Old 03-20-2013, 11:23 AM   #7531
OlivierS
Oddometer: 98
Changed the brakepads, by the looks of it, it was about time
OlivierS is offline   Reply With Quote
Old 03-20-2013, 02:13 PM   #7532
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,731
On the 1190 Adv it would go into limp mode if less than 2mm of pad, then if the pads are not changed and the ECU reset (using the KTM authorised PC hardwired to the KTM international dealernet database) within 200 miles it will apply the immobiliser and service crew auto callout via GSM/GPRS/GPS.
Honest ;)
Peanuts is offline   Reply With Quote
Old 03-20-2013, 04:36 PM   #7533
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,280
Honest ;)
Oh, I don't like where this is going.
Orangecicle is offline   Reply With Quote
Old 03-20-2013, 05:08 PM   #7534
Orangecicle
On a "Quest"
Oddometer: 3,280
Brought it back to life today:
Orangecicle screwed with this post 03-20-2013 at 05:23 PM
Old 03-20-2013, 05:17 PM   #7535
Bgunn
Mucha distancia
Bgunn's Avatar
Oddometer: 1,440
Your first day of spring was about like ours... cold
Bgunn is offline   Reply With Quote
Old 03-20-2013, 05:28 PM   #7536
Orangecicle
On a "Quest"
Oddometer: 3,280
No sheisse! It was 14.5F this morning when I left for work. And no, I did not ride to work.
Old 03-20-2013, 08:48 PM   #7537
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Originally Posted by mookymoo View Post
If you have a slow coolant leak, you wont see any milkshake.
Theres an old thread I posted about 2-3 years ago - I had a slow coolant leak (undetected because the rad cap had also failed to do its job so the reservoir tank was still full) - and there was no evidence of emulsion in the oil.
However, the oil filter was eeever-so-slightly wavey - like the one pictured - and I wondered the same thing at the time. In my limited observation, healthy oil filters tend to be straight-as-a-die.
Always check your actual radiator fluid level - dont just rely on the reservoir level.
Hmm...learn something new every day...
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 03-21-2013, 06:04 AM   #7538
OlivierS
Oddometer: 98
Honest ;)
You are kidding right, so even if you change them yourself you have to go past a dealer to reset the computer? No way of doing that at home? I know you can do that yourself on a bmw car for instance...
Old 03-21-2013, 08:25 AM   #7539
Orangecicle
On a "Quest"
Oddometer: 3,280
Rode it!!!
Old 03-21-2013, 09:42 AM   #7540
HooliKen
Awesome is a flavor
HooliKen's Avatar
Oddometer: 3,018
Originally Posted by laramie LC4 View Post
speaking of the devil...
on another note,
what do you you think of this filter? please tell me im being paranoid and those waves are nothing to be concerned about.
2012 990R with 2,600 miles. oil changed at 500 and current.
laramie
It's possible but it would be strange to have it only in that area. They will usually look more like this or worse.
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell
950R Super Enduro - 450EXC - Gas Gas TXT 280 - 2000 Honda XR100R - 1988 Honda Z50R
HooliKen is online now   Reply With Quote
Old 03-21-2013, 01:46 PM   #7541
Katoom72
Katoom72's Avatar
Oddometer: 915
My brand new filter was not straight-as-a-die when i put it in.
Done today:
Valves on the front cilinder. Ofcourse i had to strip one of the nuts.
https://dl.dropbox.com/u/103697227/I...320_154706.jpg
Cleaned carbs and put new ACV valves in.
Build airbox and carbs back on the engine (if god did not know me, he knows me now)
Put a new Renthal KTM High bend on her, waaaay better then the horrible stock bars. Perfect for my long arms.
All i have to do now is rebuild brakes, give the chain some love, grease the wheelbearings and check the wheels themselfs and button everything back up. Praying for some sunny weather next week. Might go explore some German roads and woods if i'm blessed with good weather.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 screwed with this post 03-22-2013 at 03:33 PM
Katoom72 is offline   Reply With Quote
Old 03-22-2013, 09:06 PM   #7542
offworlder
Oddometer: 256
New 908 rear
Swapped a Heidenau K60 (150) rear for a fresh Dunlop 908 (140), in anticipation of the wet.
Cleaned and greased the bearings, axles, etc...
Got over 7K from the Heidi, and there was still enough rubber left to likely get another 1K+.
offworlder is offline   Reply With Quote
Old 03-23-2013, 04:49 PM   #7543
keener
Speed changes you.
keener's Avatar
Oddometer: 1,012
Originally Posted by BykBoy View Post
I don't think you need a magnet with the hose. The magnet is not powerful enough to pull metal fragments from the tank. The metal fragments are heavy and they sink to the bottom of the tank. The magnet simply holds these fragments that sink on top of it because the plug is att the bottom of the oil tank.
Any metal parts that sink/fall into the hose (because it is in the bottom of the tank) will be trapped at the bottom of the hose. This is the same as being trapped on the magnet. There is no way for heavy metal fragments to float back up the hose. The fragments will be extracted from the tank when the hose is opened and drained.
Of course, you won't be able to see the shards when you drain the hose, unless you rummage through the drained oil...
With all respect I completely disagree.
Oil gets sucked by the oil pump from the bottom on the tank. Very fine steel debris that can pass the filter, are caught only by the magnets. They don't just fall into button of the hose!
This is particularly important for new engines.
04 ADV 950
keener is offline   Reply With Quote
Old 03-23-2013, 06:07 PM   #7544
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,865
Heated grips.
It's been cold here. Sometimes less even than 50 on the really really cold mornings.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 03-23-2013, 06:33 PM   #7545
ERG
Oddometer: 17
Adjusted valves, new throttle cables.
Bought used at 25Kmi, ran like a champ.
At 42Kmi i figured why not....Intakes were still good, exhaust needed some love.
All shims were the same size.....no adjustment in 40,000 mi and it still ran pretty damn well, but holy shit, what a difference!!!
ERG is offline   Reply With Quote
Times are GMT -7.   It's 10:24 AM.
