Old 03-11-2013, 04:29 AM   #7471
JJLalas
Oddometer: 43
I just bought a 2006 KTM 990 Adventure with 28.000 km and first thing I did when I got her home was a basic check on the fluids, brakes, suspension setting and so on.
I found the hydraulic clutch oil to be very low and nasty, so I proceed with a refill and bleeding process. It was my first one since I'm used to good ol' cable clutch motorcycles.
Since I did not have a syringe at hand I poured ATF Dexron IID pink fluid into the master cylinder and pumped it down to the bleeding bolt on the slave cylinder, until it came out bright pink and bubble free.
JJLalas is online now   Reply With Quote
Old 03-11-2013, 06:55 AM   #7472
Marc Lenssen
Marc Lenssen's Avatar
Oddometer: 17
Hello JJ,
The slave cylinder of the clutches start to leak at an early age, the fact that the reservoir is empty might indicate you are loosing clutch fluid already. If the slave cylinder is still origina you might consider a decent replacement. This clutch system does not respond well to synthetic fluids, the fluids must be mineral, not sure if the dextron atf is mineral, if not I would get some mineral fluid (or even the original but expensive Maguar Blood) and redo the exercise.
Have fun!!! Although that is almost a given on the big KTM :-)
Marc
From Superduke to 950 Adventure... YES!!!!
Marc Lenssen is offline   Reply With Quote
Old 03-11-2013, 08:05 AM   #7473
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 582
Marc
That's right. As you are in Spain, I expect you'll be able to find the bright green LHM+ (Liquid Hydraulic Mineral) fluid for Citroen car suspension (normally you can get it at the supermarket or fuel stations). It's ideal.
Note what's written on the bellows in your master cylinder:
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 03-11-2013, 09:59 AM   #7474
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,430
Hello JJ,
Marc
ATF is not mineral oil compatible. It has additives to make seals swell. You'll also notice that ATF will cause your latex gloves to swell and fall apart.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 03-11-2013, 02:43 PM   #7475
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Interesting. I've been running synthetic ATF per cjracers recommendation for about 3k miles with no issues.
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 03-11-2013, 04:21 PM   #7476
guns&coffee
Gnarly!
guns&coffee's Avatar
Oddometer: 1,235
Bar Snake
Installed a bar snake on my 300 EXC. Lots of dish soap. It was a little tricky with having hand-guards, but it worked out OK. Probably test it out in a day or so. 100% chance of rain tomorrow.
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '75 Husky 360WR/CR,
guns&coffee is offline   Reply With Quote
Old 03-11-2013, 09:26 PM   #7477
Katoom72
Katoom72's Avatar
Oddometer: 886
i have been using ATF or forkoil since my first KTM and i never had to replace or rebuild either the master or slave. Always worked fine.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 03-11-2013, 10:57 PM   #7478
chrish4ku
chrish4ku's Avatar
Oddometer: 836
Originally Posted by Qwik View Post
one tooth up front is 2.87 in the rear But going smaller of both just means less chain length/weight and more wear on the chain (Tighter radius means more wear) Oh, and i took it for a nice ride. Sunnyvale to Stevenscreek Reservoir to 9 to Skyline, Down into woodside then onto 280 up to 92, to 101 and up to Scuderia. Then back down 101 to Sunnyvale. Some of the cagers on 101 or stupid. Had one clown that decided he wasnt going to allow me to split in 10MPH traffic. Driver next to him saw what was going on and waved me through. I did adjust A Hole's Mirror for him as I went by. It was obviously out of whack.
Funny, but it seems to be pretty rare that I get the guys trying to squeeze. Maybe like once or twice a year and usually on 880 or 101. Just another reason to have metal handguards. Usually the thud of the mirror is a shocker for the driver. Begs the question -
If someone squeezes you and you collide with them, is it your fault? I can see some dorkwad filing a report for a broken mirror.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 03-11-2013, 11:09 PM   #7479
Qwik
Adrenaline Addict
Oddometer: 6,742
Yes it is your fault.
Topes never seem to make me go any faster.
Qwik is online now   Reply With Quote
Old 03-12-2013, 02:43 AM   #7480
jimmibanke
jimmibanke's Avatar
Oddometer: 102
New chain kit 16-45 the bike feels like a funky fresh stalion now
And did a Oil change, nothing to see on any filters so thats fine.
My oil jet was blocked again, who of you have fix't this problem for good? What have you done?
I Know you can drill it up to 0,5 mm, but is there any other solutions?
jimmibanke is offline   Reply With Quote
Old 03-12-2013, 02:55 AM   #7481
Peanuts
Peanuts's Avatar
Oddometer: 1,642
Me too.
It's brake fluid that must not be used on Magura systems that say mineral oil on the lid.
Peanuts is offline   Reply With Quote
Old 03-12-2013, 02:58 PM   #7482
deepsea rider
deepsea rider's Avatar
Oddometer: 76
Got her home from the dealer and promptly ran her up this hill, I have a 530 EXC and need to see how she handled in the dirt. I know this is not what the thread is about, but its what I did to my KTM today!!
2008 KLX 450r
2002 XR650R
2010 KTM 530 EXC CE
2012 KTM 990 ADV
Ride hard, eat good and Drink tequila.
deepsea rider is offline   Reply With Quote
Old 03-12-2013, 03:41 PM   #7483
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 702
Edited - completely unnecessary comment - sorry
HeatXfer screwed with this post 03-12-2013 at 10:30 PM
HeatXfer is offline   Reply With Quote
Old 03-13-2013, 05:47 PM   #7484
go2cnavy
go2cnavy's Avatar
Oddometer: 526
New Renazco
Installed the new Renazco. What a difference.
Before and after.
go2cnavy is offline   Reply With Quote
Old 03-13-2013, 07:02 PM   #7485
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,031
Treated it to a day out... at the DMV...
... And when I say, "day", I mean it (you know how that goes!)...
Weeks of red tape and sitting around on municipal chairs [when I already had a UK bike license] just to do five figures of 8 in a suburban parking lot.
I shit you not!
To be fair, it's gotta be the first time they've ever had a 'n00b' roll up on a 12-foot tall KATOOM! and I'm pretty sure the 'test' called for a few more maneuvers than were performed. But the examiner [who looked like she'd never even been on a bike, let alone ridden one] figured I either knew what I was doing, or was utterly insane.
Gotta love Louisiana!
Anyway... Fully legit now, so onwards and upwards!
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike screwed with this post 03-13-2013 at 08:53 PM
amanlikemike is offline   Reply With Quote
Times are GMT -7.   It's 10:07 AM.
