
Old 04-11-2010, 05:38 PM   #7
mookymoo
Mookish Mook
Oddometer: 4,396
Agreed. I would definitely rejet.
Even with the re-jet I still found my mains a bit rich.
I also found that the preflter blocks up pretty quickly. Even riding on the road in non-dusty conditions, I would clean & replace it pretty regularly...
mookymoo screwed with this post 04-12-2010 at 12:18 PM
mookymoo is offline   Reply With Quote
Old 04-11-2010, 05:59 PM   #8
a$$hole
a$$hole's Avatar
Oddometer: 997
Slight hijack here. So on my 990 it pops ALOT of decel and between shifts. I have a 2 into 1 with a very free flowing pipe. If I were to put a prefilter on would it tame some of the farting? Once again sorry about the hijack.
a$$hole is offline   Reply With Quote
Old 04-11-2010, 08:29 PM   #9
David37
David37's Avatar
Oddometer: 410
You won't have to rejet with a pre-filter. I put one on my 950SE and it runs great with the stock jetting.
If your bike pops on decel, sounds like you have a lean condition. I would try turning out your air/fuel screws 1/4 to 3/4 turns to richen your air/fuel mixture. An exhaust leak can create a lean mixture too.
David37 is offline   Reply With Quote
Old 04-11-2010, 10:44 PM   #10
Oldfatbeerman
Enroute to a PUB
Oldfatbeerman's Avatar
Oddometer: 3,997
Uni filter pre filter is plug and play .
It does not matter how much lipstick , lingerie , botox or other beauty enhancing products you put on or in a Pig , it is still a PIG .
Oldfatbeerman is offline   Reply With Quote
Old 04-12-2010, 12:25 PM   #11
mookymoo
Mookish Mook
Oddometer: 4,396
.... that tends to go against the grain of the general consensus here as I understand it....
As H2W mentions above, mains will be rich even at sea level...
Its a reasonable restriction on the intake (worse, if its heavily oiled, and worse again when it gets dirty) ...
Old 04-12-2010, 05:18 PM   #12
ryanwilliamcantrell
Get Out and Ride!!
ryanwilliamcantrell's Avatar
Oddometer: 3,861
Having put 10k on a new pre-filter last year, I HIGHLY recommend it. It's saved me from having to mess with my filter constantly. As someone else said, it'll plug with dirt quickly and frequently (which means its doing it's job) so keep an eye on in.
Ride your own ride & enjoy your ride.
ryanwilliamcantrell is offline   Reply With Quote
Old 04-12-2010, 07:20 PM   #13
Oldfatbeerman
Enroute to a PUB
Oddometer: 3,997
I was assuming the jetting had been set correctly before the filter was installed ........ mine had and I fitted the pre filter and there is no ill effect , runs just fine , has same economy ( provided pre filter is clean ) feels to have the same output , power and torque wise . Still needs same amount of Choke to cold start in summer ( lots ).... I have not done anything scientifically significant to tell all that for sure though . Seat of the pants works for me !
Some of the gentlemen here are a bit over the top with the state of tune they demand on 100 hp dirt dikes . You can't use all that power on anything but Tarmac so a small amount of richness in the running will have your bike running cooler and will probably last a bit longer because of it . Swings and roundabouts .
Old 04-13-2010, 06:50 AM   #14
Geek
oot & aboot
Geek's Avatar
Oddometer: 32,063
Does anyone have a uni part number or a link to the prefilter online?
Mine has a hole in it
Old 04-13-2010, 06:52 AM   #15
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,200
http://www.ktmtwins.com/950adventure/nu-1415.html
Backorder.
H2W sells them.
http://www.advmachines.com/product_p/am1415.htm
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger"
My2Wheels
dad2bike is offline   Reply With Quote
Times are GMT -7.   It's 02:21 AM.
