Old 04-15-2010, 02:27 PM   #1
svejkovat OP
svejkovat's Avatar
Oddometer: 856
How quiet can you make a 2 stroke?
Performance is absolutely not an issue. A one cylinder water cooled KX80 Kawasaki dirt bike motor being used in a fun scooter project. The 2 stroke it's replacing is rated at 2.5hp. The KX80 weighs the same (actually a few oz less!) and is rated at 16hp.
I'd be very happy with 8hp if I could make it stealth quiet. Seems like it would be possible, especially being water cooled, with a standard (non expansion) enduro muffler and a little more attention paid to silencing the intake. Would I have to do any retuning to the engine?
Anyone ever tried to calm a two stroke beast? Just how quiet can you get these things? I had a Yamaha 80cc "Mini Trail" when I was a kid. That's how quiet I'd like this to be. Obviously I want more than 2.5 hp out of it or it's not worth the effort. An enduro pipe would probably spread out the power band a little bit as well, no?
svejkovat is offline   Reply With Quote
Old 04-15-2010, 02:31 PM   #2
KLXplode
Desert Hunter
KLXplode's Avatar
Oddometer: 980
Step one: Take off muffler
Step 2: Sell twostroke
Step 3: Buy a fourstroke
Formerly known as ridehard_ridefast
The Collection:
-1985 Bronco II: Top chopped off. Off road lights/bumper. 2 12" subs. 5 Speed manual
-1993 Kawasaki KLX650R(Green Goblin). Trying to plate
"Trials is an amazing sport. You can get hurt really really bad without even leaving the campsite!
"Its not how fast your going, its about how fast your fast comes to a stop"
KLXplode is offline   Reply With Quote
Old 04-15-2010, 02:38 PM   #3
svejkovat OP
svejkovat's Avatar
Oddometer: 856
I googled it as well. No one is really interested in losing any performance for the sake of noise reduction, so 100 percent of online info focuses on tweaking the silencer, or wrapping the expansion chamber with insulation in order to get a db or two below max limits for sanctioned events. Helps me none at all.
I guess I'll have to just start experimenting. I hate to do it blind. If I didn't have this particular motor I would not even think to do this, so selling it and buying a four stroke is not an option. It's a '96 model, and selling it to get a watercooled 80cc four stroke would put me 500 dollars in the wrong direction. In fact, an 80cc fourstroke racing bike is still going to be waaaaaaay too loud for my aims and I'd be in the same spot of trying to repipe it.
Anyone know of a more suitable forum where I might pose this question?
svejkovat screwed with this post 04-16-2010 at 08:27 PM
Old 04-15-2010, 02:41 PM   #4
KLXplode
Desert Hunter
KLXplode's Avatar
Oddometer: 980
I guess I'll have to just start experimenting. I hate to do it blind. If I didn't have this motor laying about I would not even think to do this, so selling it and buying a four stroke is not an option. It's a '96 model, and selling it to get a watercooled 80cc four stroke would put me 500 dollars in the wrong direction.
Leave it on here for a few days you will get some responses. It just takes time, like you said mess around with different silencers, mufflers, and insulation. . Keep looking.
The Collection:
Old 04-15-2010, 03:44 PM   #5
Fubars
What would Scoobydo?
Fubars's Avatar
Oddometer: 1,751
You could try a Kawasaki KDX200 stock muffler. They're kinda heavy, though.
Fubars is online now   Reply With Quote
Old 04-15-2010, 03:59 PM   #6
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
If you're not adverse to doing some exhaust fabrication, a non-expansion exhaust from a engine roughly as quiet as you're looking for would probably work. Potential sources could be outboard boat engines, lawnmowers, etc. You could even use multiple mufflers from a smaller quiet engine to get adequate flow. Yes, you would probably have to address the engine's jetting.
That wouldn't help at all. Four-strokes seem to have more energy in the low-frequency ranges in the exhaust that are harder to muffle and carry further....hence the term "thumper."
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 04-15-2010, 04:07 PM   #7
Navin
Navin's Avatar
Oddometer: 7,658
http://www.thedbsnorkel.com/
Navin is offline   Reply With Quote
Old 04-15-2010, 04:07 PM   #8
Flatulator
Oddometer: 733
If this scooter has plenty of room for a big airbox and big pipe ... you could make it VERY quiet ... without even losing much performance at all
... even more so if the pipe and airbox could get hidden inside a plastic compartment ... (don't know what scoot you're talking about)
example ? ... the KDX200 ... a very quiet bike that is 2.5 times bigger displacement .. so you could make quieter than that with out much trouble
... don't worry about starting from scratch ... since virtualluy nobody does what you're trying to do ... your path is unknown (to you)
in steps >
cut/rotate/fit/weld the stock KX80 pipe to fit on the bike fairly nice .. dont make the overall volume/length much smaller than stock
adapt the largest (stock)OEM muff from a 2 stroke that you can find cheap ... (KTM200/250/300 EXC? - all quiet bikes)
- stock Banshee muffs are quiet too
consider doing a 180 'return' for the muff ... (so it lays over or under the pipe - with another .. mmm .. 180 (or so) ... for the final exit
If you want to keep as much of the stock power as possible ... keep the final exhaust exit the same ID as the stock KX80 had ... don't go smaller
Do an image search for aftermarket moped/scooter pipes to see what I'm talking about (with the 180 returns).
airbox ? ... make it as big as possible ... do some multiple internal baffling's to prevent 'straight shot' path of air(noise)
Too much power and noise ? ... add a few inches of overall pipe length if you have room ... make a stop to keep the powervalve (it has one?) from opening
The KDX200 used a double walled pipe for its first 20 inches to help kill noise
It could be whisper quiet ... and haul ass
Flatulator is offline   Reply With Quote
Old 04-15-2010, 08:01 PM   #9
LILBIT
Ride you must.
LILBIT's Avatar
Oddometer: 1,675
Ignorance. A two stroke is easier to make stealth. The sound waves do not carry as well as an opened up thumper. Any offroad race that does DB checks can attest.
A smaller diameter longer muffler with a DB Snorkel. On the bike it will still seem noisy. The pipe(not muffler) and cylinder do that. From 50ft at a reasonable RPM things will be much different.
I had a KTM 300 with a snorkel and good packing. Riding here at my house trail my wife would have to come outside to hear me unless i was flogging it. Even at RPM it was not annoying.
I eat my candy with the pork and beans-
LILBIT is offline   Reply With Quote
Old 04-15-2010, 08:20 PM   #10
ADVCoop
ADVCoop's Avatar
Oddometer: 785
One reason two strokes can seem loud is the thin pipes. I have had some success with wrapping the pipe with header wrap. Sometimes you have to re-jet and it kind of looks like crap so I haven't done it in awhile. I like how the DBsnorkel works but I'm cheap. I have also welded elbows on the silencer end to direct the sound down, that helps some too.
My KX125 is quieter stock than my nephews TTR125 with FMF PowerCore 4 exhaust on it that's for sure.
2006 Husqvarna 610 - 1982 Suzuki PE175 - 2009 Yamaha XT250 (wife's)
ADVCoop is online now   Reply With Quote
Old 04-15-2010, 10:19 PM   #11
KLXplode
Desert Hunter
KLXplode's Avatar
Oddometer: 980
Originally Posted by LILBIT
Ignorance. A two stroke is easier to make stealth. The sound waves do not carry as well as an opened up thumper. Any offroad race that does DB checks can attest. .
I know i know, Im just saying what I would put in it. Im a fan of 4strokes. Im in a family with XR's and I used to have a yz250. I know plenty.
The Collection:
Old 04-15-2010, 10:36 PM   #12
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,622
At our state circuit enduro last month, I'm a check captain for two checks during the race. I got to see about 300 dirt bikes come through our checks...twice. I was amazed at how quiet the KTM200's were. There were stupid quiet. The exhaust note was unbelievably low. I'm assuming these bikes had stock exhausts, because just about every KTM200 that came through was this quiet. I'd go find someone with one of these models and see how KTM made these bikes so quiet. I got see/hear everything from 80cc race bikes to 600+cc bikes, and these particular KTMs were absolutely the quietest.
TNC is offline   Reply With Quote
Old 04-16-2010, 05:31 AM   #13
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,648
please post your results,
this is real interesting
plugeye is online now   Reply With Quote
Old 04-16-2010, 05:48 AM   #14
gplassm
gplassm's Avatar
Oddometer: 587
I feel that the two strokes are easier to quiet down than the four strokes. I have an '04 KDX 200, with a stock pipe and silencer, and a Db Snorkel attached to it. As some have mentioned, while sitting on the bike, the bike sounds almost just as loud as it does without the Snorkel, but from 100 ft away the device makes a big difference. I am not able to offer actual sound measurements, but I did ask my wife to stand on the porch and listen as I rode into the woods both with and without the Snorkel attached. She said that the Snorkel made a big difference in sound reduction.
You have several main areas to look at: The silencer, the pipe itself (wrapping will help), intake (if you can find an airbox that has an intake snorkel, it will make a huge difference), and general vibration and noise containment for the entire engine bay. Stuufing foam into every crevis will help stop random vibrations and frequency resonances form metal parts. If you can "box in" the entire engine compartment with something like ceiling tiles, you will reduce noise emmision significantly. It may help to get the silencer exit as close to the ground as possible, and point it downward.
Street bikes for the street. Dirt bikes for the dirt. Let's keep it that way.
gplassm is offline   Reply With Quote
Old 04-16-2010, 06:12 AM   #15
28marcb
28marcb's Avatar
Oddometer: 139
+1 on above post.
I can get my two stroke exhaust quiet enough that I can rev my engine with my ear a foot away from it. What becomes the culprit at that point is engine noise from the exhaust manifold area, exhaust springs vibrating and the expansion chamber...
A db snorkel in combination with a ktm hockeystick or kdx 220/200 stock exhaust can will get your volume down to where you're probably happy, but the engine noise will be much more substantial at that point..The pipe wrap might be a starting point for that..
Ktm 525sx (sold)
Wr 250x
Dr 650
Ktm 690R
28marcb is offline   Reply With Quote
Times are GMT -7.   It's 09:18 AM.
