Old 06-05-2013, 11:07 PM   #7996
EZ300
EZ300's Avatar
Oddometer: 1,005
Preparing for my trip...
Mounted up a Heidenau K60
Put the rim sticker on
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 06-06-2013, 12:22 AM   #7997
TarmoM
TarmoM's Avatar
Oddometer: 17
Not today, but installed Montana 600 on dashboard.
https://vimeo.com/67758288
TarmoM is offline   Reply With Quote
Old 06-06-2013, 12:27 PM   #7998
Skinner
Mr.KTM
Skinner's Avatar
Oddometer: 5,707
Installed my new license plates.
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is online now   Reply With Quote
Old 06-08-2013, 08:18 PM   #7999
BykBoy
Meshuganeh
BykBoy's Avatar
Oddometer: 555
MRA X-Creen Add-On Variable Windscreen Spoiler Blade
Installed the MRA X-Creen Add-On Variable Windscreen Spoiler Blade on my Carbon Fiber windscreen.
The X-Creen is fully adjustable. The mounting arms have a pivot point at the windscreen and at the X-Creen. This allows the X-Creen to be set at infinite positions.
The X-Creen positioned high over the CF windscreen:
The X-Creen positioned in the middle:
The X-Creen positioned as low as possible:
There are two tabs that hold the adjustment arms in place. When the tabs are vertical, the X-Creen is locked in place. When they are horizontal (as seen in the photo), the X-Creen can be adjusted:
Here is the mounting bracket that connects the X-Creen to the windscreen. I drilled two holes in the CF windscreen for each arm mount. The long arms have two pivot points on the base: up and down + left and right. This allows the arms to be installed on almost any angle windscreen
View from the rider's seat with X-Creen in high position:
Technical drawing showing the arms, pivot points, locking tabs, and windscreen mounts:
Took it out for a short ride. It helps a lot with the buffeting and wind protection when set in the high position. It's probably not suitable for riding single track through the woods though. However, I can easily remove it by taking out the two screws that hold the lower (windscreen) mounting pivots.
Product looks to be well built. It is clearly designed for touring and road use. Not sure how it will hold up in rough riding. Time will tell.
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE
BykBoy screwed with this post 06-08-2013 at 08:23 PM
BykBoy is offline   Reply With Quote
Old 06-08-2013, 09:03 PM   #8000
Orangecicle
Orangecicle's Avatar
Oddometer: 2,459
Took this apart:
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is online now   Reply With Quote
Old 06-09-2013, 03:05 PM   #8001
RENCRN8
RENCRN8's Avatar
Oddometer: 253
Got it dirty....
Then washed it.....
RENCRN8 is offline   Reply With Quote
Old 06-09-2013, 03:44 PM   #8002
Goosefeather
Captain Slow
Goosefeather's Avatar
Oddometer: 857
Wondered where to go next . . .
On a trip to Central Queensland, where I tested my crash bars on a slimy causeway ( luckily only at walking pace )
Goosefeather is offline   Reply With Quote
Old 06-09-2013, 05:47 PM   #8003
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,780
Still messing with my carbs to get the damn thing running correctly. It'll be up for sale in the fall.
'06 KTM 950 Adventure S
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox
"The bouncer is a bulldog who looks like Wilfred Brimley and the password is 'diabetus'"-Stefon, SNL character
DakarNick is offline   Reply With Quote
Old 06-09-2013, 06:16 PM   #8004
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,834
Well let's see:
Tore it down
Checked the valves for the first time, ever, on anything
Replaced the air filter
Replaced the fuel filters
Chopped the kickstand for my 19/17 wheels
My ghetto-fabulous quick change extension
Padre's answer to my ghetto-fabulous quick change extension
Replaced the water pump shaft and seal
Put on CJ's peg extensions (which work great for holding the WP impeller!)
Put it back together, put a gallon of gas in the left tank...
CLACK CLACK CLACK CLACK
*heart attack/stroke/brain aneurism trifecta*
Realized the bike died because a gallon of fuel isn't enough for the fuel pump to prime in the supertanker Safari tanks
Burned 2.8 gallons of diesel in a fiery burnout going .18 miles up to the gas station and back
Put more gas in supertanker Safari tanks
Deduced that the horrible noise of death was the lack of oil on the cam chain
Went out and rode it 5 miles in 82* heat during Charlotte rush hour
Drank copious amounts of alcohol when it didn't explode
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 06-09-2013, 08:12 PM   #8005
spencergt66
Oddometer: 760
Originally Posted by smitty141 View Post
Did the "Big washer" on the kickstand trick. Weld on the bottom for a super clean look.
Made a bracket to hold my Spot Tracker. ...
Smitty
Nice bracket but when you in a position like this is a good idea to have your spot on you
It may not look too bad but this was so steep there was no way to walk or climb up if I was alone I would have been screwed
I was about 300 ft away from the bike and below the tree was all that stoped me from going for along way
spencergt66 is offline   Reply With Quote
Old 06-10-2013, 05:52 AM   #8006
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,112
First, I went out and got it dirty
Then I crashed a streetbike motorcycle Bikini Wash
Since my Son wasn't able to attend the girls sent him a special note;
1Bonehead is offline   Reply With Quote
Old 06-10-2013, 07:12 AM   #8007
smitty141
smitty141's Avatar
Oddometer: 596
If I was in a spot like that, I would not want anyone to know... :
Smitty
2011 Prudoe bay, Dalton Hwy.
2014 Inuvik, NWT. Demster Hwy. D2D, Yukon
2013 Yamaha FJR1300...2010 BMW F800GS..
1999 Yamaha YZ250.. 2008 Suzuki DRZ400SM
smitty141 is offline   Reply With Quote
Old 06-10-2013, 07:26 AM   #8008
smitty141
smitty141's Avatar
Oddometer: 596
I like this pic alot better...
Where was this bike wash at???
Smitty
Old 06-10-2013, 08:40 AM   #8009
beewill
beewill's Avatar
Oddometer: 125
Originally Posted by RENCRN8 View Post
Got it dirty....
Then washed it.....
That was a good time. We'll have to do it again soon. Did you get a chance to powerwash your Aerostich yet?
Here's the two dirty girls together, too bad it wasn't three........
2004 KTM 950 Adventure
A bore is someone who deprives you of solitude without providing you with company.
― Oscar Wilde
beewill is offline   Reply With Quote
Old 06-10-2013, 11:14 AM   #8010
trailjammer
trailjammer's Avatar
Oddometer: 366
Smitty
I know right! There's some hotties! I need to find that kind of bike wash near me. haha awesome!
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Times are GMT -7.   It's 06:08 AM.
