Old 05-17-2010, 04:00 PM   #226
catalina38
Contrarian
Oddometer: 1,606
My dad and I just got matching 2010 990R's a few months ago and he is 67
Originally Posted by folknride
I went for a nice ride to test my new tank venting system (copied this - http://www.advmachines.com/product_p/tankvent.htm), my new 661 pressure jersey, and my 65th birthday! Happy to report that everything works great.
My wife took this, I think, to show the grandkids what an idjit there grandpa used to be, when he was young.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 05-18-2010, 01:16 PM   #227
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,094
Getting it ready for a 3 day all-dirt romp all over north western colorado
Old 05-18-2010, 01:23 PM   #228
209ninja
209ninja's Avatar
Oddometer: 122
Mefo's ?
"Life By Design"
http://www.hostpuppies.com
2008, KTM, 990, Adventure, Current
2008, Kawasaki, Ninja, ZX-10 Current
2005, KTM, 950, Adventure, For Sale
2003, KTM, 625, SXC, Sold
Pics: http://s895.photobucket.com/albums/ac157/209ninja/
SierraNevadaAdventures.com Member
http://www.sierranevadaadventures.com
209ninja is offline   Reply With Quote
Old 05-18-2010, 01:49 PM   #229
DakarBlues
One-everythinged man
Oddometer: 1,285
Noise-beating system
Not today, but some time in the past:
It was a system to break the vacuum pocket behind the screen, that vacuum pocket is the cause of buffeting and noise.
I worked quite well, I was able to hear my Akros up to 55mph.
Front intake behind grill
left outlet behind windscreen
Right outlet behind windscreen
central outlet in the middle,
the intake behind the front grill where it fed air to those tubes which came up behind the windscreen to these "ears" along with another outlet at the bottom of the dashboard.
As you see I had great time with my 950
He, whose nuts skim the ground while airborne, won't crash very far!
Pedibus Cum Jambus 1200 S
IBA # 38875
DakarBlues is offline   Reply With Quote
Old 05-18-2010, 04:55 PM   #230
Flameout
Flameout's Avatar
Location: I'm right where I'm suppose to be all the time!
Oddometer: 275
Question
Originally Posted by Fighthard
Installed the latest generation (Gen 2) SW Motech Crash Bars on the 990 Adventure and then gave her a nice wash and took a 2 hour ride.
Well, I tried to do this as well today with my gen 2 on my '10 ADV R. Maybe I'm doing something wrong but the rear hole in the crashbar on the left side seems to be too short...won't get even close to the frame where the frame clamp is...like by an inch or so. And I have to press up on the right bar in the rear to get it close to the frame clamp hole. I'm not sure but I thought these were suppose to fit? Am I doing something wrong, missing something or is a call to twisted throttle in order?
"Artillery lends dignity to what might otherwise be a vulgar brawl."
Frederick The Great (1712 AD - 1786 AD)
FOLLOW ME!
http://share.findmespot.com/shared/f...rytJ4p77xkQ75p
Flameout is offline   Reply With Quote
Old 05-18-2010, 08:02 PM   #231
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,094
Originally Posted by 209ninja
Mefo's ?
Yup.. TKC80 front with MEFO rear. I'm trying to find a combination that will last for a 4000 mile ride I have coming up in July.
Old 05-18-2010, 08:02 PM   #232
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,094
Wow! formula 1 has nothing on you!
So what are the results? Worth all the effort?
Old 05-18-2010, 08:25 PM   #233
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,395
holy krap, nww i think i've seen it all!
and I thought I was a cobbler.
good stuff.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 05-18-2010, 08:30 PM   #234
Kendrick
Kendrick's Avatar
Oddometer: 110
hey, what rack do you have that dual rotopax set up mounted to?
http://mattkendrick.whereamiriding.com
'09 950SE
'07 525EXC
Kendrick is offline   Reply With Quote
Old 05-18-2010, 08:36 PM   #235
Kendrick
Kendrick's Avatar
Oddometer: 110
nevermind. blackdog. saw it on your smugmug account.
'09 950SE
'07 525EXC
Old 05-18-2010, 10:35 PM   #236
209ninja
209ninja's Avatar
Oddometer: 122
good set up. My friend mark who runs www.sierranevadaadventures.com runs that exact same set up on his 07 KTM 990 Adventure. I am following his lead on that. When most of the crew went down on Lost Coast in the mud his tires stuck like glue. He said the manufacture is saying that you can get 7000 miles out of them.
"Life By Design"
Old 05-18-2010, 10:36 PM   #237
209ninja
209ninja's Avatar
Oddometer: 122
Did the canisterectomy light mod today. Will see out it comes out.
"Life By Design"
Old 05-18-2010, 10:58 PM   #238
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 405
Re-assembly
Putting the 950 back together after checking the valve clearance. Flushed coolent, RR thermostat, rad cap,oil press sensor, spark plugs. Leak check revealed carb fuel fittings leaking bad. O-rings bad. gave up for the night.
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV is offline   Reply With Quote
Old 05-19-2010, 12:08 AM   #239
Denalidirt
High Plains Drifter
Denalidirt's Avatar
Oddometer: 921
new rubber
Well, went out to ride to work today and noticed a flat on the bike. I put some air to it and could hear the air escaping. When I got home I decided to put the new rubber on, even though I still had about 1000 miles left to the old tire. call me lazy but I prefer to change tires only once a year.
Today I put new sneakers on my ride.
Denalidirt is offline   Reply With Quote
Old 05-19-2010, 12:49 AM   #240
nvdesertrat
Nevada Desert Rat
nvdesertrat's Avatar
Oddometer: 210
Camera Pedestal
I decided to make myself a camera pedestal for my Adventure 990R, a little crude but effective . All the parts cost about 10 bucks.
I made it so the tower can easily be changed out for different size heights.
And the camera has full swivel motion
Doug
2009 KTM 990 Adventure R
2014 KTM 500 EXC
2014 KTM 1190 Adventure R
nvdesertrat is offline   Reply With Quote
Times are GMT -7.   It's 10:55 PM.
