Old 03-18-2014, 07:02 AM   #9406
JRod152
will work for tires
JRod152's Avatar
Oddometer: 347
I rigged up a new windscreen with my new LED lights from Cyclops. Here is the thread in vendors on Darryl's lights... baller
Gone is the worthless OEM headlight. I elminated the OEM instrument cluster and am running a Trail Tech Striker. I also tossed the factory key switch w/ steering lock (which has to weigh 2 lbs. ) & put a Sicass Racing key switch in it's place. I think it's much cleaner now. These mods worked great with the HDB hand guards & the accessories that Paul offers for them.
I wanted to have a windscreen that gave some decent protection for cold weather riding & long trips. However, I didn't want it to be cumbersome or hard to remove for local trail riding, etc. I purchased a used Slipstreamer Spitfire w/ mounting hardware off of eBay for $35. The mounting hardware kit size / part # doesn't matter since you wont use the handlebar clamps... just the mounting cones on the windscreen.
With som RAM accessories (1" threaded femal socket balls, 1" offset mount balls, 3" arms), I rigged up a quick release and moderately adjustable windscreen. It comes off very easy and mounts solid. When unmoutned, you only see the 2 RAM balls on the handguards. (How many times can I say "Ram Balls" in a paragraph!)
Once I decide on the final position, I'll use zip ties or Dzus fasteners with some fuel hose as a protector to secure the bottom of the windscreen.
Check it out...
I think it will work! The screen will most likely work best at roughly the same angle of the front forks, but I'll play with it a bit and see.
Cheers!
"Never let the things you want make you forget the things you have"
JRod152 screwed with this post 03-21-2014 at 08:46 PM
JRod152 is offline   Reply With Quote
Old 03-18-2014, 07:08 AM   #9407
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,712
I overfilled and pumped the bubbles out. The cheapie Motion Pro tool works for setting the height. The marks are a little hard for old eyes to read and the stop ring won't fit over the spring guide but I just used some tape at the mark. Worked fine.
On old school forks I just measure the fluid with a graduated cylinder.
Sent from my Hipster Rotary iPhone using Tapatalk
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 03-18-2014, 07:17 AM   #9408
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,042
Originally Posted by JRod152 View Post
Yep.
I like where this is headed.
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Old 03-18-2014, 09:12 AM   #9409
ABuck99
0.0
ABuck99's Avatar
Oddometer: 613
Burping my Baby
After a waterpump seal update, flush, adding some delicious Engine Ice, Samco Silly hoses, I commenced to burp the baby.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is online now   Reply With Quote
Old 03-18-2014, 02:04 PM   #9410
DirtyADV
DirtyADV's Avatar
Oddometer: 2,328
Originally Posted by Lycan1 View Post
That is how I did mine as well. The straps might have helped.
When will you learn? A couple of wheelies after having drained the coolant is the proper way to burp any LC8 engine!
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 03-18-2014, 02:17 PM   #9411
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,499
Is that really necessary? I have to to do mine soon.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 03-18-2014, 02:39 PM   #9412
DeepSea
electronically challenged
DeepSea's Avatar
Oddometer: 242
Tubeless
Inspected my $8 tubeless rim job and mounted new rubber.
This is after about 1k miles. It doesn't leak and the tape is firmly in place.
I felt comfortable enough to put on a new tire on.
Got to say installing that Heidenau without a tube made it all worth the effort.
CDR 2012 ------ Too Lazy to write my own RR
Commercial Diving flashlight and tools
It's not me. My bike is Narcoleptic.
Research is what I'm doing, when I don't know what I'm doing.
DeepSea is offline   Reply With Quote
Old 03-18-2014, 03:01 PM   #9413
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,886
Duct tape? Can you do that?
DELTATANGO is offline   Reply With Quote
Old 03-18-2014, 03:02 PM   #9414
juames
juames's Avatar
Oddometer: 2,499
If you are referring to the "burping". It does call for it in the manual. Many don't bother, or have their own way of removing any trapped air (Wheelie, etc). after filling I use the bleed screw on the top of the water-pump housing and also the one on top of the rad (opposite from the cap) to remove trapped air.
Right...thanks!
Old 03-18-2014, 03:22 PM   #9415
DeepSea
DeepSea's Avatar
Oddometer: 242
It's the silicone glue in the spoke nipples that do the sealing. I'm not sure that gorilla tape is doing much sealing. But... if I need to install a tube. Say for a hole I can't plug. Or I get a leak thru the spokes. The tape will work as a rim protector.
It didn't take all that long. About an hours worth of work, then letting it sit overnight.
First I made sure my spokes were tight. Then cleaned everything really well. Wire brushed and degreased. Put the wheel up on a stand and went around to each nipple. Injecting silicone adhesive with a caulking gun. While it was still wet I wrapped it with the gorilla tape. Squeegeed it out down (as best I could). Then cut the hole for a valve stem. I tried to make sure I ended the tape somewhat near the valve stem hole. Doing my research on this I kept hearing about the tape just coming up. My thinking is the valve stem will hold it down. So far so good. I surely wouldn't use fix a flat or slime in it. Can't imagine the tape or silicone would like that.
If it shits the bed, I'll post back on here with the results. But for now, I'm pleased with it.
Old 03-18-2014, 04:36 PM   #9416
BMacW650
BMacW650's Avatar
Oddometer: 751
Silicon has poor adhesion properties. Plus sealing the rim this way makes it hard to fix on the road or locate a leak.
This is a much better method (just as cheap , takes longer though) <--- (Not my idea, I just used this method)
http://cyb.smugmug.com/Motorcycles/K...9444&k=BjwM3St
I've done it on my 990 and 1 other bike no problem so far 25k miles combined.
BMacW650 is offline   Reply With Quote
Old 03-18-2014, 04:54 PM   #9417
kag
Wander Lust
kag's Avatar
Oddometer: 1,719
I rode it
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 03-18-2014, 05:01 PM   #9418
EZ300
EZ300's Avatar
Oddometer: 1,116
Took her in for a valve check.
Eliminated the rear ABS
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is online now   Reply With Quote
Old 03-18-2014, 05:38 PM   #9419
DeepSea
DeepSea's Avatar
Oddometer: 242
Does that dry hard like crazy glue?
When/if my silicone fails, I'll give it a shot. Got to say I'm hooked on having it tubeless.
Old 03-18-2014, 08:11 PM   #9420
keener
Speed changes you.
keener's Avatar
Oddometer: 964
What if you need to adjust the spokes later on?
04 ADV 950
keener is offline   Reply With Quote
Times are GMT -7.   It's 03:45 PM.
