Old 04-13-2010, 05:56 AM   #1
rogtek OP
Oddometer: 24
Carb Sync
Hello everyone!
I am interested in synching the carburetors in my KTM 950 Adv (mod 2004) and I am a little confused with the whole procedure.
Service manual and other posts I have read, say that you must disconnect both tanks and mount the sync tool in the two hoses attached in the right back corner of the air filter and the SAS valve (my bike has the SAS system) coming from the cylinder inlets.
Can I disconnect the two hoses and attach them to the sync tool without removing both tanks?
rogtek is offline   Reply With Quote
Old 04-13-2010, 06:59 AM   #2
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 581
Only if both of the hoses from the inlet stubs are long enough, but at the standard length you'll probably need to remove the R/H tank. You could fit longer hoses so that you can do it without removing the tank next time.
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 04-13-2010, 08:54 AM   #3
1stiski
Ride that nasty thing
1stiski's Avatar
Oddometer: 1,630
Get an airflow meter instead, makes life easy, just put it on the carbs and it will show you flow, easy and no screwing with hoses or disconnecting stuff.
"04" 950 Adventure S 37,000+ miles
2003 Harley XL883 converted to CAFE (2013-14)
"Grim Brother" #1
1stiski is offline   Reply With Quote
Old 04-13-2010, 09:54 AM   #4
AdvGa
AdvGa's Avatar
Oddometer: 1,320
I just Synced the Carbs and did the following:
1- Had to Unbolt the Right Gas Tank to get to the Vacuum ports
2- Added a 2- Y Connection Hose Adaptors to the Lengthened Hoses to under the seat for easier future access.
3- Capped the One Tee when the Sync was done.
http://www.ktm950.info/how/carbs/sync/carb_sync.html
Also found it ran smoother when I did the Sync at the 4-5k range with just a minor adjustment.
Now with this process, don't have to Unbolt the Tank but just lift the seat and Uncapped the 2 ends for future syncs.
AdvGa screwed with this post 04-13-2010 at 03:54 PM
AdvGa is offline   Reply With Quote
Old 04-13-2010, 11:15 AM   #5
DirtyADV
DirtyADV's Avatar
Oddometer: 2,241
Like i did, only had some plastic Y-connection that broke, maybe cause of the heat or something.
Now i have just plugged both of them with some small metal pins with a ridge on them used for holding up bookshelfs.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 04-13-2010, 02:32 PM   #6
cagiva549
whats a cagiva
Oddometer: 2,454
I sync mine with an infared thermometer , shoot temps on the exahust the same distance from the cylinder . When the temp is the same its running right . I picked up an electronic sync tool cheap a couple years ago so the first thing I checked was the 950 . sync was perfect till I maxed the sensytivity all the way out , they were out by 1/8 of the scale there so I left it alone . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
86 Goldwing my geezer ride
cagiva549 is offline   Reply With Quote
Old 04-14-2010, 12:56 PM   #7
rogtek OP
Oddometer: 24
I think the best solution is the one made by AdvGa.
Two questions only:
1) Does it affect carb sync sensitivity and
2) As I see in the photo there is no need to remove the right tank. The two hoses (with the Y connector) that connect to the air filter and SAS valve are already coming from the cylinder vacuum ports. Right?
Old 04-14-2010, 01:47 PM   #8
AdvGa
AdvGa's Avatar
Oddometer: 1,320
RogTek,
The Plastic Y Connector I attached were Added to the Hoses and not on it originally. Brought both hoses back to under the seat so the Tank will NOT have to be unbolted again to do this process.
When the Sync is done, I just put some caps over the Extra Y Connector when it is done.
Hope this helps....
Old 04-15-2010, 05:16 AM   #9
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,738
Sync
Good point made earlier thata is worth reinforcing - sync at the rpm range you ride in most of the time. It will be a little different to idle. What would ya rather have - sync when your running or sittting at the lights.
Pete
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 02-02-2012, 02:35 PM   #10
Blackalac
Oddometer: 80
I use a home made manometer which consists of 1/4" id vinyl tube tie wrapped to an aluminum yard stick(could be a meter stick). I find it much more convenient that a device were I have to read each meter and compare the reading.
This device is commonly used on airhead BMWs
i did remove the right tank for access
Blackalac is offline   Reply With Quote
Old 02-02-2012, 02:47 PM   #11
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,244
"Another option is a direct airflow meter like the STE Flowmeter shown above which measures the actual airflow though carbs or F.I. throttle bodies. The correct model for the 950/990 is the 6537 AKA the "SK". It fits snuggly in the air horn and doesn't need to be held in place (though if you touch your finger to it lightly, it will make reading the gauge easier with the "normal" V-Twin engine vibes). It's the most accurate and easiest to use tool of the bunch, as no vacuum connection is needed. Click on the image above for a link to more info on this tool."
Copied from the HOW...I use this and it's so easy, and I can do it pretty much any time I have the top of the airbox off. It takes seconds.
Chuckracer is offline   Reply With Quote
Old 02-02-2012, 03:44 PM   #12
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,905
+1 I bought one and it's stupidly easy, buying two would make it even easier, but it's not required.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 02-02-2012, 04:48 PM   #13
Pax
shazam.
Pax's Avatar
Oddometer: 812
Not to hijack, but how do you do it with the SE? Aux fuel tank?
Pop & Pax - West TAT 2009
The Dean of Adventure Routes
“Character is much easier kept than recovered.” –Thomas Paine
Pax is offline   Reply With Quote
Old 02-02-2012, 06:53 PM   #14
Orangecicle
Orangecicle's Avatar
Oddometer: 2,566
+2. . Simple and easy.
Orangecicle is offline   Reply With Quote
Old 02-03-2012, 10:10 AM   #15
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,295
I tried to order a 6537 from their website and when I got to the checkout I got an ODB database error
I emailed them. Hopefully they got the order
Times are GMT -7.   It's 04:59 PM.
