Old 01-19-2014, 10:53 PM   #9031
spencergt66
Oddometer: 760
Tanks
Test fitting of the Safari Tanks
spencergt66 is offline   Reply With Quote
Old 01-20-2014, 01:15 AM   #9032
BrandtSA
Oddometer: 99
One of my dream items still to get...
Sent from my GT-I9300 using Tapatalk
BrandtSA is offline   Reply With Quote
Old 01-20-2014, 10:15 AM   #9033
prince
prince's Avatar
Oddometer: 89
oil change
did my first oil change on the beast which was fairly easy since i have the cj hose thingy however i forgo changing the screen inside the port hose right next to the drain plug since removing the crash bars and my left tank seems like a lot of work. I know for a fact that it hasn't been checked in the last oil change either so would advise me to go ahead and do it or it doesn't matter? ( i haven't put new oil in it yet).
Also i added too much water to my coolant reservoir, do i need to drain it out or is it something that will occur naturally?
thanks in advance for the help.
07 KTM 990 adv
06 Triumph Scrambler
04 1150 GSA (sold)
02 1150 GS ( crashed and stolen)
00 750 Ducati monster ( sold)
prince is offline   Reply With Quote
Old 01-20-2014, 02:56 PM   #9034
gozirra
Spam?
Oddometer: 160
Pissed failed service
Finally got to take my 950A out for a shakedown after a whole list of service items.
Get home to pop skidplate back on and find that the *&%$*%&$ o-ring on the bearing bolt that i replaced ( part #60036071044 for the bolt and oring, just did the oring) is LEAKING AGAIN! oil all over the front/left of the motor.
why is it hidden behind the tank and oil tank and radiator and uggghhh.
When i get the new bolt/o-ring to install I will be adding a liquid sealant so i wont care if it nicks the ring again, I was stupid careful with the last install.
angry, sad, let down, wanted to ride, now maybe i will actually finish my write up for the now failed service i did do. parts are probably weeks out.
gozirra is offline   Reply With Quote
Old 01-20-2014, 04:40 PM   #9035
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,834
I remember when I got mine. Literally danced a jig until the ethanol dissolved the rubber o-rings and puked gas everywhere. $5 for an ethanol resistant rubber sheet and 3 min with a knife fixed that.
If I had it all to do over again that'd be the first mod I'd do, without question.
I finally got around to putting the graphics on the bike that I ordered while studying for my Commercial Law final. It's dangerous for me to have an idea with quick access to a computer...
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 01-20-2014, 08:07 PM   #9036
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,368
Alaska ready...
And you can come down and ride to Baja with me when you've got them dialed in. They look awesome!
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 01-20-2014, 08:56 PM   #9037
Grayjet
Ride on!
Grayjet's Avatar
Oddometer: 410
Same same
I had the same leak, but it turned out not to be the o-ring... it was the damn sensor itself! The center of the sensor is like a hard, black epoxy framed by black plastic. It was the seam between the epoxy and the frame that leaked on my bike. Weird.
Photobucket Pictures, Images and Photos
I installed a new sensor and o-ring and all is well. Good luck hunting it down. Hopefully it's just the o-ring.
Cheers,
Lance
Originally Posted by Tee2 View Post
Crap!
Haven't had a chance to see where it is coming from.
'93 Honda XR650L
'09 KTM 990 Adventure
Putting miles on the tires!
Grayjet is online now   Reply With Quote
Old 01-20-2014, 09:12 PM   #9038
spencergt66
Oddometer: 760
Thats the plan.... Want to do either Alaska or Baja this year or both
Old 01-20-2014, 10:54 PM   #9039
phycospecialties
phycospecialties's Avatar
Oddometer: 46
Backgrounds
Where did you find these?
[/QUOTE]
phycospecialties is offline   Reply With Quote
Old 01-21-2014, 06:55 AM   #9040
Sumi
Sumi's Avatar
Oddometer: 1,780
Temporarly fixed the broken chain:
Old 01-21-2014, 07:23 AM   #9041
Katoom119
Katoom119's Avatar
Oddometer: 1,834
Powersports Grafix. I've had sets from them on all my dirt bikes and couldn't be happier.
Old 01-21-2014, 10:46 AM   #9042
Pyndon
Pyndon's Avatar
Oddometer: 2,498
Blew a half in hole in my front header pipe......rotten!
Lyndon Poskitt Racing
Currently racing my way around the world at: www.facebook.com/LyndonPoskittRacing
Blogging at: www.racestoplaces.com
My Dakar Rally Experience
and blog www.LyndonPoskittRacing.com
My KTM 950 Story
Pyndon is offline   Reply With Quote
Old 01-21-2014, 11:15 AM   #9043
Katoom119
Katoom119's Avatar
Oddometer: 1,834
I'm sure you'll come up with some fix that adds 15 hp, 30 ft lbs of torque, and weighs half of what the original pipe did using a rubber band, a Coke can, and some bubble gum.
Old 01-21-2014, 01:11 PM   #9044
toto#77
toto#77's Avatar
Oddometer: 97
Finish to put the muffler on and lift the number plate of about 10cm
non facile scrivere mentre mi allaccio il casco...
toto#77 is offline   Reply With Quote
Old 01-21-2014, 03:27 PM   #9045
kanur
cu new er
kanur's Avatar
Oddometer: 711
New chain and sprockets. Changed to 17 - 45 gearing.
Just cause I don't run my mouth don't mean I got nuth'n to say. Mike Cooley DBT
kanur is offline   Reply With Quote
Times are GMT -7.   It's 01:27 PM.
