Old 09-06-2012, 08:24 AM   #6451
vonotto
vonotto's Avatar
Oddometer: 250
Originally Posted by EZ300 View Post
Called up James at Super Plush Suspensions and started working out the details of my fork set-up.
You'll like the upgrade
vonotto is offline   Reply With Quote
Old 09-06-2012, 07:51 PM   #6452
Shuffler
Hommes Grande
Shuffler's Avatar
Oddometer: 1,687
Wheels...
Before last week's trip, I finally got around to getting the new wheels on my '04. New chain & sprockets as well. Even mounted the tires myself and didn't f**k anything up or scratch 'em.
Woody's superlaced Excel rim/Rad hub tubeless rear, Woody's superlaced Excel rim/Rad hub front with the Tubliss system. Repsol orange powdercoat (not my choice, somebody else had them built & then didn't want them)
Rode some gnar and got the setup properly tested & broken in ... no issues at all - this is a great setup!
________________________________
AMA | COHVCO | TPA | NCTR | BRC
KTM 950A | KTM 300XCW | BMW R1100RT
Shuffler is offline   Reply With Quote
Old 09-07-2012, 04:45 AM   #6453
snarley
snarley's Avatar
Oddometer: 501
Just made up a couple of mounts for my new GoPro HD2 cam, front facing, rear facing and side view. Now for the testing....
Did I mention how farking great the 990AdvS is........
snarley is offline   Reply With Quote
Old 09-07-2012, 07:08 AM   #6454
Blackbert
Factory Rambler
Blackbert's Avatar
Oddometer: 1,058
Gave her some real travel bags.
Design: Colebatch, famous inmate here.
Sold by AdventureSpec.
They are huge. Loops to hold the straps in place, a waterproof inner bag (on top of the bike), 4 bottle holders.
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy)
want to save on Smugmug? use this code (VoUO8M1ukmnMY)
Blackbert is offline   Reply With Quote
Old 09-07-2012, 07:25 AM   #6455
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Originally Posted by spencergt66 View Post
I ordered a new Wins NOS can with carbon tip for the 990
You will LOVE them!!!! I do.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 09-07-2012, 12:01 PM   #6456
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,149
not today but, in the last few days...
swapped my broken old stock indicators with these short ones ...
stock
new
did a water pump overhaul and changed the bearings
this bolt was corroded, but from the coloring, it looks like some corrosive liquid came into the pump from the front cyclinder head causing the erosion of the steel bolt. but this has not affected the aluminium of the pump case / cover.
bad picture but you can see the bolt head eroded completely
lots of powdery metal looking stuff
the seal and shaft showed signs of abnormal wear / high temperature
Photobucket
one of the bearings went and had jammed (was it because of the corrosive liquid getting in through the seal ?). The shaft kept spinning inside and wore itself and the bearing inner race out.
bought new bearings and swapped them out
cleaned the injectors in-situ as i didn't want to take them out. nor did i want to put injector cleaner in to the fuel tanks.
ny own injector cleaner kit. a piece of wire, a syringe, a spare battery and the wiring diagram .. there u go, you have an injector cleaner kit
checked the valve clearance. at approx 30,000kms they are perfectly in spec.
removed the SAI plumbing and valve.
removed stock coolant hoses
and replaced with a SAMCO kit
the two small pieces are a bit longer than stock so the long hose which connects two heads together falls short. and if you ignore this then you will have a leak / blown hose as the clamp does not hold it well. i cut off 2mm from each of the two small hoses to sort this out.
and then one of the hose clamps decides to give u a hard time... thankfully got another one in without much drama
did a seal + bushings change alongwith 0.64kg springs for the forks
stock
the Mrs' hair dryer came in handy to pull out the fork seal
worn stock bushings on the left, new ones on the right
the lower fork leg shows some wear. nothing major i'm hoping
take care while installing the fork seal and dust wiper
new 0.64kg spring wouldn't go in easily
shaved off the guide and all was ok
gonna install a new 16/45 sprocket alongwith new VM525 chain later along with lot more stuff to do in the coming days. weather is still bad here (hot and humid) so i dont have to hurry...
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks screwed with this post 09-07-2012 at 12:10 PM
Vicks is online now   Reply With Quote
Old 09-07-2012, 12:20 PM   #6457
Dan950ser
NW Shredder
Oddometer: 475
Nice maintainence plan there.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR For Sale http://www.advrider.com/forums/showthread.php?t=1046431, 2014 KTM 250 XC-W
Dan950ser is online now   Reply With Quote
Old 09-07-2012, 03:02 PM   #6458
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,563
Removed the Perelli MT21 (4,000 miles) from the front and spooned on a Heidenau K60 scout. The old & the new-
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is online now   Reply With Quote
Old 09-07-2012, 03:49 PM   #6459
ekmek
ekmek's Avatar
Oddometer: 22
[QUOTE=Hondo;19543907]Removed the Perelli MT21 (4,000 miles) from the front and spooned on a Heidenau K60 scout. The old & the new-
what's your impression after 4.000 miles with MT21? isn't this a bit slippery?
Ride It Like You Stole It
2008 current KTM Adventure 990
2007 Yamaha FJR
2005 Honda Varadero
2003 Bmw GS
ekmek is offline   Reply With Quote
Old 09-07-2012, 04:51 PM   #6460
Hondo
Hondo's Avatar
Oddometer: 9,563
[QUOTE=ekmek;19544212]
Yeah, it was used up big time. Not really slippery, just felt odd at speed and when slow it was very rough as I was riding on the center knobs only.
Old 09-07-2012, 07:23 PM   #6461
folknride
Old Adventurer
folknride's Avatar
Oddometer: 682
Finally fixed my broken screw!
Went from this
To this
Huge PITA! Managed to drill it out (mostly - drill drifted a bit in the stainless), then re-tap. constructed some very weird rube goldberg rigs to get drill and tap long enough to fit in the tight spot.
Then finished up what I intended to do in the first place - before I broke the screw.
Drilled the drain holes in the swing arm (DO IT!)
New K60 Scout
New chain and sprockets.
New rear brake pads.
Greased swingarm bearings (it was apart anyway)
Went for a brisk ride!
Question? Is it OK to remove this bolt (the outside one) on the rear rebound adjuster to lube inside. The adjuster screw rusted on my old 950, broke, and was very difficult to fix. There's no nitrogen in there is there?
Occurred to me (often) that if I wasn't willing/semi-able to do this stuff myself, rideing the KTM would be a pricy proposition
folknride is offline   Reply With Quote
Old 09-07-2012, 08:34 PM   #6462
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,836
Did that once to my KTM dirt bike. There's a gas or oil in there, I can't remember which. I just remember there's something there.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 09-08-2012, 12:34 AM   #6463
cat
cat's Avatar
Oddometer: 1,323
Big diameter hose...how did you cut it, to keep it clean and straight?
Someone should tell them.
ohhh, so they give crappy hose clamps. ok to use screw clamps instead of the Oetiker clamps - if only because it's so difficult to get the crimp pincers in some places, but those are not good enough.
What is the tape under the clamps? I've never noticed that before, in pics of Samco hoses.
cat is offline   Reply With Quote
Old 09-09-2012, 03:04 AM   #6464
Oz Nutter
Oddometer: 1,272
Thumb Changed the oil,filter/screen etc
Got out of bed,straight into it, due to ride at 9.30 am, dropped the oil, (Motol) thin as water, swapped out filter and screens, new chain/sprocket yesterday lots of cleaning , new chain slider (NOTE: grease slider attachment bolts or they seize in swing arm !!)
Rode 250 kms through forest see :GTR Nelson ride (OZ)
Oz Nutter is offline   Reply With Quote
Old 09-09-2012, 08:38 AM   #6465
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,149
I cut the hose with a regular knife. The outcome wasn't perfectly clean n straight but not so bad that it was an issue either.
Actually, i bought those crappy hose clamps. I prefer the screw (worm ?) clamps for ease of installation. Lets see how these fare. Only, i should have bought better quality ones (jubilee ?) but i used these just bcos i had them laying around. But once i had put the whole thing together and installed on the bike (after getting several cuts / skinned knucles) i couldn't think of taking it all off for the sake of replacing the clamps.
Its normal insulation tape to prevent the clamps from cutting into the hose, just as a precaution.
Times are GMT -7.   It's 09:47 PM.
