Old 06-02-2014, 06:20 PM   #256
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
We have added a new option.
Low profile DIN Hella BMW Powerlet Plug to USB...
http://www.burnsmoto.com/dual-port-u...atherproof.php
http://www.burnsmoto.com/usb-power-s...atherproof.php
Burnszilla is offline   Reply With Quote
Old 06-03-2014, 06:43 AM   #257
jmckeown88
Oddometer: 34
The little white piece inside of one of my two usb sockets fell out - is it replaceable outside of re-mounting the whole assembly?
"I'd rather my heart be without words than my words be without heart..."
jmckeown88 is offline   Reply With Quote
Old 06-03-2014, 09:22 AM   #258
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
I'll send you a replacement unit today.
Old 06-09-2014, 07:43 PM   #259
theycallmetrinity
theycallmetrinity's Avatar
Oddometer: 91
question for iphone 5
Hello there, I want to use my iphone 5 as a gps. I see you have different methods to hook up the sockets. As I read the direct connection to the battery slowly drains the battery. As I understand the sae connection only draining the battery when its charging a phone. Am I getting this right?
So if I get a sae unit how do I install it? Do I need a power outlet on the bike? My bike is stock this will be my first mod. Do you have tutorial...sorry for the nooby questions I'm not soo familiar with electronics.
"A good traveler has no fixed plans, and is not intent on arriving."
Lao Tzu
2009 Triumph Thruxton
2013 Kawasaki KLR 650
theycallmetrinity is online now   Reply With Quote
Old 06-10-2014, 05:42 AM   #260
:.Wahspz
:.Wahspz's Avatar
Oddometer: 36
Hi mate. Grab something like this http://www.amazon.com/Battery-Tender.../dp/B000NCOKZQ and hook it to your battery.
:.Wahspz is offline   Reply With Quote
Old 06-10-2014, 10:46 AM   #261
theycallmetrinity
Oddometer: 91
Thanks man, after doing some research I figured I needed something like this...felt a bit like a dumb(_:_) asking silly questions.
Lao Tzu
Old 07-16-2014, 07:44 AM   #262
sanluissound
Oddometer: 44
SAE connector and battery drain
The power socket you use, which ever you choose, will have a small current draw when plugged in - even if it's not connected to your phone. The SAE connector will have no effect on that (you'll still be using a bit of power) unless you unplug the SAE connector.
If you want to go simple - an SAE wired to the battery then wired to a USB charger will work but you MUST disconnect the SAE every time you're done riding the bike.
A better, simple solution - find a switched lead on your bike (head lights, FI, etc.) - something that's not on until the key is turned on. Connect the USB/charger outlet leads to the switched lead and mount the outlet where you'd like. Whenever you turn of the bike there is no more current draw, no chance of leaving the SAE connected accidentally overnight (as an example).
I've been using my iPhone5 for GPS for a little over a year now - in a Defender case, mounted to the bars with a Ram mount, powered with a homemade power distro system (fused, relay, multiple outputs) and it's been great. My Garmin Montana feels like a primitive tool after using the smart phone (it is more rugged though…)
Hope this helps!
Joe
sanluissound.com
sanluissound is offline   Reply With Quote
Old 08-24-2014, 03:15 AM   #263
Hedonist222
Hedonist222's Avatar
Oddometer: 197
I'm interested in getting this.
2.1amp
What all would I need?
I'll be passing my mobile in a weatherproof case on my handlebar.
Hedonist222 is offline   Reply With Quote
Old 08-26-2014, 07:50 AM   #264
Hambone70
Hambone70's Avatar
Oddometer: 35
Can I use your device to charge one of these: http://www.amazon.com/New-Trent-iCar.../dp/B003ZBZ64Q ?
2008 Kawasaki KLX 250
2001 BMW R1150R
Hambone70 is offline   Reply With Quote
Old 09-02-2014, 07:17 PM   #265
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
Yes you can.
Old 09-02-2014, 07:18 PM   #266
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
2.1amp
All the products I sell will work for you. It's your choice how you want to do it.
Old 09-13-2014, 08:49 PM   #267
chatleyg
Oddometer: 11
Ordered on Tuesday, received on Thursday and installed this afternoon. Looks good and works great. Doesn't get any better.
Chatleyg
chatleyg is offline   Reply With Quote
Old 09-16-2014, 03:55 PM   #268
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
Chatleyg
That's the way we roll!
Old 09-20-2014, 04:52 AM   #269
blackcap
blackcap's Avatar
Oddometer: 538
do you guys sell the mounting brackets separately?
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 09-20-2014, 11:43 AM   #270
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
If you need a replacement bracket, send me an email and I'll send it to you free.
Times are GMT -7.   It's 02:57 PM.
