Old 09-11-2013, 06:22 AM   #8461
salvadorfrieri
salvadorfrieri's Avatar
Oddometer: 125
Originally Posted by DesertSurfer View Post
Highlights include the SuperPlush full front and rear revalve. New front DID SE Wheel. New Pirelli Rally shoes... 16T frt. 44T rear sprockets... New frt. brakes, flushed and replaced brake fluid, New updated front brakeline ( no more crossover line), new high fender kit, lowered aux. lights to work with high fender, New EarthX ultra light battery, Dash mount for Garmin Zumo 660, Saeco wind deflector, Engine oil and filter change.
Man, that has to be one of the best farkled 950s on this forum; a great balance between function and style! The only thing I'm not too fond of is the high fender... But I guess it's absolutely necessary for mud.
Good luck with your father in law.
salvadorfrieri is offline   Reply With Quote
Old 09-11-2013, 09:07 AM   #8462
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,475
16/44... It's kind or a tweener
Originally Posted by henryroten View Post
How do you like the 16/44 gearing? I have been thinking about doing that to my 990 for some time now. Good luck with the situation.
I bought the 44T rear because the Sunsprox 45 was on backorder. I like the 17/ 44 for all around with minimal top end loss for super slabbing. I think if you're gonna go low, you might as well go 16/45 to maximize the low end grunt, which is most helpful for technical stuff.
I personally like the lower gearing for helping on decel on steep decents where the weight of the Adventure wants to force you off a rutted curve.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is online now   Reply With Quote
Old 09-11-2013, 09:30 AM   #8463
henryroten
Oddometer: 260
Thanks. Where did you buy it?
henryroten is offline   Reply With Quote
Old 09-11-2013, 09:33 AM   #8464
DesertSurfer
Tail sprayin
Oddometer: 1,475
The long tale of a simple low fender install...
I hear you on this... I love the 950 Rally style low fender. I like that it gives the bike a subdued understated look. The main reason I added the high fender was due to the thick consistency of the mud in the Colorado Back Country Discovery when the rain comes. And most importantly to loose that questionable front crossover brakeline.
The highfender update was not an easy install for me however. I ordered all the parts from the KTM parts fiche through a distributor. And even after several re-orders, different unmatched bolts arrived and some stuff never even showed... like the brakeline copper "washers" ( I reused the originals which is not necessarily recommended). Then I had to make brackets to lower the aux. lights to clear the high fender at full turn. I had to tap out threads into the brake caliper bracket to hold the brake line wire bracket. Then I had to make brackets for the bottom of the fork protectors. And threading the double banjo bolt with brakelines to the master cylinder requires far more dexterity then should be humanly possible ( 40 minutes of patience bordering on mental explosion).
It turned out looking totally OEM and I'm very happy with it... but I could never earn a living as a bike mechanic or fabricator. After the addition of adding new front brakes including the required brake fluid flush and bleeding the air out of the brake lines... I think I had nearly two days into it.
I guess it was worth it. That would have been about $1800 of shop time at the local shop.
But I'll probably revert back to the low fender for my local desert riding...
Old 09-11-2013, 09:39 AM   #8465
DesertSurfer
Tail sprayin
Oddometer: 1,475
I bought the 44T rear from Superspox directly, although they don't normally deal with the public. Their warehouse is somewhat local. But others carry them like CJDesigns!!!
I bought the dampened KTM 16T front sprocket. Maybe it's subliminal, but I like the drivetrain's smoothness on long highspeed rides and don't want to alter that.
Old 09-11-2013, 10:14 AM   #8466
Schmittenhymer
Adventure Tourer
Schmittenhymer's Avatar
Oddometer: 682
"dampened KTM 16T front sprocket"
2010 KTM 990 Adventure R
2006 KTM 525EXC
2013 Kawasaki Ninja 650 (wife's)
http://www.adventuretourer.ca
www.2wheelcentral.com
Schmittenhymer is offline   Reply With Quote
Old 09-11-2013, 01:51 PM   #8467
Katoom72
Katoom72's Avatar
Oddometer: 901
Rubber disk on the sprocket (in the middle)
Edit: pic:
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 09-11-2013, 04:40 PM   #8468
Beema Killa
Beema Killa
Beema Killa's Avatar
Oddometer: 816
What Did You Do To Your KTM Today?
I finally gave her a scrub after her long trip East.
Beema Killa screwed with this post 09-11-2013 at 04:48 PM
Beema Killa is offline   Reply With Quote
Old 09-11-2013, 06:41 PM   #8469
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,415
hahahahahha!!! love that it's BMW insignia's that you have the crosses on!!
sure the beemer boy's don't think it's quite as funny but what can they say.... ????
laters,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 09-12-2013, 01:11 PM   #8470
Beema Killa
Beema Killa
Oddometer: 816
15K service done. 3 intake shims needed. Exhaust was in spec. Need brake pads, new sprockets and chain too. Ready for more mileage! 3 out of 8 ain't too bad for valves I suppose.
Old 09-12-2013, 10:19 PM   #8471
Patacca
Pimp my SE italian style
Patacca's Avatar
Oddometer: 567
Edit: pic:
And this is useful for....??? what?
If you aren't sure, open to MAX!!!
www.raffaellophoto.com
check out my pimped SE @
http://www.myktm.it/viewtopic.php?f=50&t=223
Patacca is offline   Reply With Quote
Old 09-12-2013, 11:38 PM   #8472
JK1
JK1's Avatar
Oddometer: 116
I'm running a front sprocket like that on mine, helps makes it quieter but then again I can't hear much with my leo's making all the noise.
Current KTM 950 Adventure S 03
Old Suzuki TS50, Aprilia Chesterfield RS125 , Honda NC30, Cagiva Elefant 750
JK1 is offline   Reply With Quote
Old 09-13-2013, 08:55 PM   #8473
EZ300
EZ300's Avatar
Oddometer: 1,116
New shoes...
TKC80
Mefo Super Explorer
New Midwest Engineering Shorty Clutch Lever!
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 09-13-2013, 09:07 PM   #8474
Team Vegas
98.6°
Team Vegas's Avatar
Oddometer: 269
Free Farkel came in a box of parts when I bought my 450 EXC
ZipTy Racing Shark Fin :)
Constantly dreaming of adventure
Team Vegas is online now   Reply With Quote
Old 09-13-2013, 10:15 PM   #8475
spencergt66
Oddometer: 784
Flogged
Flogged the crap out of her today wide open was the thing thing todo today
spencergt66 is offline   Reply With Quote
Times are GMT -7.   It's 04:12 PM.
