Old 04-14-2010, 08:40 AM   #1
Wirespokes OP
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,127
Airhead plastic repair
I'm repairing a /6 instrument housing and need to know what glue to use. My first thought is ABS cement.
Any of you glued one of these things back together? What worked (or didn't)?
Old 04-14-2010, 02:42 PM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,597
Is it a visible crack or the inner screw mounts?
If it isn't visible I find Plastex works well Plastex obviously I have no idea if it's available to you.
It's also known as Plastech and sold on UK Ebay Ebay link
Rob Farmer screwed with this post 04-14-2010 at 02:50 PM
Rob Farmer is offline   Reply With Quote
Old 04-15-2010, 12:04 AM   #3
Wirespokes OP
Wirespokes's Avatar
Oddometer: 8,127
Thanks Rob! Never heard of Plastex before - I'll check into it.
I experimented with some junk housing bits and ABS pipe cement; it seems to be working.
These housings usually have broken/cracked mounts where the brass inserts live. I think it's due to over-tightening in the factory plus possibly the screws seizing over time. Then when some poor bloke powers the screw out of there, SNAP!
I've use regular epoxy to fix those.
The repair this time was needed around the base of the lens - inside the rubber eyebrows. Not visible, but also couldn't be globby or the eyebrow wouldn't fit. It looks like the ABS cement is going to do the trick.
Old 04-15-2010, 05:40 AM   #4
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,633
PVC (ABS) pipe cement contains a thickner that make it less liquid-y and might be hard to use on some repairs. The active ingredient in PVC cement is MEK, and it works nicely by flowing into the crack and welding the ABS.
Be careful with it-- MEK is nasty stuff.
'73 R60/5 Toaster
Old 04-15-2010, 06:01 AM   #5
Wirespokes OP
Wirespokes's Avatar
Oddometer: 8,127
Definitely! One whiff when the container is first opened is enough to tell if it's still good! So it's MEK that gives off that potent odor. Huh
Are you saying PVC and ABS are the same? I've tried to use PVC cement on ABS and got nowhere. As a matter of fact, Home Depot doesn't carry any cement specifically for ABS, instead something that's supposed to work for both. It didn't. However, ACE Hardware sells the good stuff!
Old 04-15-2010, 08:32 AM   #6
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,467
Methyl Ethyl Ketones. Will give Cancer cancer.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 06-06-2010, 06:26 AM   #7
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,597
Looks like you guys finally caught up
Plastex is available in the States now http://plastex.net/
Bit more info here --> OffRoad.com
Old 06-06-2010, 09:52 AM   #8
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,365
I have used Locktite Super Glue Slow for that exact repair. It is thin (non globby) so it can be brushed like paint. The slow formula gives you some breathing time.
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 06-06-2010, 11:04 AM   #9
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,597
I've just had a look at the plastech ingredients. It's Methyl Methacrylate or MMA which you drip onto the fine powder. It's basically the stuff used to protect the spectators at ice hockey matches and the material used to make your helmets visor.
Old 06-06-2010, 09:02 PM   #10
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,681
Another alternative
Chloroform
An organic solvent useful for bonding hard plastics and clear acetate
Ether
Can also be used on some stubborn plastics where retail products fail
I'm going back to sleep now.
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 06-06-2010, 11:07 PM   #11
squish
Out of the office.
Oddometer: 6,214
you can weld ABS pretty easily,
There are kits where you get a high temp heat gun and abs sticks for welded.
You do it from the back side of the part.
On vacation for a spell
squish is offline   Reply With Quote
Times are GMT -7.   It's 06:33 AM.
