Old 12-10-2013, 02:31 PM   #8836
srad600
srad600's Avatar
Oddometer: 653
Originally Posted by speed_racer View Post
A way of flushing it through without costing shitloads in oil is to use diesel. Dont start it, but just fill the thing full of diesel and turn it over with the spark leads out, drain and repeat..
I did this with a freshly rebuilt v8 once (after the head gaskets, heads/block test were not the problem of the water into the oil) and found it very successful, since then I use diesel instead of engine flush with everything..
Interesting, never heard of that technique before, thanks. I'll look into it.
srad600 is offline   Reply With Quote
Old 12-10-2013, 03:03 PM   #8837
keener
Speed changes you.
keener's Avatar
Oddometer: 927
Cool trick but I'm not sure what the remaining diesel in the engine will do to fresh oil. Might not be good.
One other way is this. Dump the used oil and let it sit for a while in a clean pan to let the oil and water separate.
Remove the water from the top using any method u can think of....like a syringe or a cotton piece. Use the oil to flush more water out of the engine. And repeat this as needed.
After the first flush, water will separate from oil quicker if you don't run the engine just. You can rotate it manually using the bolt on the generator cover or put it in 6th gear on center stand and rotate the rear wheel (harder).
04 ADV 950
keener is offline   Reply With Quote
Old 12-10-2013, 03:41 PM   #8838
EZ300
EZ300's Avatar
Oddometer: 1,031
Rode mine to the tank retirement home...
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is online now   Reply With Quote
Old 12-10-2013, 03:46 PM   #8839
speed_racer
speed_racer's Avatar
Oddometer: 707
Thanks.. Well given my non chemical background, I assumed diesel was made from oil and is basically a lighter version.. Therefore its got to be 1000% better for your engine than water is and due my calculation I estimated it to be a viable solution.. hahaha
From what I have seen, it mixes with the oil. But it cleans the crap out of an engine bigtime, and gives the new oil a longer life as it stays clean looking for a lot longer.
13' KTM 1190 Adventure R
KLX650R
RIP - BMW F650 GS Twin
speed_racer is offline   Reply With Quote
Old 12-10-2013, 03:49 PM   #8840
speed_racer
Oddometer: 707
Man you guys have it all, tank retirement home, plane graveyards etc.. if this was australia and they had a retirement home fo ranything defence wise it would either be in a museum or fenced up and considered confidential until they have rusted to nothing..
Whats to stop you from grabbing a tank with a truck or something and take it home and fix it?
KLX650R
Old 12-10-2013, 04:16 PM   #8841
GoGoGavin41
Isn't this that guy?
GoGoGavin41's Avatar
Oddometer: 828
Probably about 50 tons of metal haha
GoGoGavin41 is online now   Reply With Quote
Old 12-10-2013, 04:26 PM   #8842
speed_racer
Oddometer: 707
LOL only 50? meh, ill whip out the snatch strap and tow it home behind the 4x4 hahaha
KLX650R
Old 12-10-2013, 04:34 PM   #8843
folknride
Old Adventurer
folknride's Avatar
Oddometer: 670
I've been thinking of de-gunking the my motors at oil change (no water worries but I'm sure there's other crud). Diesel is an interesting idea.
I use Seafoam in the tank from time to time to clean that end of things, and noticed on the can it says to add it to the crankcase (cars) as well. Anyone ever do this on their bike? I wouldn't ride with it in, but you could add to the oil, run it for a while, then drain and change.
Thoughts???
folknride is offline   Reply With Quote
Old 12-10-2013, 06:53 PM   #8844
Harold Waikiki
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 395
Fell down on my SE riding in DEEP sand south of lake havasu city after driving 1500 miles thru the below zero weather from WA to AZ. Nothing broke though. The sand was like a marshmallow SE soft landing pad.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
'09 KTM 950 SE Erzberg
'15 KTM 1290 SA ordered.
Harold Waikiki is offline   Reply With Quote
Old 12-11-2013, 05:09 PM   #8845
Mesjr
Oddometer: 158
Working on a side stand relocater , and high finder . Going to disable the sidestand switch .
Mesjr is offline   Reply With Quote
Old 12-11-2013, 06:11 PM   #8846
FWUT
Oddometer: 33
I beat it like a orange headed stepchild!!
FWUT is offline   Reply With Quote
Old 12-11-2013, 10:12 PM   #8847
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 666
Thoughts???
I wouldn't use diesel fuel, but I did use diesel motor oil after my water pump seal failed. Diesel motor oil is a high detergent oil that does a bang-up job of pulling water, antifreeze, clutch fibers, carbon, pretty much any dirt & grit that accumulates in you engine.
It was recommended by the inmates here. I did 2-500 mile changes with Rotella T to flush the engine: I was a bit surprised by the amount of suspended crap in the oil during the second change.
I'm back to full synthetic. I plan on "flushing" the engine once a year this way. Overkill? Maybe, but compared to a regular oil change I've never seen that much crap caught in oil before.
HeatXfer is offline   Reply With Quote
Old 12-12-2013, 12:24 AM   #8848
srad600
srad600's Avatar
Oddometer: 653
Did you find that locally or order online?
Old 12-12-2013, 05:24 AM   #8849
Themastermike
Themastermike's Avatar
Oddometer: 743
Walked passed it in the shed
Sent by telepathy
BBF 03-09-13 "It is cool. I was playing dakar racer It truly was a gr8 day of riding you bitch"
Themastermike is online now   Reply With Quote
Old 12-13-2013, 01:46 PM   #8850
DirtJack
DirtJack's Avatar
Oddometer: 1,515
Wally World
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Times are GMT -7.   It's 05:29 PM.
