Old 11-12-2012, 06:52 PM   #6841
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 317
Nice
Originally Posted by Hobbes950 View Post
Fabricated some options.
Dirt
Tarmac
I like that! It looks like you are using a cut down windshield as well. In the "tarmac " position is it the same height as stock?
"The Road goes on Forever and the Party Never Ends" REK
StevefrmGV is offline   Reply With Quote
Old 11-12-2012, 08:16 PM   #6842
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 1,711
Yes it is the same height. There is a little more room, I could raise it higher, but I have no issues with the stock shield. Been thinking of doing this for a while. Last ride in the silt I hit the windshield when we had a little nappy time. Figured it wouldn't hurt to go ahead and do it. Picked up a used shield cheap so I had a party with the hackzall.
You can also see my new lights. I have a Hella driving light and a PIAA fog light mounted under the headlight. They are attached to the forks, sitting just above the high fender and turn with the steering. Now I can see and really be seen!
When in doubt, take it as a compliment.
Lost Coast ride report
Nevada Desert ride report
Campoaventura
Hobbes950 is offline   Reply With Quote
Old 11-12-2012, 09:10 PM   #6843
Qwik
Two Wheeled Addict
Oddometer: 5,231
Originally Posted by FakeName View Post
Removed footpeg rubbers.
Originally Posted by Bonsai Elephant View Post
Keep the footpeg rubbers in place and take the whole damn things off and fit Fastway pegs instead.
Really gives a nice level of stability when standing.
That or Buy the Extensions CJDesignsLLC makes (He is a member and contributor here after all) I have them on Mine and Love em.
Speed bumps never seem to make me go any faster
Qwik is online now   Reply With Quote
Old 11-14-2012, 06:42 AM   #6844
GreatWhiteHunter
Lovin' Life!
GreatWhiteHunter's Avatar
Oddometer: 327
Send a message via Skype™ to GreatWhiteHunter
2010 530 xc-w
I brought my newest KTM home...
* 2006 Suzuki DL1000K6 V-Strom (the fast, red one)
* 2010 KTM 530 XC-W Sixdays
* 2009 KTM 300 XC
* 2010 Ski-Doo MXZ 600 X-RS
GreatWhiteHunter is offline   Reply With Quote
Old 11-14-2012, 07:45 AM   #6845
dualsportride
Oddometer: 211
Very nice bike did you lay it over in the parking lot to just get that out of the way, or are you like me and ride slower until you go down for that first time then hop on it and take off and ride the heck out of it?
dualsportride is offline   Reply With Quote
Old 11-14-2012, 03:44 PM   #6846
GreatWhiteHunter
Lovin' Life!
Oddometer: 327
Honestly I've only putted around the house. It has 245 miles on it and there was a little damage to the left grip, guard and clutch lever when I took ownership on Tuesday. Other than that it's brand new. I'm sure I'll get the chance to thrash it in the week or two coming up.
For now, I'm just going over it with a fine tooth comb in the garage. I've found several loose electrical connections and fasteners and I've only just started. Once that's done, yee haw.
* 2009 KTM 300 XC
Old 11-14-2012, 04:04 PM   #6847
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,158
990:
Installed Midwest Mountain Engineering shorty clutch lever.
Removed security screws from filler necks.
525:
Removed clutch cover, remove, clean, loctite and retorque that stupid left-hand thread nut that keeps coming loose and making the KTM death rattle.
2011 White 990 Adv R
2003 565exc
FakeName is offline   Reply With Quote
Old 11-14-2012, 05:01 PM   #6848
duckboy810
duckboy810's Avatar
Oddometer: 125
Over the past couple of months I have done some mods:
Tire
This past weekend put on a new mefo super explorer rear, spooned on with a pair of stubby tire tools absolutely great product made of hard plastic virtually impossible to scratch your rim but had to use a slimmer metal iron to get the last bit of bead over the rim. **used side stand to break the bead
Got about 5k out of the scorpion 80% slab (i know i would have rather been on single track trust me)
Exhaust
First mod a couple months ago was the MIVV carbon exhaust love them they sound awesome got them through PJ's parts out of TN awesome guys and service..**remember to loctite exhaust hardware
Headlight
Ordered euro headlight ass. and switch along with dual HID 55w. Absolutely impressed with light output! If you want more light get this done! Got the HID through DMM tuning because i was able to select different temperature bulbs on the same order. I got the 4300k for low beam (basically matches the white front fender) and 3000k (yellow) for high. Some guys stuff all the wire behind in the housing but i shrinked it nicely and put it outside which worked well. Place the ballasts about the only place theyd fit one on the bottom of the fairing frame and one mounted to the inside of the right fairing with no problems. Euro switch was plug and play hardest part was running the harness through, i ran the new one through first to follow the old path exactly then pulled the old one out re ziptied everything.
Winter plans:
Aux power fed up top for heated gear/gps
Oil/Fuel Pressure gauge
Weld86 skid plate
clean up the tail if i can decide on a tail light
water pump shaft and seal (flush coolant system)
duckboy810 is offline   Reply With Quote
Old 11-14-2012, 05:10 PM   #6849
ian408
More wag; less bark
ian408's Avatar
Oddometer: 11,800
Installed a new heat shield from Trailjammer Designs.
Cuts down on the heat coming from the pipe-so far so good!
ian408 is offline   Reply With Quote
Old 11-14-2012, 05:13 PM   #6850
rossguzzi
Oddometer: 240
990:
525:
Where exactly is the left hand nut ?
I would like to check mine just in case.
Some say I am always checking my nutz
rossguzzi is offline   Reply With Quote
Old 11-15-2012, 09:04 AM   #6851
75monza
75monza's Avatar
Oddometer: 238
Send a message via AIM to 75monza Send a message via MSN to 75monza Send a message via Yahoo to 75monza
990:
Got any pictures of this? Is it a true shorty lever? Can you get a matching shorty brake lever?
I have looked at other options, but I really want a shorty.
2006 KTM 950 Adventure - Go Everywhere Bike
1993 Suzuki GSX1100G - Street Touring Shafty
75monza is offline   Reply With Quote
Old 11-15-2012, 10:32 AM   #6852
FakeName
FakeName's Avatar
Oddometer: 1,158
Funny you should ask- I know it looks like a pro shot- it is, I shot it for fun because I think the images on the website could use some help.
Yes, it is a true 2/3 finger shorty lever, yes, it's very smooth to use, yes, it fits perfectly, and yes, it's everything I was seeking. No, a matching brake lever is not yet offered, but PLEASE email the company and ask for one. If they get enough requests, they'll make them.
2003 565exc
FakeName screwed with this post 11-15-2012 at 10:37 AM
Old 11-15-2012, 09:44 PM   #6853
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,574
Came one step closer to a 2006 950 today...
high time you got active back on the OC
@ duckboy : neat and clean HID install
'07 KTM Adv990S
No myriad hues of laser lights no bottles that are oozing with nectars from heaven, no beautiful body soft and warm to the touch but, i have a very small desire.. Give me a dark.. long.. winding road, three gears to go and my Hellas on fire..
950Rally picture thread
Vicks is offline   Reply With Quote
Old 11-16-2012, 04:39 PM   #6854
lukeinlondon
Oddometer: 455
ordered a front Excel wheel
..another time and money consuming project begins!!!!
lukeinlondon is offline   Reply With Quote
Old 11-17-2012, 03:12 AM   #6855
Peanuts
Peanuts's Avatar
Oddometer: 1,030
Its on the end of the crank. You need to take it off, clean the threads with brake cleaner, dry it, then apply red loctite and torque it to 150Nm which is pretty much as tight as you can go with a 18" knuckle bar.
Lock the gears together with a couple of pennies stacked on each other then inserted into the teeth of the gears.
Peanuts is offline   Reply With Quote
Times are GMT -7.   It's 11:53 AM.
