Old 03-23-2013, 05:49 PM   #7561
keener
Speed changes you.
keener's Avatar
Oddometer: 925
Originally Posted by BykBoy View Post
I don't think you need a magnet with the hose. The magnet is not powerful enough to pull metal fragments from the tank. The metal fragments are heavy and they sink to the bottom of the tank. The magnet simply holds these fragments that sink on top of it because the plug is att the bottom of the oil tank.
Any metal parts that sink/fall into the hose (because it is in the bottom of the tank) will be trapped at the bottom of the hose. This is the same as being trapped on the magnet. There is no way for heavy metal fragments to float back up the hose. The fragments will be extracted from the tank when the hose is opened and drained.
Of course, you won't be able to see the shards when you drain the hose, unless you rummage through the drained oil...
With all respect I completely disagree.
Oil gets sucked by the oil pump from the bottom on the tank. Very fine steel debris that can pass the filter, are caught only by the magnets. They don't just fall into button of the hose!
This is particularly important for new engines.
04 ADV 950
keener is offline   Reply With Quote
Old 03-23-2013, 07:07 PM   #7562
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,780
Heated grips.
It's been cold here. Sometimes less even than 50 on the really really cold mornings.
2011 White 990 Adv S
2014 500EXC Black
FakeName is online now   Reply With Quote
Old 03-23-2013, 07:33 PM   #7563
ERG
Oddometer: 17
Adjusted valves, new throttle cables.
Bought used at 25Kmi, ran like a champ.
At 42Kmi i figured why not....Intakes were still good, exhaust needed some love.
All shims were the same size.....no adjustment in 40,000 mi and it still ran pretty damn well, but holy shit, what a difference!!!
ERG is offline   Reply With Quote
Old 03-23-2013, 07:48 PM   #7564
zgfiredude
Oddometer: 823
Originally Posted by FakeName View Post
Heated grips.
I test rode mine when I bought it a couple of months ago at 14 degrees! And yes the heated grips were nice!!
'06 950S Adv, DRZ440E, KLX440R, DRZ250, & F650GS
zgfiredude is offline   Reply With Quote
Old 03-23-2013, 08:07 PM   #7565
graveltooth
gt
graveltooth's Avatar
Oddometer: 19
Wings!
installed a new (black) front fender and bolted up a set of Wings. Charging the battery now so hopefully I can take a listen before lights out...
2006 KTM 640 Adventure
2010 KTM 990R Adventure
graveltooth is offline   Reply With Quote
Old 03-23-2013, 09:32 PM   #7566
chrish4ku
chrish4ku's Avatar
Oddometer: 769
Dropped the 990 off at........
Photo & Video Sharing by SmugMug
Get back my white R model Tuesday!!!
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 03-23-2013, 11:30 PM   #7567
srad600
srad600's Avatar
Oddometer: 650
Eek
I finished up the K300a service...man, that was not fun. 18,900 miles in the books so far.
  • Change oil, and filters.
  • Replace air filter. Ordered a K&N but who knows when that'll arrive.
  • Remove and replace coolant.
  • Check and adjust valves. (Why is it I always end up making two runs to the shop for valve shims... No matter how carefully I measure...bummer. I'm investing in a shim kit next time.
  • Replaced the spark plugs. (these things are like gold....hard to find and $$$$)
  • Installed the Uni-pre filter
  • Installed the RC8 intake trumpets (just had to try it).
  • Decided to leave the SAS & Canister in place for now. I want to judge my fuel economy with one change at a time (or at least a few small changes...)
  • Installed a new chain and sprockets. Went with stock 16t front, and upsized to the 45t stealth rear. Feels good so far.
  • Chased the threads on the engine hanger that my crash bars mount to, and installed some longer set screws.
  • Checked various nuts/bolts/bearings/etc.
Not bad for 9mths of riding. I did learn that performing a major service on a motorcycle should not be attempted while sick...just makes everything take that much longer.
srad600 is offline   Reply With Quote
Old 03-24-2013, 09:38 AM   #7568
SikDMAX
Oddometer: 719
New Slick, completely cleaned the swingarm, axle, eccentric axle adjusters, sprocket and carrier, chain, rotor, caliper, new Galfer pads, new brake fluid and filled the tire with Nitrogen LOL. Onto the front for today.
Matt - SikMoto www.Facebook.com/SikMoto San Luis Obispo, CA
SikDMAX is offline   Reply With Quote
Old 03-24-2013, 09:46 AM   #7569
dmn0507
dmn0507's Avatar
Oddometer: 351
Is that a greek tyre?
dmn0507 is offline   Reply With Quote
Old 03-24-2013, 03:45 PM   #7570
enduroprofi
TR Adventurer
enduroprofi's Avatar
Oddometer: 14
I have installed Rallemoto RM2 SD Steering Damper
I have caught of a good equipment
enduroprofi is offline   Reply With Quote
Old 03-24-2013, 04:02 PM   #7571
Peanuts
Peanuts's Avatar
Oddometer: 1,576
Goldspeed street legal pre-cut slick.
http://www.aaa-racing.com/product.ph...&cat=87&page=1
Peanuts is offline   Reply With Quote
Old 03-25-2013, 06:34 AM   #7572
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,646
Nice looking tires.
akarob is online now   Reply With Quote
Old 03-25-2013, 11:40 AM   #7573
BrooklynOffRoader
Concrete or the Dirt.
BrooklynOffRoader's Avatar
Oddometer: 174
Went Riding
With a friend who owns a Canadian Model Honda Varadero 1000. He kept mentioning how sorry he was he didn't buy a KTM adventure and kept asking to ride mine.
04 KTM 950 ADVenture
07 KTM 450 xcw Plated
CHIP
BrooklynOffRoader is offline   Reply With Quote
Old 03-25-2013, 12:13 PM   #7574
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,403
Ordered the Heidendau K60 scout for the front. Going to give it a go after having OK results from the mefo front.
TKC front is the way to go IMO if you are a more agressive rider.
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Old 03-25-2013, 07:44 PM   #7575
Orangecicle
Orangecicle's Avatar
Oddometer: 2,473
Jenga!
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is online now   Reply With Quote
Times are GMT -7.   It's 06:34 AM.
