Old 04-14-2010, 04:32 PM   #1
cleatis t OP
Oddometer: 9
Bluhduh Vibration in 1200gsa
My 2006 GSA has developed a fine vibration . It seems to be in the engine at all rpms. If you run it up to around 60 mph and pull in the clutch and let off the gas it goes away. With the clutch pulled in and run the rpms up the vibration is there. I rebalanced the tires and they were right on. You feel it more in the footpegs and less in handle bars. Any ideas.
cleatis t is offline   Reply With Quote
Old 04-14-2010, 07:45 PM   #2
marcoue
Oddometer: 264
Final drive? Had this problem once and it came form a broken drive. Take the wheel off and check if the brake disk moves or a has a play in it...
marcoue is offline   Reply With Quote
Old 04-14-2010, 08:21 PM   #3
OConnor
Bad juju
OConnor's Avatar
Oddometer: 3,783
By fine do you mean high frequency?
2013 Husky TR650
2008 GSX1250N
1990 HD Ultra Classic
2000 SV650 track bike
1971 CB175 vintage racer inabox
OConnor is offline   Reply With Quote
Old 04-14-2010, 08:42 PM   #4
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,567
Loose skid plate, lights, valve cover protector, crash bars?
scooteraug02 is offline   Reply With Quote
Old 04-15-2010, 05:50 AM   #5
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,600
That, or your rockerarm endplay is getting on the loose side. A quality endplay adjustment, valve adjustment, and throttle body sync should reduce it. Keep in mind you do have a boxer motor, two 600cc pistons battling it out.
Jim
JimVonBaden is online now   Reply With Quote
Old 04-15-2010, 04:40 PM   #6
cleatis t OP
Oddometer: 9
I did a valve adjustment about 1500 mile ago, but not end play . I look at that this weekend. The only thing I have changed is I put pivot pegs on and might have a different harmonics so this weekend so i'm going to put stock footpeg back on. I check final drive when I balance rear wheel. It has a very small amount of play that has not changed in the last 35000 miles.
Old 04-15-2010, 05:15 PM   #7
atdrs
atdrs's Avatar
Oddometer: 101
If the pegs, then it should vary noticeable when you put your feet on them, I be thinkin.
Tim S. Phx, Az.
15 R1200RT
atdrs is offline   Reply With Quote
Old 05-02-2010, 01:27 PM   #8
cleatis t OP
Oddometer: 9
I
I checked the drive shaft and everthing is nice and tight. Then I checked the final drive and the pinion shaft has about 0.010" side play. Is this excessive amount of movement.
Old 05-02-2010, 02:14 PM   #9
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,262
Check all engine mount fasteners.
Old 05-03-2010, 04:14 PM   #10
jonny cash
LEGEND
jonny cash's Avatar
Oddometer: 366
I was having the same type vibration, mostly in the foot pegs. I had recently changed the alternater belt, so I went back over the mounts on the crash bars, and found a few that could be snugged. I also re-tourqued the rear frame bolts at the engine attachment, and they were also a little out of spec. It did not make the vibes go away completely, but did make quite a difference. ymmv
jonny cash is offline   Reply With Quote
Old 05-05-2010, 07:41 PM   #11
wanocksett
Oddometer: 279
I know the vibration issue is a bit of a PIA for most of us.
Some of the gals, however, don't seem to mind it at all.
wanocksett is offline   Reply With Quote
Old 05-07-2010, 12:42 PM   #12
biggziff
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,749
Unfortunately, it's a boxer and they vibrate like a tractor motor. Some of us are much more sensitive to it. Others don't seem to even feel it.
"Fools you are. To say you learn by your experience. I prefer to profit by others' mistakes and avoid the price of my own."
- Otto von Bismarck
biggziff is online now   Reply With Quote
Old 05-07-2010, 12:45 PM   #13
ricohman
Marinoni man
ricohman's Avatar
Oddometer: 1,981
You answered your own question.
ricohman is offline   Reply With Quote
Old 05-09-2010, 04:17 PM   #14
Gone-Native
XPLORER
Gone-Native's Avatar
Oddometer: 1,198
I
I would think..... have your dealer check it.... you would not want it to seize-up while riding
Gone-Native is offline   Reply With Quote
Old 05-10-2010, 07:53 AM   #15
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,849
+1
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Times are GMT -7.   It's 06:22 AM.
