Old 12-18-2012, 04:56 AM   #6961
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,194
Originally Posted by Patrol View Post
...I was all proud of myself for learning to change my own oil til I read this. Sheesh
You should be proud.
That is the first major accomplishment of maintenance on a KTM Adventure.
The journey begins...
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger"
My2Wheels
dad2bike is offline   Reply With Quote
Old 12-18-2012, 05:32 AM   #6962
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,491
Originally Posted by DesertSurfer View Post
I don't know what's more amazing... your bike's transformation over the last few years... Your patience in the process... Or your ability to summorize it all in the "What Did".
Yours is always a great inspirational "live vicariously thru" thread.
Through it all... do you feel like your bike has transformed permanently into a slab grabber, with the hp curves, exhaust flow, torque curve, suspension and wheelset? If so, was there a point of no returning to a dual sport bike. Or does it easily retain it's off roading character with a few swapouts and adjustments?
Thanks for the R&D.
Hi Surfer! Thanks.
It's funny, Gino and I were just talking about that last night. We're both itching for another big trip and Alaska is the only state I've not ridden to and I live in Portland - the perfect starting point and the perfect bike for the trip.
For sure my bike will still be ridden in the dirt. Honestly, one of the big reasons I wanted to move to Portland over back to Colorado was that I think the riding is more diverse and I'd not ridden that part of the country. Oregon was made for the 990 with the big wheels and I suspect that when the bike makes it back there it will wear the big wheels at least half or more of the time. The torque now means I'll never need to run the 16 counter shaft sprocket again - in fact keeping the taller gearing will probably be helpful. It's a fast swap as both wheels have rotors - 15min tops.
Also, I don't have the same desire to do the really stupid epic single track stuff I used to do with it. I did it. It's hard to pick up. I don't need to do it anymore. I will for sure be using it to explore logging roads and double track all over next summer. I'll certainly ride it down to Steamboat with the big wheels. Does it have too much torque to ride off road? Meh. It had too much when it was stock. I think it will be fine depending on my ability to control myself but I do think my knobby life will get shorter! I used to love spinning knobbies up on pavement and that's only going to be easier.
Patrol - 25 years ago I started with changing the oil on my old boxer. Little by little I kept learning. The wrenching and building is for me as much part of my passion for bikes as the riding. I think that's why I'd hate California - winter is the time to take them apart and make stuff.
Gregor
sakurama is offline   Reply With Quote
Old 12-18-2012, 07:40 AM   #6963
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,577
Getting to know my new (to me) 990. 200 miles after purchase, time for tear down to perform the cannisterectomy (and whatever else comes to mind).
I spent so much time on the KTM sites reading about the cannisterectomy, that I was able to do it from memory
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 12-18-2012, 10:44 AM   #6964
superhak31
superhak31's Avatar
Oddometer: 91
Wink LEDs
Originally Posted by SCflyer View Post
Good info. Why the need for a relay? Always read a resistor may be needed due to the difference in power requirement but that was on other bikes.
Do the Rizmo signals light up on the back side? Look like they're clear and seem like it would be annoying at nite, esp. with LED brightness. (Checked the site - so how bad is the rear flashing from the front signals?
Are they plug and play or do you have to change the end connections? (Did they have a connector for their wiring kit that worked for the OEM connector?)
What color inserts did you get for the rear? All white since the cover is red or red LED as well?
How flexible are they in case of a fall----I mean when I fall
So I used a relay for LEDs, it eliminates the use of resistors. The rizoma s came with all the necessary resistors though.
Yes, they are visible from the back and sides. But I can't see them while in the normal seated position. The 950 fairing hides them from my line of sight. And they are half the length of OE indicators. They are more flexible than OE also.
I had to splice and dice them in. I used waterproof 16-18 gauge bullet connectors (female) as the indicators come with male bullet connectors. The rear ones are bit of a pain due to the taillight wiring cluster.
Tight fit. Got the bullet connectors @ pep boys. I wrapped every connection with "rescue tape" self fusing silicone tape.
Got it at OSH hardware store and amazon carries it. Good stuff.
And I used red LEDs for the taillight bulbs. Recommended for red lenses.
Taillight is super bright!
superhak31 is offline   Reply With Quote
Old 12-18-2012, 08:30 PM   #6965
lukeinlondon
lukeinlondon's Avatar
Oddometer: 437
Originally Posted by patrol View Post
...i was all proud of myself for learning to change my own oil til i read this. Sheesh
ha
lukeinlondon is offline   Reply With Quote
Old 12-21-2012, 06:29 PM   #6966
propilot10
Oddometer: 121
Put a new battery in and started her up. Listening to it idle now. Love the freaking sound of this thing! 3 eels has been way too long.
propilot10 is offline   Reply With Quote
Old 12-22-2012, 09:31 AM   #6967
guns&coffee
Gnarly!
guns&coffee's Avatar
Oddometer: 1,258
Rear Sprocket Upgrade
Completed install of 50 tooth rear sprocket. Now running 16/50. 2000rpm = 10mph. Used a 120 link chain. Adjuster are almost bottomed out. The Beastie lofts the front wheel rather nicely now.
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '75 Husky 360WR/CR,
guns&coffee is offline   Reply With Quote
Old 12-22-2012, 12:44 PM   #6968
75monza
75monza's Avatar
Oddometer: 354
End of the World mail run
It was a nice day so I thought I would go and get the mail today with the KTM. It is about a 1/4 of a mile down the street. It took me over 50 miles to get there.
I was instructed to keep it short.
It was a good day, roads were fairly empty of people. I got a nice good coating of grim on the 950. Of course I had to go down the one road with Ice on it... The bike slid farther than I did. I guess the crash bars still work.
2006 KTM 950 Adventure - Go Everywhere Bike
1993 Suzuki GSX1100G - Street Touring Shafty
2000 Suzuki DR200 - A Little Smaller
75monza is offline   Reply With Quote
Old 12-22-2012, 02:59 PM   #6969
EZ300
EZ300's Avatar
Oddometer: 1,166
Wicked
Took it out an acted like a hooligan.
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 12-22-2012, 05:20 PM   #6970
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,075
Laugh Took Delivery Of Her .... F i n a l l y
She finally arrived, got within two miles of where we are staying and the truck shat itself, we had to chase her back ver to the other side of Phoenix 40 miles away to get her but we won.
In the trailer
Gettin freed
On our way
Bit of cheek off dancing ... she is tall and I am a hobbit
Tomorrow we wash her down, change a few bits and pieces and we are one step closer to resuming our trip
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 12-22-2012, 05:49 PM   #6971
guns&coffee
Gnarly!
Oddometer: 1,258
Sweeeeet!
Congrats Andi!
Old 12-25-2012, 04:45 PM   #6972
KTMSAM
KTMSAM's Avatar
Oddometer: 124
tis the season for farkles
installed the KTM frame protectors, fit great and look nice too
[IMG]Uploaded from the Photobucket iPhone App[/IMG]
"KTM? Who makes that?"
KTMSAM is offline   Reply With Quote
Old 12-26-2012, 03:26 PM   #6973
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
^^^ Still got those nifty footpeg risers?
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 12-26-2012, 03:53 PM   #6974
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,446
first thing that went bye-bye on my bike.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 12-26-2012, 04:31 PM   #6975
KTMSAM
KTMSAM's Avatar
Oddometer: 124
I'm guilty, I have only ridden 150 miles on it so far, but I will certainly be taking them off in the spring
Times are GMT -7.   It's 05:34 PM.
