Old 07-19-2013, 03:14 PM   #8191
BikeLugger
BikeLugger's Avatar
Oddometer: 197
Picked it up last night, fitted the rear luggage rack then took it for a spin this evening. I'm just waiting for the top box mount after the shop forgot to add it to the box.
(that's not my house btw...)
Matt.
Save $5 with SmugMug, voucher code - mwllJmqM2Vgzo
BikeLugger is offline   Reply With Quote
Old 07-19-2013, 03:44 PM   #8192
mario848
Oddometer: 16
had shop install Akra slip ons and downloaded Akra map.
I'm very pleased with the result. sorry can not download pic.
mario848 is offline   Reply With Quote
Old 07-20-2013, 09:50 PM   #8193
2torqued
Oddometer: 16
Got the safari tank installed today. Really wasn't that bad. All holes lined up. Cant ask for more then that.
2torqued is offline   Reply With Quote
Old 07-22-2013, 08:38 PM   #8194
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,042
Originally Posted by Vicks View Post
Do that for the air box as well. Your engine will like it better. Drop in IAT guaranteed.
Ah, maaan! You had to go and show me that now, didn't ya?
Knew, I'd missed a spot!
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Old 07-22-2013, 08:53 PM   #8195
amanlikemike
Oddometer: 1,042
Originally Posted by HeatXfer View Post
Very clean job, the tanks look great! I can't see any overlap: did you work a single sheet onto the tanks or did you do it section by section, rubbing smaller pieces into place?
Section by section, mate. That stuff - while nice and thin (which, I assume, is why it's fairly spendy compared to other types) - is still a bit too stiff to go on in one hit. Plus it definitely don't shrink down under heat, like you'd need it to, in order to get a close fit.
My technique went something like this:
  • Start out OCD
  • Cover larger [easy] areas first
  • Carefully fill in the gaps with as few pieces as possible
  • Realize you're only halfway through the first tank and it's 10:30 on the night before you leave
  • Get impatient
  • Drink a beer
  • Slap the rest on.
With that particular material, what really counts is how well you clean the surface and how much attention you pay to eliminating bubbles / wrinkles and getting good edge adhesion.
I hope.
'Ave it.
BritKit LLC
Old 07-23-2013, 08:15 AM   #8196
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 413
More HP For the Ol Beast
2004 950 with 52K miles.
Just got this done this week.
- CPR Air Filter
- Remus cans (2-2)
- Mains 165/170
- PJ #45
- Needle Factory Pro 3 slot
- Air screws out 2 3/4
Evelavtion at repair shop is near sea level. I live at 3K ft
= 76HP@8KRPM rear wheel on Factory Pro EC997a Dyno
Runs like it never has before. Hang on cause the front wheel is off the ground. I am very impressed and happy with Raul's tuning skills. Give him a call at Wheelsmith Racing in San Rafael Ca.
53 Mark Dr San Rafael, CA 94903
(415) 472-4962
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV is offline   Reply With Quote
Old 07-23-2013, 08:58 AM   #8197
speedmonkey7
speedmonkey7's Avatar
Oddometer: 337
Pulled my bent-ass front wheel off my 950A to send to Woody's to build me a new A60 super everythinged rim!
Sent from my SAMSUNG-SGH-I547 using Tapatalk 2
Speedmonkey7
"Ride with caution . And be thankful cagers are slightly more predictable than marsupials."
-XRman (fellow inmate)
speedmonkey7 is offline   Reply With Quote
Old 07-23-2013, 12:16 PM   #8198
gozirra
Spam?
Oddometer: 161
Dropped my tanks in prep for the new heat shield material, and to allow access to fix fuel line routing.
Also remeasured my right tank that has sat empty for over a month compared to when I got it and the tank was full. 3% shrinkage from the ethanol and water evap and tank shrink back to "stock" size. much easier to fit on the bike, no rubbing on any panels and the bolts all line up.
Changed oil, changed coolant, changed clutch lever and fluid, changed spark plugs, added the second fan (connector hate), cleaned front cyl pipe and drilled out the stuck heatshield bolts, added 1/2 gal of fuel to left side to fire the bish up and proceeded to have carb leaking everywhere. (yes I had run it dry before storage) let it sit overnight and now no leaks as seals re-expand (ordered o-rings just in case).
Whats left? Sidestand relocate, brake flush, cable lube, clean the airbox and heatwrap (impressive covering the bottom and top but I will cover the triangles also!), carb balance, fit crash bar studs and crashbars, swingarm bearings and rear wheel bearings.
(All of the remaining stuff will get done as I ride and get bored, but first, MORE RIDING.
gozirra is offline   Reply With Quote
Old 07-23-2013, 03:30 PM   #8199
srad600
srad600's Avatar
Oddometer: 674
- CPR Air Filter
- Remus cans (2-2)
- Mains 165/170
- PJ #45
(415) 472-4962
Huh, I work in San Rafael and I didn't even know these guys existed. Are they setup with TuneECU?
srad600 is offline   Reply With Quote
Old 07-23-2013, 03:53 PM   #8200
StevefrmGV
StevefrmGV's Avatar
Oddometer: 413
Give them a call
They are set up for fuel injection tuning but I dont know what system they use. The have a web site, look up Wheelsmith Racing/factory pro. Raul and Otto run the shop. From my experiance they know what they are doing.They have been tuning race bikes for AMA road racers etc.
Steve
Edward Abbey
Old 07-23-2013, 04:49 PM   #8201
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 722
  • Start out OCD
  • Get impatient
  • Drink a beer
  • Slap the rest on.
I hope.
Good on'ya. Thanks for the reply
HeatXfer is online now   Reply With Quote
Old 07-24-2013, 05:11 PM   #8202
stou
stou's Avatar
Oddometer: 350
What did I do to my KTM...this
1year and two weeks after purchase...
Is this helping a lot or just a little bit?
2010 KTM Adventure 990R - 2012 Ossa TR280i
'87 Honda TLR 200 - '72 Honda CB350K4 - '72 Honda CD175
http://www.stoudesign.com
Montreal to Moab 2008: http://www.advrider.com/forums/showthread.php?t=343166
stou is offline   Reply With Quote
Old 07-24-2013, 06:58 PM   #8203
Spacelord
Mutha Mutha
Spacelord's Avatar
Oddometer: 874
Added the Rox riser... No more hunchback of notre dame for me.
"I swear to god that I will beat you senseless with a sanka can before I die"
Spacelord is offline   Reply With Quote
Old 07-24-2013, 07:40 PM   #8204
Tee2
I SAID! Woo Hoo!
Oddometer: 1,270
Still the best thing I did to my 990.
Tee2 is offline   Reply With Quote
Old 07-24-2013, 08:32 PM   #8205
Rally_West
Central Scrutinizer
Oddometer: 142
Over the last few weeks (had issues with my Safari tanks) I have been doing:
1. Oil and filter change with CJ tube and drain kit and clean clutch oil jet
2. Coolant flush with destiled and Water Wetter
3. Rebuild fuel pump with new filters
4. CPR air filter
5. Pulled butterfly shafts (PO pulled butterflies off already) and silicone holes
6. Remove SAS (canisters already gone)
7. Tune with TuneEcu (still a work in progress)
8. Mount Safari tanks...what a mess so far...hopefully the new set I have will work out.
9. Euro headlight
10. New KTM heated grips (only halfway done though)
11. Slavens Skid plate
12. New battery
Still need to:
1. Figure out what to do with my driving lights
2. Go to Seat Concepts to get my seat did
3. New tires...not sure what to get for my trip to Steamboat riding the COBDR along the way
4. Modify Happy Trails rack to clear CJ storage tank
5. Mount Zumo GPS antenna so it has better view of sky
Wow...I did a lot, never wrote it all down till now, and still have a lot to do.
'07 450EXC Sold but not forgotten...you will be replaced soon.
'07 990 Adv...BOOYAH!
Rally_West is offline   Reply With Quote
Times are GMT -7.   It's 10:09 AM.
