Old 05-25-2012, 01:42 PM   #5791
PS-RagE
PS-RagE's Avatar
Oddometer: 648
Finally came to a decision on decals:
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is online now   Reply With Quote
Old 05-25-2012, 08:00 PM   #5792
Av8rPaul
Av8rPaul's Avatar
Oddometer: 445
How does a guy follow that up Rage? Your bike looks SICK!!!
I did install my new Oberon slave cylinder though...
Paul IBA #33
Av8rPaul is online now   Reply With Quote
Old 05-26-2012, 12:14 AM   #5793
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,229
I was only going to check the valves, really...
Tore it down to check the valves, second time in 35K miles. I was ready for the job with CJdesigns Hot Cams kit:
Only 2 exhaust shims needed (one in each head, of course), barely a half size. The valves are holding nicely.
While it was apart ...
Installed a new Wings can, direct from Slovenia.
2-into-1 is from HT Racing
Installed a Dimple SuperMagnet sump oil plug, OEM on the right
Installed a right-hand side shroud over my second fan
Converted to studs on crash bar mounts
Tested my fuel pressure. It was a little low
so I serviced the fuel pump. The used parts:
Had my suspension forks and shock shock revalved and serviced by Konflict Motorsports
Sooo much nicer now.
While I was re-installing the suspension I noticed the steering head bearing were too loose, took it apart and they were shot.
Rebuilt them with an All Balls kit from CJracer.
And, well... while the steering head was apart replaced the top triples with BRP and Scotts goodies
Put some almost-new Scorps on it and balanced the wheels, fixed all the other niggling little stuff, rewired so my heated handgrips were now on switched power and will no longer drain my battery when I forget them.
Noticed one of my throttle cable ends was frayed by the throttle bodies, so I replaced both with a Motion Pro throttle cable set. High quality construction, I think better than OEM, and less expensive than OEM.
and finally...
New chain and sprockets, bling SuperSprox in the rear (17/45). Filled 'er up with Jonah's Top 1 good stuff.
Wow, I forgot how much better and more stable it steers with good steering head bearings properly adjusted.
Wings can sounds mighty nice too IMHO.
cyborg is offline   Reply With Quote
Old 05-26-2012, 06:27 AM   #5794
BroodRooster
BroodRooster's Avatar
Oddometer: 77
Took my KTM for a ride with the new Dunlop trailmax tr91 tires. The first couple of km's were weird and I wasn't riding confident, but after that it got better. On loose gravel it's okay as long as you maintain speed, on the white sand in the background it wasn't really good. The front end just kept digging in. So it's a great tire for me, riding 90% on road
One weird thing though: these things are slippery on my garage floor
BroodRooster is offline   Reply With Quote
Old 05-26-2012, 07:02 AM   #5795
Yascher
Yascher's Avatar
Oddometer: 388
Hi Cyborg,
Which map you run for your 2-1 system?
Yascher is offline   Reply With Quote
Old 05-26-2012, 07:10 AM   #5796
Yascher
Yascher's Avatar
Oddometer: 388
Great job there!!!!
Love that 2-1 pipe
So that is some special muffler for bigger outlet diameter of the HT 2-1 pipe....is it from BMW or something?
Is it any better than original?
Where did you get this one from?
Old 05-26-2012, 07:10 AM   #5797
CharlieFox
Oddometer: 196
Originally Posted by Yascher View Post
Hi Cyborg,
And where did you get the deflector for the right side fan?
CharlieFox is offline   Reply With Quote
Old 05-26-2012, 07:37 AM   #5798
rockitdoc
rockitdoc's Avatar
Oddometer: 391
Aeroflow on my 990A
Aeroflow works great, but too tall for me (6', 34" inseam) so I added two holes to lower it 2".
Still flows air over me and now I look over it. Much better for a short squirt like me. Shoulda ordered the medium, but easier to lower than raise.
'00 DR650SE
'60 BSA Gold Star Clubman (in process)
'76 BMW R90S
'77 BMW R100RS
'85 Laverda RGS1000SFC (also in process)
rockitdoc is offline   Reply With Quote
Old 05-26-2012, 07:58 AM   #5799
cyborg
cyborg's Avatar
Oddometer: 5,229
Made it from a left side deflector that I trimmed and modified a bit and mounted with cable ties.
Old 05-26-2012, 08:01 AM   #5800
cyborg
cyborg's Avatar
Oddometer: 5,229
Hi Cyborg,
My own map done with a Tuneboy.
See: http://www.advrider.com/forums/showthread.php?t=328809
Old 05-26-2012, 08:17 AM   #5801
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
Got in some of my first "real" off-road riding with Geek, D-Train, and LemurPilot. Up above Wolford Mountain reservoir...
FYYFF!
http://www.youtube.com/watch?v=NtpUv4VBDhA
Bikes: 2013 BMW K1600GT
A Few Past Bikes
: 2003 Suzuki DRZ400E | 2012 BMW K13S | 2009 KTM 990 Adventure
Narsisco Lopez is offline   Reply With Quote
Old 05-26-2012, 08:19 AM   #5802
cyborg
cyborg's Avatar
Oddometer: 5,229
I didn't like the FMF muffler that came with the HT Racing system. I sent my 2-into-1 specs to Gorazd Marovic of Wings during the Winter when things were slower and he made a custom can for my 2" OD header. Awesome craftsmanship!
Is it any better than original? [new oil drain plug]
Don't know yet, just installed it Saw it on OC somewhere www.drainplugmagnets.com/ and seemed like a good idea to capture more metalic debris. Mine is the M22 x 9mm
Their next size up M22 x 14mm was too long and interfered with engine parts inside the drain opening. I'm just experimenting.
Old 05-27-2012, 04:00 AM   #5803
Peanuts
Peanuts's Avatar
Oddometer: 1,666
I installed a cigar lighter socket complete with USB adapter to charge my phone as I ride
Peanuts is offline   Reply With Quote
Old 05-27-2012, 07:43 AM   #5804
matthewavale
Oddometer: 2
Help
hello I was not sure where to post this. I own an RC8 and need to complete my 10,000km service, which includes valve adjustments etc. A fellow rider who owns and does all his own work on his adventure/enduro KTM has offered to help me with the service. I'm hoping someone can advise me on if I need to let a pro do this tune up, or if I can rely on a knowledgeable friend?
Thank you
Matthew
matthewavale is offline   Reply With Quote
Old 05-27-2012, 08:21 AM   #5805
biggus
biggus's Avatar
Oddometer: 378
Added Carbon Fiber.
Looking bling vinyl that is.
The paint on top of my right fairing was starting to peal of and getting worse. I found some 3M Dinoc looking stuff here in Thailand that is supposed to be from Taiwan and covered it up.
While I was at it I decided to cover that hideous looking Rally Raid Screen that they neglect to finish on one side.
Before the Bling:
After:
Dull side gone:
biggus is offline   Reply With Quote
Times are GMT -7.   It's 04:29 PM.
