Old 03-04-2013, 07:58 PM   #7426
GrenDesb
Oddometer: 328
Originally Posted by Orangecicle View Post
Sad so sad to see a KTM in this condition.
But, that's what ya gotta do to:
  • Service the rear shock,
  • Service the swing arm,
GrenDesb is offline   Reply With Quote
Old 03-04-2013, 08:08 PM   #7427
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 2,898
Originally Posted by GrenDesb View Post
I know. The rear is getting done once the forks are finished. Right now the rear and a rope are keeping everything stable. I like to focus on one end of the bike at a time. Rushing suspension repairs can really jack with your day, ya know?
Orangecicle screwed with this post 03-04-2013 at 08:46 PM
Orangecicle is online now   Reply With Quote
Old 03-04-2013, 09:33 PM   #7428
midfat
wholesome dirtiness
midfat's Avatar
Location: Socal, between the mountains, desert and ocean
Oddometer: 208
Originally Posted by Arzach View Post
No skiing today , perfect time to install the steering damper I got few days back .
Nothing special I guess but this is something I wanted on my 950 for a while now .(it still will Not make me a better rider , nothing can cure that : )
ready for a quick ride
The 450 will probably be next .
I installed the Scotts Damper on my 950SE last year. It was like magic. The bike was instantly tamed down on the freeway. The dreaded head shake all but vanished. Well, up until about 120 anyway, but on knobs I figure that's probably about time to stop twisting anyway. Awesome product.
midfat is offline   Reply With Quote
Old 03-05-2013, 09:01 PM   #7429
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
Originally Posted by EZ300 View Post
Been running 16/45 for a little over a year now. Love the grunt off the line but this trip will be higher speed. Planning on running 17/45.
At the risk of starting an accidental math war, I had understood that reducing the front countershaft sprocket by one tooth was akin to adding three teeth to the rear sprocket (rounded up to the next whole number). If that was the case, wouldn't running a 17/45 be the same as running a 16/42?
If so, that would be back to stock (at least on the 2010 990) and would likely reduce potential axle spacer issues (or chain length issues).
Just a thought. I assume the idea was that it'd be cheaper to just buy a larger countershaft sprocket to work with the existing 45 rear. But if you are one to replace them both at the same time, stock gearing might be easier on the chain.
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 03-05-2013, 09:39 PM   #7430
Qwik
Adrenaline Addict
Oddometer: 6,824
one tooth up front is 2.87 in the rear But going smaller of both just means less chain length/weight and more wear on the chain (Tighter radius means more wear) Oh, and i took it for a nice ride. Sunnyvale to Stevenscreek Reservoir to 9 to Skyline, Down into woodside then onto 280 up to 92, to 101 and up to Scuderia. Then back down 101 to Sunnyvale. Some of the cagers on 101 or stupid. Had one clown that decided he wasnt going to allow me to split in 10MPH traffic. Driver next to him saw what was going on and waved me through. I did adjust A Hole's Mirror for him as I went by. It was obviously out of whack.
Topes never seem to make me go any faster.
Qwik screwed with this post 03-05-2013 at 10:53 PM
Qwik is online now   Reply With Quote
Old 03-05-2013, 11:38 PM   #7431
Gil.caz
Oddometer: 24
Wasn't today, but I took it up to Santa Cruz and back to corona CA over the weekend. Trying to wear out the stock tires so I can get a more dirt worthy set.
Gil.caz is offline   Reply With Quote
Old 03-06-2013, 03:52 AM   #7432
The Bigfella
Big Adventurer
The Bigfella's Avatar
Oddometer: 2,484
Fitted new sprockets today to the SE. 16 45. Had run 16 48 through Asia, but I got the bike back from there this week.
Was about to fit the new chain, but the chain adjuster on the end of the axle fell off in two parts... had been broken for quite a while by the look of it. Glad it happened at home, not up near the Laos border where I last had the axle out.
Found the sight glass window on the rear master cylinder had popped out. Tapped it back in and bled the brakes. Seems to be retaining the fluid.
New battery was needed too. My Lithium Ion battery shit itself last August over on the Burma border and I threw in the only battery I could get. It didn't survive the three months shipping process (disconnected). Wouldn't take a charge.
A man should only do the work that is required of him. To do more is a form of greed.
Ride through Oz and Asia
The Bigfella is offline   Reply With Quote
Old 03-06-2013, 06:14 AM   #7433
Chinookmark
Oddometer: 272
You're correct that 17/45 (2.65:1) is roughly the same as 16/42 (2.63:1). But I believe EZ300 is basing his change on the 45t rear sprocket, using 16/45 for acceleration, and 17/45 for highway cruising. I'm pretty sure the stock chain is long enough for 17/45.
Chinookmark is offline   Reply With Quote
Old 03-06-2013, 08:10 AM   #7434
Qwik
Adrenaline Addict
Oddometer: 6,824
CJDesigns sells a billet a axle block set. Well worth the investment.
Old 03-06-2013, 10:55 AM   #7435
chrish4ku
chrish4ku's Avatar
Oddometer: 846
+1 CJ designs sells a solution for global warming too. He's that good.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 03-06-2013, 04:12 PM   #7436
The Bigfella
Big Adventurer
Oddometer: 2,484
Agreed... I've got some of his gear already. His solution would have been cheaper and better than the standard KTM Australia rip-off, but I need to get the bike back on the road for a ride this weekend... so KTM are winging an axle to me supposedly by tomorrow.
Old 03-06-2013, 07:18 PM   #7437
chrish4ku
chrish4ku's Avatar
Oddometer: 846
Wow - Australia is a hell of a long way away...
Damn spell check ehhh
Chris
Chris' Sat Tracker
Old 03-07-2013, 03:52 PM   #7438
EZ300
EZ300's Avatar
Oddometer: 1,112
Yeah,... 17/45 just lowers the RPM' s on the highway.
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 03-07-2013, 04:02 PM   #7439
zedtours
zedtours's Avatar
Oddometer: 366
Correct but you need to turn rear spacer block 180 deg
zedtours is offline   Reply With Quote
Old 03-07-2013, 04:42 PM   #7440
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,810
Not compared to stock. Im sure you meant compared to the lower gearing. I still have stock gearing and have about 11k miles. It's tough off road but I have zero complaints on road, the bike's too fast on the top end if anything. I can't wait to try a 16 or 17 / 45 setup.
I just want to say, bone stock, the bike is awesome. I clutch up second gear wheelies easily. I don't have to balls to try 3rd gear yet, but I'm sure it would go up. What a bike.
Here's a recent picture of her.
akarob is offline   Reply With Quote
Times are GMT -7.   It's 08:15 PM.
