Old 02-10-2014, 02:26 PM   #9166
macleod
New guy
macleod's Avatar
Oddometer: 92
Originally Posted by scorpion View Post
Don't forget the anti-seize
Got the same issue when I put a bigger sprocket. A lot of WD40 and brute force I finally got the bugger out
Sent from my Nexus 10 using Tapatalk
live long and prosper
macleod screwed with this post 02-10-2014 at 10:19 PM
macleod is offline   Reply With Quote
Old 02-10-2014, 07:48 PM   #9167
sstewart
sstewart's Avatar
Oddometer: 1,056
Aux Fan
Installed the BDCW Aux Fan.
sstewart is offline   Reply With Quote
Old 02-11-2014, 08:10 PM   #9168
sstewart
sstewart's Avatar
Oddometer: 1,056
SS Bracket
Installed BDCW SS bracket
Old 02-12-2014, 12:25 AM   #9169
Hawkeyenfo
FLY NAVY - 113 Years
Oddometer: 50
Oil, filter, screens, serviced foam air cleaner, replaced stripped water pump cover bleed screw, new o-rings on the metal water pump tube, check valve clearances (one needed adjustment), Pastrana bars, heated grip install, new grips, changed coolant....last week. Tonight, put my new Woodward aluminum baseplate one, replacing the cracked original. Thanks to FZCruiser for the help and the garage lift!! Ready to go
'05.5 950ADV
'97 ATK 605
'82 CR 480R
Hawkeyenfo is offline   Reply With Quote
Old 02-12-2014, 01:20 PM   #9170
FZcruzer
Oddometer: 498
After doing all that work, you should have did what I did last weekend, ride it!
http://youtu.be/FnHcooUTb_w
FZcruzer is offline   Reply With Quote
Old 02-12-2014, 11:11 PM   #9171
Hawkeyenfo
Oddometer: 50
You know it!!
'05.5 950ADV
'97 ATK 605
'82 CR 480R
Old 02-13-2014, 12:42 PM   #9172
KTM 950S
KTM 950S's Avatar
Oddometer: 111
put new "shoes"...first time with so oriented dirt tires..have to wait until sunday to ride it...[IMG][/IMG]
KTM 950S is offline   Reply With Quote
Old 02-13-2014, 02:39 PM   #9173
Katoom72
Katoom72's Avatar
Oddometer: 861
Insured it, my 690 (that would have been be the replacement of my 950) is up for sale. 950S is way more fun then a 690R.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 02-13-2014, 02:50 PM   #9174
SpeedyR
SE in the SE
Oddometer: 870
put my studded tires back on and went for a spin... short spin. not enough ice, wore down my studs!
SpeedyR is offline   Reply With Quote
Old 02-13-2014, 07:54 PM   #9175
Black Hills
Oddometer: 1,180
Installed the forks with new springs the UPS guy brought me from Superplush. Ready for the predicted 60 and sunny on Sunday to test them out.
Black Hills is offline   Reply With Quote
Old 02-14-2014, 05:28 AM   #9176
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,807
You know its a bad winter when someone in Atlanta keeps studded tires on hand. (I used to live in Marietta)
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 02-14-2014, 07:34 AM   #9177
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 872
Marietta
HaHa, I used to live in Marietta ( 1974/75 ) Remember as kids sliding down the paved hill after ice storms on bicycles.
dogsslober is offline   Reply With Quote
Old 02-14-2014, 10:33 AM   #9178
SpeedyR
SE in the SE
Oddometer: 870
oh yeah and I forgot, I installed my Minion to the front fender pre ride. just a bit of shaving of his ass to get him enough contact area for the superglue to get a grip.
I was pissed about the weather mainly because I had just taken the tires off last week because I "assumed" that our once a year snow/ice storm was done with. it's not easy mounting these things up, you have to watch your knuckles/pants and with the mousse in the front, makes things more fun. especially when it's cold out.
Old 02-14-2014, 11:18 AM   #9179
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 666
Drove 30miles home from work without a clutch and without stopping. Master cylinder seal blew. Again.
HeatXfer is offline   Reply With Quote
Old 02-14-2014, 12:04 PM   #9180
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 454
gefr is doing my second master cyl S/S re-sleeve. I haven't tried his mod yet but shall do next month when I'm reunited with my SE in Chile. He also offers a needle bearing in the lever to cut friction.
This brings the bore down to 9mm and should last for ever. Add to that Rekluse and it should be the best possible solution.
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Times are GMT -7.   It's 12:25 AM.
