Old 09-29-2013, 10:28 AM   #8551
loph917
Beard Bros Racing
loph917's Avatar
Oddometer: 4,641
put on one of these...anyone know where to get custom shrouds made? i kind of like the all black look.
[ this space for rent ]
loph917 screwed with this post 09-29-2013 at 10:53 AM
loph917 is offline   Reply With Quote
Old 09-29-2013, 06:36 PM   #8552
EOD3MC
What will break next
EOD3MC's Avatar
Oddometer: 4,777
So after some great riding Friday and Saturday, I figured I'd knock out some maintenance on the KTM
Oil change took about 20 minutes thank to the drain hose installed on the oil tank.
Don't have to pull the left side tank anymore to swap the oil and main filter. Occasionally, I'll have to pull the hose fitting to check the screen located at the tank.
Pulled the air filter and cleaned it up, replaced the prefilter and installed a filterskin over that.
Then I pulled the tank anyhow to change out the fuel filters. The last time I changed these out was just shy of a year ago.
Looks like they needed it.
Here are the T-bag filters for comparison
Close up of the old filter...actually had debris from the tank attached to it
Here are the secondary filters...
I got this new filter kit from an inmate in Greece for a fraction of the KTM price. The only difference to be seen was the height of the secondary filter. Everything fit well and seems to work fine.
Then the problems started...
First I get everything back together and the bike won't start. Troubleshoot a bit and the fuel pump doesn't seem to be working. Checked all the plugs and connections...no luck. Off with the tank again and pull the pump assembly. Found the problem there easy enough, one of the pump's electrical connections came loose inside the housing. Fixed and back together again. Working fine, started right up
But that's not all...
Apparently the fuel pump housing wanted more attention since it was weeping gas...
Off with the tank again, out with the pump assembly....again...checked the gasket, looks good. Cleaned up the edge around the pump mating surface...put a bit of grease on the O-rings to help them slide into place...
Put it all back together again...
Looks like it's fixed...took it for a short little ride tonight. It's amazing what a difference the new fuel filters make. Power you never notice loosing is suddenly restored.
EOD3MC is offline   Reply With Quote
Old 09-29-2013, 06:42 PM   #8553
EOD3MC
EOD3MC's Avatar
Oddometer: 4,777
Originally Posted by toto#77 View Post
If you see is deepee because in the upper side there is a piace more, it's touch the bottom of the seat...sorry I can't expkain right in english
Non č facile scrivere mentre mi allaccio il casco.....
That extra lip at the top could come in handy. I have the same tray dad2bike has. Very useful, I use a piece of foam between the tray and the seat pan to keep things from moving around.
Old 09-30-2013, 11:31 PM   #8554
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
PUBLIC SERVICE WARNING:
FWIW, during my last oil change I ended up REMOVING the hose on my bike. I kept noticing there was oil residue on the inside of my skidplate and I'd clean it off and it'd just come back again. During the last oil change I discovered the source. On the bottom end of the drain hose, one of the O-rings in the fitting (where you put the end cap into) had warn out. As I put the wrench on to hold it (so I could remove the end cap) the O-ring gave out and the fitting essentially came apart before I got the cap off! Had this had happened on the trail I would have never known about it... (well, maybe the oil light would come on to tell me something's up?)
Anyway, if your oil sump extension hose can come into contact with the skidplate I'd be careful to check for this and re-route the hose to keep it off the skidplate. While I had mine zip-tied to the bottom of the engine lines there was still enough length in the hose that the end fittings were wearing into the skidplate. Please be careful and check yours.
As an aside, now that I had already cut the notch in the top plate, I can now easily get a socket on an extension up and onto the oil sump and access plug without having to remove the tank. Sure oil will spill all over everything, but cleaning that up is still quicker than removing the Safari tank!
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 10-01-2013, 05:23 AM   #8555
EOD3MC
EOD3MC's Avatar
Oddometer: 4,777
I noticed the contact when I first installed it. One heavy duty zip tie keeps it in place nicely.
Thanks for the heads up, I'll be changing the o-ring out each oil change...cheap insurance
Old 10-01-2013, 07:47 AM   #8556
SE Steve
Super Noob
SE Steve's Avatar
Oddometer: 225
Just have the stock panels warped in black. Any sign shop should be able to do it.
SE Steve is offline   Reply With Quote
Old 10-01-2013, 08:30 AM   #8557
GJ990
GJ990's Avatar
Oddometer: 297
Kenda Big Block
Well, I got these delivered to the front door for 200 bucks. They are the Kenda Big Block in 150/70-18 and 90/90-21.
The reason I chose them:
1. Good in the dirt (reportedly)
2. OK on the road (reportedly)
3. Very strong/stiff carcass
4. I wanted to try a 150 rear to match the 4.25 rim
5. I’m light on tires and so is the FL sand (we have to import our rocks).
6. Cheap: front was $71.99 and rear is $124.99
I am slightly disappointed in that I received the previous model (manufactured in 2011). I especially waited until now because I heard the new model lasts longer than the previous one. Anyway, I’ll fit them and report back on the performance and mileage. That is if I can get these D908RRs used up. 5600 miles and still useable…
990 Baja
GJ990 is online now   Reply With Quote
Old 10-01-2013, 08:59 AM   #8558
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
I'm not clear on which O-ring failed, exactly, and what that ahs to do with skidplate contact? Pics?
SA
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 10-01-2013, 09:39 PM   #8559
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
SA
The O-ring appears on the fittings at each end of the hose. Basically (if you built the hose extension yourself from the parts from Summit Racing), at each end of the SS-braded hose there is a fitting that allows you to fit the hose to the fitting mounting into the bottom of the oil tank or into the plug-end (stopper) for the downward end of the hose. On my setup, this fitting was zip-tied to the frame but the end (with the fitting) still rested on the skidplate. Over time, that hose must have rattled or vibrated enough to cause the O-ring inside it to fail. When it came time to change the oil, I secured the fitting with one wrench and tried to remove the stopper with the other. As I did that, the oil (in the hose) started to free-flow out of the fitting long before I had the stopper removed. Thus, the part failed. If that were to happen on the trail you would have never known it was occurring.
Thus, my recommendation was to carefully check those fittings to make sure they are holding. If you find you have traces of oil build-up on the inside of your skidplate, you may want to check this. I opted to just remove the hose and go back to the original OEM bolt.
For all I know, mine was the anomaly. In the event it wasn't, I pass this along as nothing more than a heads-up.
Tod
2010 KTM 450 EXC
Old 10-01-2013, 09:42 PM   #8560
Alleycatdad
Oddometer: 1,439
Sa
Old 10-01-2013, 10:56 PM   #8561
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 518
question:
Looks like the Kenda is much smaller diameter than the D908. Wouldn't that make the Kenda setup a lot lower gear ratio?
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 10-01-2013, 11:16 PM   #8562
Newbusa
Newbusa's Avatar
Oddometer: 605
Originally Posted by knobbyjoe View Post
question:
The mounted tire looks like its on the center stand.
2010 990R Adventurer.
2007 Tuono 1000R
Newbusa is offline   Reply With Quote
Old 10-01-2013, 11:18 PM   #8563
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 518
I think your right... maybe I should look a little closer next time. Thanks
Old 10-02-2013, 09:39 AM   #8564
GoGoGavin41
Isn't this that guy?
GoGoGavin41's Avatar
Oddometer: 830
My wife and I rode to Mt. Whitney over the weekend.
A few years ago (when we were still living on the East Coast), I was reading cycle world and was looking at this article that had this picture in it.
I said to myself "Self, if you're ever out there, you should go to that turn and slide through it too."
Well, we didn't capture my sidewaysness as well, and the picture's not quite as good, but it was still pretty cool to point at a picture in a magazine and ride through it years later.
GoGoGavin41 is online now   Reply With Quote
Old 10-02-2013, 09:53 AM   #8565
GJ990
GJ990's Avatar
Oddometer: 297
Correct.
990 Baja
Times are GMT -7.   It's 06:04 PM.
