Old 06-19-2013, 10:14 AM   #226
Hoosier Wanderlust
Oddometer: 8
I've had my USB socket from Burnsmoto for a couple of months now so I wanted to put up a mini-review.
First off Burnsmoto was great to deal with and gave a free shipping discount for ADVrider's. It arrived in 2 days.
I've ridden with mine both closed and with the USB plugged in in the rain without any problems. It charges my Galaxy Nexus as fast as a wall charger and faster than my car. The socket is compact enough to stay out of the way. I wired it straight to my battery, routing the wire with the loom.
I couldn't decide where to mount mine so I ziptied it to my left bar for now. Next is a Ram Finger mount.
I am very pleased with it and recommend Burnsmoto.
Pics of it on my old DR.
Hoosier Wanderlust is offline   Reply With Quote
Old 06-19-2013, 08:01 PM   #227
Queen of Spades
tall drink of water
Queen of Spades's Avatar
Oddometer: 978
I've had mine installed for a couple months and found that while my Galaxy S2 appears to be charging (the lightning bolt appears over the green battery indicator), the device is absolutely not being charged. Ran my phone completely down one afternoon after a full charge in the AM. I was using GPS like I use when it is plugged into my car's 12v adapter, which does keep the device charged.
Socket is wired directly to battery with the included fuse.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades screwed with this post 06-19-2013 at 08:10 PM
Queen of Spades is offline   Reply With Quote
Old 06-20-2013, 05:26 AM   #228
zeeede
Oddometer: 1,117
I had that happen to my Droid Razr Maxx running my screen on full brightness with GPS. Upgrading the USB cable solved my problem. I'm not using this particular USB power socket on my bike though.
One of these solved my problem: http://www.3brpowersports.com/products_Red_Band_USB.php
zeeede is offline   Reply With Quote
Old 06-20-2013, 05:35 AM   #229
Queen of Spades
tall drink of water
Oddometer: 978
I'll give that a try. the existing cable was a $2 made in china unit from Ebay.
Old 06-23-2013, 12:32 AM   #230
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
USB Waterproof Power Socket - Panel Mount
Item # USB-PM
Options:: 5 volts, 2 amp
Will this work/ charge a Samsung Galaxy Note2 ?
thank you.
Bbasso is offline   Reply With Quote
Old 06-27-2013, 10:46 AM   #231
bcliff
Oddometer: 150
Burnszilla,
do you still have inventory? I was about to purchase on your website but was confused by the 'out of stock' message. Wasn't sure if that was for the USB or just for the customized ends.
thanks
bcliff is offline   Reply With Quote
Old 06-28-2013, 02:50 PM   #232
VStromNC
DNS/DNF
VStromNC's Avatar
Oddometer: 853
Not here to interrupt the thread but just pointing out that having a USB power adaptor does not mean that it will work on all USB devices. Yes, it is true that all USB devices follow a protocol of using 5v but the amperage requirement is just as important and need to be carefully reviewed for your device.
Burnzilla's Adaptor produces DC 5V +/-0.25 and 1A max)
Jon
14 TR650 (Terra)
06 DL1000K6 (Vee)
VStromNC screwed with this post 06-29-2013 at 05:54 AM
VStromNC is offline   Reply With Quote
Old 06-28-2013, 03:27 PM   #233
Queen of Spades
tall drink of water
Oddometer: 978
There's also this:
http://www.modaco.com/topic/353966-b...-cant-keep-up/
Old 07-14-2013, 08:51 AM   #234
Foamfollower
Foamy
Foamfollower's Avatar
Oddometer: 57
Burnsmoto Mount?
I have been informed that the mount pictured Below (Right side) is no longer available. Has anyone seen this mount for sale else-where's? Thanks..
Originally posted/found here "http://www.advrider.com/forums/showthread.php?t=569860"
Originally Posted by Burnszilla View Post
Now available... "USB Single Charger All Weather" on http://www.burnsmoto.com
Foamy..
2003 Honda Nighthawk 750
Foamfollower is offline   Reply With Quote
Old 07-14-2013, 09:33 AM   #235
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
They are no longer in production and I sold the last one last month.
I have a new source for a charger that looks the same and also comes in 2.1 amps.
Burnszilla is offline   Reply With Quote
Old 07-14-2013, 04:18 PM   #236
BillMoore
BillMoore's Avatar
Oddometer: 258
Just placed an order for the 2.1A USB charger. Thanks!
2012 Suzuki DR650SE
2010 Kawasaki KLX250S
BillMoore is offline   Reply With Quote
Old 07-15-2013, 10:42 AM   #237
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
You're welcome!
Old 08-02-2013, 01:58 PM   #238
SRad
Shutterbug
SRad's Avatar
Oddometer: 7
Cry USB Power Socket
I just bought this one from my local BMW dealer (Adventure BMW, Chesapeake VA) - did he see me coming? I wired it to the CenTech and discovered when I tested my iPod Touch that it rendered the touch screen inoperable, a common problem I'm seeing. Should it go directly to the battery or should I junk it for the new 2.1 Amp version?
SRad is offline   Reply With Quote
Old 08-16-2013, 09:46 AM   #239
TraumaQueen
WW( ;,; )D?
TraumaQueen's Avatar
Oddometer: 458
Hey there!
I'm looking for a way to put a good-quality USB hub in my tank bag so I can charge multiple whatevers (iPhone, intercom, GPS, etc.)
Will the 2.1 amp version of the USB Weatherproof Power Socket work as a source for the hub, or will that draw too much?
It's a Kawazuki Yamahonda.
TraumaQueen is offline   Reply With Quote
Old 08-16-2013, 02:02 PM   #240
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
Originally Posted by TraumaQueen View Post
Hey there!
I have never seen this done before. You are dividing 2.1 amps by 4 devices = .5 amps per device. So, that .5 amp wont charge most of your devices.
Times are GMT -7.   It's 11:51 AM.
