Old 09-23-2012, 07:05 PM   #6571
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 873
I think it is a hitch for a single wheel trailer similar to a motomule unit or something
1Bonehead is online now   Reply With Quote
Old 09-23-2012, 08:15 PM   #6572
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 5,516
Geek, 1Bonehead has it correct. I love the Moto Mule design. But, I'd rather work at building my own, than actually spending my day job's money toward buying one (no offense, Mr. Bracket). I like to fabricate and "make it my own."
It does look like a chock. But, what you saw in the pic has been scrapped and I'm going with a through-the-axle design instead. Those lugs are built, as I learned today, to support the rear for a bike stand but they may not hold up to stresses from a trailer.
I'll get more pics up as I progress.
06 KTM 950 Adventure S
08 Dodge 2500, QC Shortbed, Cummins 6-speed auto, Big Horn
DakarNick is offline   Reply With Quote
Old 09-26-2012, 02:21 AM   #6573
Kenbike
Oddometer: 490
Installed a replacement voltage regulator from Rick's replace under warranty. The old VR was putting out 14 to 13 v and my Ballastic battery failed because of it. Switched to a $70 Walmart AMG battery and hope this VR holds up.
Current Bikes: 2012 Yamaha Tenere, 2010 Vespa 300 Super scooter ( hers), 2011 Blur 220i (his)
Kenbike is offline   Reply With Quote
Old 09-26-2012, 03:02 AM   #6574
markie_wales
Oddometer: 873
fitted some folding mirrors after nearly having a couple of off's when riding through dense bushes on my big trip away this year. Think they will vibrate more than the std ones (garage check), but not been out to check as the rain here is of Noah proportions. Fold in nicely, and put some Velcro (soft side) where they touch down to protect them.
I think my SE may actually be finished now..... yeah, I know
cheers
Markie
- "Dad, when I grow up I want to ride motorbikes like you do." -------- "Son, you can't do both."
- Only bikers understand why dogs like to stick their heads out of car windows.
markie_wales is offline   Reply With Quote
Old 09-26-2012, 03:30 AM   #6575
Bannisdale
....snowing now!
Bannisdale's Avatar
Oddometer: 207
cheers
Markie
I put some Wemoto folding mirrors on a while back and they actually vibrate less than the stock ones. I can see what's behind me on motorways now without having to damp the vibes with my hand!
If yo leave them slightly loose they also fold on impact if you forget to fold them in first....don't ask me how I know...
If you can keep your head when all about you are losing theirs, it's just possible you haven't quite fully grasped the situation...
Bannisdale is offline   Reply With Quote
Old 09-26-2012, 03:39 AM   #6576
mousitsas
Oddometer: 2,143
Have you considered to attach the hinge on a suspended mass point? It will do wonders to handling.
Old 09-26-2012, 04:03 AM   #6577
mousitsas
Oddometer: 2,143
These days I got rid of the main filter/prefilter on my SE in favour of a DNA main filter, 165/160 main jets (instead of the 152/148 per H2W) and 3 turns out for the fuel screws. All other jets remained according to the H2W setup. Also modded the sommers doors. Sea level @ 25C, akrapovic with large inserts.
I am impressed with the outcome. Midrange is brutal, low end stronger compared to the prefilter setup and the top end is a fair bit stronger too. I went from 16/45 gearing to 17/42 to make the 1st usable on the street. Roll-on on 5th seems sligthly softer than on 6th and 16/45.
Haven't been to the dyno yet to check AFR but it seems 'fine', it might be a bit lean on bottom and on the top if anything, but I refrain from high revs till I'm sure anyway. I expect consumption to drop on the motorway.
mousitsas screwed with this post 09-26-2012 at 04:12 AM
Old 09-26-2012, 04:03 AM   #6578
markie_wales
Oddometer: 873
Thanks for heads heads up - I already leave my levers / mounts slightly loose for the same reason and it's saved me too!
cheers
Markie
Old 09-26-2012, 06:14 AM   #6579
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 5,516
I've seen a few home made trailers like with it suspended from the rear subframe but not sure if I like that mounting. Yes, every other vehicle on the road has a hitch mounted to the frame and not the wheel. The trailer wheel will have a swingarm and shock.
Old 09-27-2012, 06:51 AM   #6580
TheMuffinMan
TheMuffinMan's Avatar
Oddometer: 3,718
"Civilize the mind, but make savage the body."
To the house of a friend the way is never long.
"Show respect to all, but grovel to none."
'12 690 Enduro // 690 Wiki
TheMuffinMan is offline   Reply With Quote
Old 09-27-2012, 07:14 AM   #6581
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,665
Put a fairing on my new to me 2007 SE.
Old 09-27-2012, 07:28 AM   #6582
spafxer
spafxer's Avatar
Oddometer: 2,323
Originally Posted by Peanuts View Post
I prefer to drill the holes out to 6mm then use a long allen screw to pass all the way through the swingarm to a nyloc nut on the other side. Will never come loose then.
That is a really good idea.. Too bad they don't do it from the factory. I must do this next time I have the wheel off.
One suggestion. To fully use the fiber locking nut, the threads are supposed to protrude by 1 and 1/2 turns. (Sorry, aircraft mechanic speaking here! ) If you used locktite too, then it's probably ok.
spafxer is offline   Reply With Quote
Old 09-27-2012, 03:00 PM   #6583
EZ300
EZ300's Avatar
Oddometer: 518
Bolted up my forks that I just got back from getting rebuilt by SPS and rode the 990 to work.
Can't wait to get it on the trails and see if it was worth all that money!
EZ
AMRA
2007 KTM 990 Adventure
2008 KTM 300 XCW
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 09-27-2012, 03:32 PM   #6584
Peanuts
Peanuts's Avatar
Oddometer: 1,032
One suggestion. To fully use the fiber locking nut, the threads are supposed to protrude by 1 and 1/2 turns. (Sorry, aircraft mechanic speaking here! ) If you used locktite too, then it's probably ok..
Yeah, I know... thanks :)
That screw is actually an M5 mock up of the real thing, I went out and bought the correct length M6 afterwards ;)
Peanuts is offline   Reply With Quote
Old 09-28-2012, 06:29 AM   #6585
DeeGee OP
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,767
Put firmer springs in up front, new rear brake disc fitted, road tyres fitted, new braided brake lines up front. Almost ready to roll for my Moroccan Adventure
DeeGee is offline   Reply With Quote
Times are GMT -7.   It's 05:41 PM.
