Old 08-24-2012, 10:16 AM   #1921
twohawks
Not Afraid
twohawks's Avatar
Oddometer: 2,164
Send a message via Yahoo to twohawks
Originally Posted by ruralgold View Post
No, the bike is too new for me to have cleaned it(yet). Should I go ahead and pull the carb and clean it, and is that a difficult process? Or just try the seafoam, of which I have a can sitting next to the bike right now?
No...you can try the seafoam...but I think youll need the carb cleaning with a good solvent. Just my thoughts...
TWOHAWKS
Utah and Colorado 2010 Ride Report
CAT HERDER'S
BWDR
SMIBS
2008 KLR650
1984 GL1200I GoldWing Interstate
Human Power'd two wheel machine - 2001 StumpJumper Pro Hardtail
CMA ><>
GWRRA
twohawks is offline   Reply With Quote
Old 08-24-2012, 11:14 AM   #1922
OldnoGPS
Just a sightseer
Oddometer: 1,046
Seafoam tends to loosen the crud up and clog the tiny jets in motorcycle carbs. OK for V8's, not so much for bikes.
Guaranteed that the ethanol has done it's evil stuff, take off the carb and clean it. Get the bike good and hot after it's back together and change the oil too after sitting that long.
On the KLR you may be able to take out the choke cable, loosen the carb clamp and rotate the carb enough to get the float bowl off (don't try to rotate the carb with the plastic choke fitting installed, it will snap). From there you may be able to fiddle out the jets and clean stuff enough to get it running. Worth a try first.
Good luck.
OldnoGPS is offline   Reply With Quote
Old 08-25-2012, 06:31 AM   #1923
ruralgold
ruralgold's Avatar
Oddometer: 79
Good luck.
Got it out this morning and ran some seafoam through it first. Let it run for about 15 minutes and it definitely improved. However, if I turn off the choke it still dies, so I guess I'm getting into the carb. Darn it, hoping I could take it out for a run today, but not comfortable with it acting flaky. I'm pretty sure I know where the tag is too, and I love it over there!
Rory Martin, Front Royal, VA
2000 Kawasaki Concours
2011 Kawasaki KLR650
ruralgold is offline   Reply With Quote
Old 08-25-2012, 04:38 PM   #1924
5punksdad
Tag-Master-Flash
5punksdad's Avatar
Oddometer: 1,528
Send a message via Yahoo to 5punksdad
Rory,
I used this trick the other day with success.
Remove the air filter and spray carb cleaner in the intake that way. With throttle opened and closed. I did it with bike not running. After a few applications and an overnight sit the problem went away on the DR650. I also added seafoam and stabil to fuel. In between applications I ran the bike.
Sent from my PC36100 using Tapatalk 2
5punksdad is online now   Reply With Quote
Old 08-27-2012, 03:04 AM   #1925
ruralgold
ruralgold's Avatar
Oddometer: 79
Originally Posted by 5punksdad View Post
Rory,
Sounds like a plan. Funny thing though, I put the seafoam and left it running. I got preoccupied on something else and it ran out of gas...and I forgot to turn off the key, so now the battery is dead...shoot! Got it charging, so hopefully we'll get it going again tonight.
Old 08-27-2012, 04:37 AM   #1926
twohawks
Not Afraid
twohawks's Avatar
Oddometer: 2,164
Question
Need more clues?
TWOHAWKS
CAT HERDER'S
BWDR
SMIBS
2008 KLR650
CMA ><>
GWRRA
Old 08-27-2012, 04:44 AM   #1927
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,331
Fresh DR650 For Sale
Saw this in an Advantage Auto ad:
http://www.advantagecertified.com/in...rt=&direction=
Old . . . and . . . Slow
ORexpat is offline   Reply With Quote
Old 08-27-2012, 09:22 AM   #1928
optical
Oddometer: 54
Sounds like your bike isn't getting enough fuel.
Check the floats. At the least, you need to clean all of your jets and check the float valve.
As for the tag, I think I know where it is but I need to get out and get it! Won't be till this weekend at best.
optical is offline   Reply With Quote
Old 09-04-2012, 08:28 AM   #1929
twohawks
Not Afraid
twohawks's Avatar
Oddometer: 2,164
Bluhduh Move it?
Do I need to move this farther north east?
TWOHAWKS
CAT HERDER'S
BWDR
SMIBS
2008 KLR650
CMA ><>
GWRRA
Old 09-04-2012, 10:16 AM   #1930
RebRider
RebRider's Avatar
Oddometer: 394
No... maybe I will go get it.....
Eastern Panhandle WV TOR
EPWVTOR Tag Map
For those who are bored... EPWVTOR tag Stats
2001 Triumph Tiger
RebRider is offline   Reply With Quote
Old 09-04-2012, 11:20 AM   #1931
bwalsh OP
Oddometer: 7,730
No! Good things take time...
2004 XR650L
1992 Specialized Stump Jumper FS
NWVA TAG
NWVA TAG MAP
RTE THREAD & IN LIST
bwalsh is online now   Reply With Quote
Old 09-08-2012, 05:39 AM   #1932
twohawks
Not Afraid
twohawks's Avatar
Oddometer: 2,164
Thumb
TWOHAWKS
CAT HERDER'S
BWDR
SMIBS
2008 KLR650
CMA ><>
GWRRA
Old 09-16-2012, 06:09 PM   #1933
twohawks
Not Afraid
twohawks's Avatar
Oddometer: 2,164
Bluhduh Its been weeks!
It's not THAT far.....
TWOHAWKS
CAT HERDER'S
BWDR
SMIBS
2008 KLR650
CMA ><>
GWRRA
Old 09-17-2012, 09:48 AM   #1934
bwalsh OP
Oddometer: 7,730
(Testing tapatalk)
It's working! New shoes on the KLR?
I'd go for the tag but am still bikeless at the present time.
EDIT: Your post vanished......but I quoted it before you nuked it!
2004 XR650L
NWVA TAG
NWVA TAG MAP
Old 09-17-2012, 10:15 AM   #1935
twohawks
Not Afraid
twohawks's Avatar
Oddometer: 2,164
Tapatalk
Yeah...old photo. Trying to get the app to work with my blackberry...that was from the iPad.Was gonna call you to meet at Joes yesterday...thought you'd be on the river...
TWOHAWKS
CAT HERDER'S
BWDR
SMIBS
2008 KLR650
CMA ><>
GWRRA
Times are GMT -7.   It's 08:39 PM.
