Old 09-06-2014, 10:23 PM   #10516
srad600
srad600's Avatar
Oddometer: 683
Primed, painted and bolted up the reinforced subframe.
Cleaned, sanded, ceramic coated and re-installed exhaust pipes.
Finally fixed the wiring around the steering stem.
And cut down the OEM windshield. I'm in the middle of painting it now. Head bobble is gone at speed!
...sent...
BAJA 2014 - 990s
srad600 is offline   Reply With Quote
Old 09-07-2014, 12:34 PM   #10517
mjskier
mjskier's Avatar
Oddometer: 497
I just cleaned the clutch reducing jet.
I know people have tried all kind of ways to get it out once unscrewed. But I just happened to have the perfect tool for the job: a set of spring loaded craftsman needle pliers.
mjskier is offline   Reply With Quote
Old 09-07-2014, 12:51 PM   #10518
DavidQ
We Don't Rent Pigs
Oddometer: 2,070
Time for the 20,000 mile service.
Adjusted valves
Flush and fill coolant
Change oil and filters
While going back together with everything, I noticed the return throttle cable was nearly broken, so I also replaced that.
I also spooned on some new tires.
The only thing left to do is replace the brake fluid and replace the rear pads.
Now, time to plan a fall trip.
2001 1150GS / Ural Hack
2011 990 Adv R
Colorado / Utah 2010
Colorado / Utah 2011
NM, CO, UT, AZ 2012
DavidQ is offline   Reply With Quote
Old 09-07-2014, 12:51 PM   #10519
scudrunner82
combustion addict
scudrunner82's Avatar
Oddometer: 2,618
I just did that job on my 1190R. After pulling my hair out, I found using some heavy grease on a Q-tip pulled it right out.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is offline   Reply With Quote
Old 09-08-2014, 02:00 AM   #10520
manxkipper
Fishpistel
manxkipper's Avatar
Oddometer: 515
Built a rack for a soft bag. Creates a nice long loading platform with the topbox off.
Norton 650 Mercury
1936 BSA Y-13 Project
1969 BSA Rocket 3
2014 KTM 1190R
manxkipper is offline   Reply With Quote
Old 09-08-2014, 11:18 AM   #10521
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 732
Originally Posted by srad600 View Post
...Cleaned, sanded, ceramic coated and re-installed exhaust pipes.
Where'd you get the coating done? I've just started looking at Jet-Hot, is there a local Bay Area shop that does true ceramic coating?
Thx.
HeatXfer is offline   Reply With Quote
Old 09-08-2014, 02:00 PM   #10522
4corners14
4corners14's Avatar
Oddometer: 668
Well.....
After having broken off both the OEM and the KTM Twins replacement mirrors on the 990 I've just installed the Double Take set. We'll see if they're any tougher.....
Originally Posted by GJ990 View Post
No thank you, way too big and clunky for my taste.
4corners14 is offline   Reply With Quote
Old 09-08-2014, 02:05 PM   #10523
JK1
JK1's Avatar
Oddometer: 116
Changed the facet filter and got lost in some lanes for 2 hours .
Current KTM 950 Adventure S 03
Old Suzuki TS50, Aprilia Chesterfield RS125 , Honda NC30, Cagiva Elefant 750
JK1 is offline   Reply With Quote
Old 09-08-2014, 02:07 PM   #10524
micky1
Oddometer: 59
fitted a six day 690 high fender to my 990 adv....lovely.
micky1 is offline   Reply With Quote
Old 09-08-2014, 02:43 PM   #10525
gozirra
Spam?
Oddometer: 160
Picked it up in Henderson NV (after being transported back from the Alcan 5000 finish in Anchorage) and rode it home through the WORST traffic possible back to Los Angeles.
Maybe I will clean it and start a service check
in a month or 3..
gozirra is offline   Reply With Quote
Old 09-08-2014, 02:45 PM   #10526
Black Hills
Oddometer: 1,321
ordered fork seals and brake pads for it....
Black Hills is online now   Reply With Quote
Old 09-09-2014, 03:03 AM   #10527
Sumi
Sumi's Avatar
Oddometer: 1,813
Installed 200F temp switch
Old 09-09-2014, 06:21 AM   #10528
gorgopodaros
gorgopodaros's Avatar
Oddometer: 286
fixed my pump with Dr Bean's assembly.
Easy, quick and only 42 euros inc. pp.
works like a charm!
memento mori
gorgopodaros is offline   Reply With Quote
Old 09-09-2014, 10:39 AM   #10529
oldfuddy
oldfuddy's Avatar
Oddometer: 713
Pulled the stock tank and prepped the facet on the safari for install on the SE. Not a huge fan of the safari, but I need to free up the left side which currently has my 1.8g aux tank so I can install a CJ designs storage box for an up coming trip and the stock 3.4 won't be enough legs.
Ordered new plastic.
Ordered Crispy Designs decal set, including matching decals for Marathon RR fairing. Can't wait!
Ordered new 606 and terraflex.
oldfuddy is online now   Reply With Quote
Old 09-09-2014, 11:34 AM   #10530
srad600
srad600's Avatar
Oddometer: 683
Thx.
I understand there are a few in South San Francisco and at least one in Belmont, but I went with a DIY method (which I know isn't as good as a full interior/exterior coating). It's basically a ceramic header coating in a spray can. You bake the coating onto the headers, either in an oven or by following precise heat cycle instructions.
It's still early days, but the finish seems pretty hard, and the heat by my right leg seems diminished.
BAJA 2014 - 990s
Times are GMT -7.   It's 08:37 PM.
