Old 12-26-2013, 12:27 AM   #8896
RoundOz
Plenty of seasoning
Oddometer: 1,017
I really appreciate that!
Originally Posted by txbear55 View Post
Hey Roundoz,
I recognize your bike from the KTM Nat. Rally...superb job with the tool container you fabricated!
You really need to consider constructing units for sale!
Unfortunately there are several hundred man hours in that piece...a labor of love. CJ's solution is eminently practical and affordable...it just doesn't work with the Jesse racks, and I like the way mine mimics the oval of the pipe on the other side. If anyone wants to build their own the starting point is 6" tubing oval-ized in a hydraulic press. This makes very good use of the space available once the bulky pipe hanger bracket is removed. If a simpler cap was fabricated, one that didn't fit inside the tube, and the finish was painted rather than polished aluminum, it would be easier and cheaper. Happy to provide construction tips and photos via pm if anyone's interested.
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 12-26-2013, 03:09 AM   #8897
种.
Ajaa kuin mummo
种.'s Avatar
Oddometer: 284
Installed uni-prefilter. Interested to see how well BMC + uni combo work.
Pics and vids
种. is offline   Reply With Quote
Old 12-26-2013, 06:03 AM   #8898
blakken
dirt napper
Oddometer: 55
Went out for a winter day ride..
Sent from my GT-I9300 using Tapatalk
http://alvsbygrusspratters.blogspot.se/
2013 350 freeride
2011 990 adv r
2011 690 enduro r
2010 990 adv abs
blakken is offline   Reply With Quote
Old 12-26-2013, 12:46 PM   #8899
steved57
steved57's Avatar
Oddometer: 431
Removed my forks and shock to send to Superplush
AMA Earned Life Member
2014 NORRA Mexican 1000
2014 Husaberg FE 350
2010 KTM 990 Supermoto
2010 KTM RC8
steved57 is offline   Reply With Quote
Old 12-26-2013, 03:11 PM   #8900
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,422
been playing with the new GoPro. did one of my easy out of the house rides on the 990 yesterday. christmas in AZ is a great time to ride. learned a lot about the camera, mounting, and the editing software. lot's still to learn but not bad for my first shot. hope you enjoy....
laramie LC4 is offline   Reply With Quote
Old 12-27-2013, 01:10 AM   #8901
macleod
New guy
macleod's Avatar
Oddometer: 100
New pegs and 2 in 1
Look at the difference between them and the standard ones
And time for a new tire
Time to ride now
Sent from my Nexus 4 using Tapatalk
live long and prosper
macleod is offline   Reply With Quote
Old 12-27-2013, 02:43 AM   #8902
Masa
Masa's Avatar
Oddometer: 303
Originally Posted by macleod View Post
New pegs and 2 in 1
You probably shouldn't look inside that 2-1 pipe..
Masa is offline   Reply With Quote
Old 12-27-2013, 02:44 AM   #8903
macleod
New guy
macleod's Avatar
Oddometer: 100
To late already did it.
Old 12-27-2013, 02:57 AM   #8904
Masa
Masa's Avatar
Oddometer: 303
I guess there was some kind of hole for the rear cylinder too, given that you're still smiling
Old 12-27-2013, 05:38 AM   #8905
JJLalas
Oddometer: 43
Nice video. Did the case suffer from that hit?
I see some "wave effect" on some on the takes, like the one facing backwards to your left foot. Are you using a class 10 SD card?
JJLalas is offline   Reply With Quote
Old 12-27-2013, 06:00 AM   #8906
laramie LC4
crash test dummy!
Oddometer: 2,422
no, no damage at all from the hit. just pushed it back.
yes i'm using a class 10 card. it's a scan disc microSDXC extreme. the best one they make.
the backward shot was the worst one. it needs more action and to be able to see the roost of the tire. problem is, if i go out nay farther then i threaten the camera with more damage. i will keep working on it and figure it out though.
thanks for the comments. really wished i hadn't lost the top of the daytona trail it was by far the best bit of trail. oh well, live and learn.
laters,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
Old 12-27-2013, 09:53 AM   #8907
effensteve
Enjoying the ride
effensteve's Avatar
Oddometer: 734
Wow, that looks like Oregon desert riding.
its a small world
effensteve is offline   Reply With Quote
Old 12-27-2013, 10:28 AM   #8908
mroddis
Oddometer: 220
Winter
Started going through my winter checklist. Started with the easiest stuff first...
- trimmed the rear mudguard after the typical groove in the swingarm was discovered. Some tinsnips and dremel work and all is good again.
- checked brake pads front and rear for wear. All fine.
Questions:
I'm looking to replace the water pump shaft this winter - is it as straight forward as all the HOW and vids show?
Does anyone have a side picture of the front brake hose guide on a 950 ADV? I think mine is slightly bent but I can't tell from the manual how it's supposed to be or exactly how it's supposed to be seated on the brakes....
Still to do:
- water pump shaft upgrade
- clean oil jet screw
- realign front forks
- fix heated grip problem
- bolt stud upgrade
- CJ oil tank drain hose kit
- service BMC filter and uni pre-filter
Clean bike - I have a lot of 'gunk' on the chain side of the bike that I'm trying to clean up - "goo gone", "clean green", other?
Matthew.
2006 KTM 950 Adventure - Black
mroddis is offline   Reply With Quote
Old 12-27-2013, 04:30 PM   #8909
Beema Killa
Beema Killa
Beema Killa's Avatar
Oddometer: 816
Mounted the new GoPro Santa brought and did a quick test on the slippery roads this afternoon. This is a pretty cool unit. The 990 Adventure sounds good too! Gonna flash freeze tonight so roads will be shitty for awhile.
https://vimeo.com/82802073
Beema Killa is offline   Reply With Quote
Old 12-27-2013, 06:19 PM   #8910
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
Sounds great.
P.S. You left your garage door open...
ben
armourbl is offline   Reply With Quote
Times are GMT -7.   It's 02:12 AM.
