Old 04-16-2010, 02:55 PM   #1
Jay.T OP
Oddometer: 59
'93 Airhead Timing
Is the “timing box” listed in the Clymer’s manual the only way to set static timing on a ’93 Airhead? I recall a post on building one for an Oilhead, anyone no if this would work on an Airhead? I have searched the maintenance threads here, no talk of the “timing box”.
Jay.T is offline   Reply With Quote
Old 04-16-2010, 07:22 PM   #2
bmwrench
Oddometer: 2,173
There's been a lot of talk lately about static timing air-cooleds. I have never bothered static-timing a bike with electronic ignition. Slip the bean can in place and set it in a location where it is almost certainly retarded. Start the motor and set the timing with a strobe light.
bmwrench is offline   Reply With Quote
Old 04-17-2010, 05:37 AM   #3
Joerg
Joerg's Avatar
Oddometer: 1,356
Hi,
you are probably referring to this unit, but I agree with bmwrench ... before removing the "bean can" from the bike I merely mark its position. After reassembly I just start, then adjust timing with a strobe light.
- Joerg
1990 BMW R80GS and K100LT * Lausanne, Switzerland
My Motorcycle WebPages - LED voltage monitor (aka charge light)
Joerg is offline   Reply With Quote
Old 04-23-2010, 05:40 AM   #4
Beemerboff
Oddometer: 2,328
I had to time my dual plugs G/S recently after fitting a Boyer ignition, and both the rev counter and strobe were out for lunch - so I set it by trial and error up a long and steep hill.
Ended up around 26 degrees full advance, a bit less than what others find.
But then , the unleaded that is around now burns a good bit faster than the leaded premium that was around when the bike was made so maybe I shouldn't be too surprised.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 04-23-2010, 06:51 PM   #5
Jay.T OP
Oddometer: 59
Thanks for the info guys.
Times are GMT -7.   It's 01:03 PM.
