Old 01-16-2011, 07:52 PM   #166
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,684
No way
It doesn't work that way. It is an output ONLY. It isn't just a connector there are electronics inside that change the voltage.
Originally Posted by jknight8907 View Post
What kind of amps is the USB plug capable of carrying? Not for charging a device, but for the other way around. I have one of your plugs on my R6, and if it could handle 2 amps I'd like to run my trickle charger through it instead of connecting to the battery.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 02-06-2011, 02:36 AM   #167
Got2Moto
Got2MotoGraphics
Got2Moto's Avatar
Oddometer: 505
Thanks Again Burnszilla!
Great products, Great service and a great ADV'er
Got2Moto is offline   Reply With Quote
Old 03-01-2011, 12:15 PM   #168
pronator
Oddometer: 5
Originally Posted by crozz View Post
I was the one that emailed you regarding current draw when nothing is plugged in. My mate (who order with me) is still skeptical that it won't draw current.
Any word on this? Does it draw any power when the bike is off and no gadgets are plugged in?
pronator is offline   Reply With Quote
Old 03-02-2011, 11:29 PM   #169
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,350
Pronator,
Good question and lots of people ask.
I have seen it tested and it does not draw power from the battery when it has no load. The manufacturer states this too.
On the other hand, I'm sure cheap car cigarette usb chargers draw power to light that little LED bulb they have.
Burnszilla is offline   Reply With Quote
Old 03-03-2011, 02:40 AM   #170
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 592
Bumping this thread has reminded me that I should post our experiences.
We installed one on each of our F658's before setting out to travel teh back roads of New Zealand for a month at Christmas.
Rain, man we live in the sub tropics and I have never seen rain like that which we experienced on the west coast of the South Island. The Kiwi's called it a "rain bomb", we just called it bloody biblical.
The USB outlets were installed on the dash beside the rev counter, and I used a lead to run to my phone in the tank bag. Worked perfectly and with the closed cover over it not a drop of water got in.
Burnzy's USB adapter is definitely the ducks nuts.
Cheers, Mike
Don't just look at it - Ride the bloody thing!
Mike.C is offline   Reply With Quote
Old 03-03-2011, 08:40 PM   #171
Ranger159
That'll Do DONKEY!
Ranger159's Avatar
Location: My compass broke, so I'm not sure where I am!
Oddometer: 349
Thumb
Am I correct in assuming that I can run it through my fuse block under the seat, and I will operate as if it was wired off of the battery? So as to charge my IPhone or BT helmet set?
Super Cool looking product, I am placing my order.
~Trust me, I packed your chute, it should open without a hitch........
Ranger159 is offline   Reply With Quote
Old 03-03-2011, 08:47 PM   #172
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,350
You are correct. Thanks.
Old 03-08-2011, 04:23 AM   #173
crozz
crozz's Avatar
Oddometer: 135
I finally got around to installing mine. simple installation .. just crimped spade connectors, and attached to the 12v accessory socket on the scrambler. I tested the socket (not the USB), and it was reading around 13v, which I assume is pretty normal (bike was off, it's a permanantly powered socket).
I then plugged in a short iPhone lead that I use with my laptop, and got the dreaded charging not supported message. It shows the plug icon on the phone, but not the charge icon.
Any suggestions ?
crozz is offline   Reply With Quote
Old 03-08-2011, 04:18 PM   #174
Day13
Worst Avatar EVER!
Day13's Avatar
Oddometer: 679
Just got mine. Super fast ship for a custom length. Charges HTC EVO and Vholdr helmet cam like a champ!
Will probably get another one.
Day13 is offline   Reply With Quote
Old 03-09-2011, 08:44 AM   #175
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,350
Any suggestions ?
Crozz as per my email to you the other day...
Try the cable that came with your iphone. Old ipod and original iphone cables do not charge the newer models.
I saw this problem before and the owner updated his iphone firmware which fixed the problem. (There were charging updates in the firmware.)
Test the usb charger with another device if you have it. If it still doesn't work, I'll send you a replacement.
Burnszilla screwed with this post 03-09-2011 at 09:39 AM
Old 03-09-2011, 05:25 PM   #176
crozz
crozz's Avatar
Oddometer: 135
Hi. I tried the cable that came with the iphone, and I am having the same issue. I'm running IOS 4.2.1 if that is any help. I will try my wifes phone (which i think is 4.1) and also an iPod and let you know how it goes.
Old 03-09-2011, 06:33 PM   #177
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,350
Please make sure you have the polarity correct. Red to positive and black to negative. If that fails then I'll send you a replacement right away.
Old 03-21-2011, 04:37 AM   #178
Timbuktu
Timbuktu's Avatar
Oddometer: 1
USB Power Socket arrived
Stephen,
The USB power socket and additional waterproof sleeve that I ordered on 9th March arrived in the UK on the 18th March I plumbed it in on Friday and can report that the kit is all working in perfect harmony.
Thank you for the prompt dispatch of a good bit of kit.
Ride safe.
Regards
Tim
Timbuktu screwed with this post 03-21-2011 at 06:31 AM
Timbuktu is offline   Reply With Quote
Old 03-21-2011, 03:35 PM   #179
roscoau
roscoau's Avatar
Oddometer: 559
G'day, I carry an iPad I want to charge as I go, but it requires more power than an iPhone etc.
The iphone/ipod charges are 5V, 1amp and the Ipad are 5V, 2Amp. Do you have anything to suit?
Aussie Ural Owners
rosco.id.au
Ural - speed limits aren't a restriction, they are an achievement!
roscoau is online now   Reply With Quote
Old 03-21-2011, 05:35 PM   #180
Kilter75
Kilter75's Avatar
Oddometer: 6
I'm curious about this too (2Amp) I've got a Samsung Galaxy Tab that I would like to charge while riding as I plan to use it as my media/gps unit. It also needs 2Amp to charge as well.
Kilter75 is offline   Reply With Quote
Times are GMT -7.   It's 01:40 AM.
