Old 03-21-2014, 05:58 AM   #9451
Bowser
Oddometer: 165
Originally Posted by keener View Post
Wow washer drama you are having....don't reuse your copper washers. They are meant to be crushed to make a seal. You can make used washers red hot with a torch and reuse them may be once more. You can use aluminum washers too.
dont forget, you need to heat them and then quench in cold water, if you let them cool slowly they will harden again, copper it the opposite to steel in this respect.
Bowser is online now   Reply With Quote
Old 03-21-2014, 09:07 AM   #9452
EZ300
EZ300's Avatar
Oddometer: 1,009
Originally Posted by akarob View Post
Was it actually a valve adjustment, or just a valve check? Sticking a feeler gauge in there and confirming everything is ok is a lot easier. When you first posted the picture I wanted to ask if you checked them to verify they needed adjustment before you brought it in.
Rear cylinder valves were fine,... Front were tight and needed shimming
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 03-21-2014, 01:00 PM   #9453
BikeLugger
BikeLugger's Avatar
Oddometer: 181
Killed three birds with one tank removal.
Replaced the fuel cocks (the thread had stripped in one leaving it jammed shut after I fitted my scottoiler), new fuel filters and new oil pressure sender.
The old ones were stupidly tight, I had to resort to a pair of pliers to close them off. When it came to opening them, only one would comply. I figured best to swap em both as the salty roads must have taken their toll. They are in a very exposed position, I'm curious how many others have had to swap them out.
Both cocks had lost their filter straws into the tank and took a bit of fishing about to recover
With the tanks off and empty it was worth doing the fuel filters. It's amazing how much crud there was in the tanks when you drained them fully.
I guess the previous service used non OEM kit. The new tea bag was a really tight fit, I had a moment thinking it was the wrong one.
Thanks to Sumi and co in another thread I'd discovered my oil pressure sender was duff so swapped that for a fresh one.
This completed the holy trinity of jobs and I offered out my sacrifices to the gods of fettling before taking a shake down ride.
Matt.
Save $5 with SmugMug, voucher code - mwllJmqM2Vgzo
BikeLugger is offline   Reply With Quote
Old 03-21-2014, 01:06 PM   #9454
JK1
JK1's Avatar
Oddometer: 113
Went out to test out the HDB mirrors, ended up being a 4 hour test ride
Current KTM 950 Adventure S 03
Old Suzuki TS50, Aprilia Chesterfield RS125 , Honda NC30, Cagiva Elefant 750
JK1 is offline   Reply With Quote
Old 03-21-2014, 01:15 PM   #9455
VTvfr
VTvfr's Avatar
Oddometer: 431
Originally Posted by srad600 View Post
There's a vendor selling these L.E.D. bulbs for "off-road use" in the vendor's thread. A link to the install process here...http://www.advrider.com/forums/showp...&postcount=403
I haven't run it at night yet as I just installed it today, but it looks pretty promising in the garage.
I've been waiting for someone with a 9X0 to be the guinea pig!
PLEASE let us know how it turns out!!!
Chad
'07 990 Adv
'07 250 XC-W
(plated)
'03 600RR
(track duty only now)
'94 VFR750 (sold)
VTvfr is offline   Reply With Quote
Old 03-21-2014, 01:53 PM   #9456
GoGoGavin41
Isn't this that guy?
GoGoGavin41's Avatar
Oddometer: 814
Rode over the weekend
Then found out that the BMC filter I had in the bike sucked dirt (literally)
Switching to a SW filter, also doing a valve check, coolant, oil, maybe fuel filter all at once. Feel free to follow / provide input here.
GoGoGavin41 is offline   Reply With Quote
Old 03-21-2014, 07:31 PM   #9457
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 617
Really need to hear more. Please ride it soon and give us a good report here or in the seller's post.
Was it a direct fit? Any issues at all with the install?
I want one, but I've been waiting for someone to report on fitment for the 990.
ben
______________________________
2013 KTM 990 Adventure Baja Edition
armourbl is offline   Reply With Quote
Old 03-22-2014, 09:24 PM   #9458
Grizz Adams
Grizz Adams's Avatar
Oddometer: 1,928
Still playing with the bar height, so I installed the .75 BRP risers
And in the interest of safety *cough cough*, I installed a new L.E.D. bulb.
Does it happen to say if the fan is water proofed? I know you have to trim the rubber boot from around the base. My only concern would be getting water in the housing. If it seals well I will be buying one soon.
Sent using smoke signals
"I go where the voices in my head tell me to!"
KTM 990 ADV- "Annika"
Grizz Adams is offline   Reply With Quote
Old 03-22-2014, 11:39 PM   #9459
Rikki Rockett
Look What The Cat Rode In
Rikki Rockett's Avatar
Oddometer: 229
GPS, Scotts Dampener and Side Stand Relocator
So, finally got around to having the Scotts Steering Dampener installed at the dealer. Eliminated the head shake by about 70%. Haven't tried it off road yet, but I'm sure it will be more than satisfactory.
I also picked up a Garmin 390. The Baja has the mount onboard and I decided to try my own fabrication rather than buy the Touratech or whatever. Winded up using a Drum Workshop floor tom stand bracket and an older Ram mount. Hardwire installed it and I think I'm gonna like this set up!
Also, did the side stand install from Back Dog as well. Good weekend so far!!!
'13 KTM 990 Baja / '13 Triumph Tiger / ['14 KTM Superduke 1290] / '04 Triumph Thruxton / '64 BSA Rocket-Lightning / '74 Norton Commando 850
Rikki Rockett is offline   Reply With Quote
Old 03-23-2014, 05:42 AM   #9460
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,780
The head shake will disappear when you change from the 908 tires.
2011 White 990 Adv S
2014 500EXC Black
FakeName is online now   Reply With Quote
Old 03-23-2014, 10:41 AM   #9461
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,261
What Did You Do To Your KTM Today?
Yesterday rode to the local dealer and picked up oil and filter. Also the little seal washers for swapping out the coolant.
Another week I'll take a couple days off work on the way to the weekend and do the valve clearance check, change oil and filter and coolant and put a fresh tire on the front. I'll be replacing that worn front 908 with a TKC80.
I asked the dealer about what they charged for the valve check and adjust, $95.00/hour shop rate for about 4 hours plus parts.
I do this myself once and I'll have saved enough for a HB lift. Couple more times and I can manage one of those fancy Handy lifts.
Sent from my Hipster Rotary iPhone using Tapatalk
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head screwed with this post 03-23-2014 at 10:49 AM
Mr Head is offline   Reply With Quote
Old 03-23-2014, 11:48 AM   #9462
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,750
How does headlight bulb do?
DELTATANGO is offline   Reply With Quote
Old 03-23-2014, 12:41 PM   #9463
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,112
I rode in circles for a total of 436 miles playing tag games. Damn Ilove this beast.
1Bonehead is offline   Reply With Quote
Old 03-23-2014, 12:41 PM   #9464
Mikef5000
Oddometer: 2,030
Today... I replaced the 10 month old BikeMaster Gel battery (that never worked well) with an official Yuasa again. I wanted to try a Deka battery, but at $50 more than Yuasa, I couldn't justify it.
I also replaced the hardly worn (after 4000 miles) front K60 tire with a new Michelin T63, in preparation of March Moto Madness later this week. The K60 front will go back on when this T63 is toast (I'm guessing in a good month, about 4k miles).
And I put in the metal Timing Cover Plug/Bolt... after I broke the plastic one doing a valve check last week.
I hope it's ready to ride 500 miles, just to abuse it off road for two days, and then ride 1500 miles home!
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 03-23-2014, 01:02 PM   #9465
mroddis
Oddometer: 183
Spent some $$
Bought her a new 4L of Motorex gold infused oil for $90 (!!!). At least that's what I suspect they put in it to justify that kind of price...
Also picked up a couple of jugs of Engine Ice ready to do the water pump seal next weekend.
M.
2006 KTM 950 Adventure - Black
mroddis is offline   Reply With Quote
Times are GMT -7.   It's 03:00 PM.
