Old 04-18-2010, 08:40 AM   #16
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,521
Originally Posted by Steverino
Me too
Steve:
Hope you get it back on the road. But if you want to fly home I can PayPal $3000 right now to you in Texas. I'll even eat the fees and add 3%. Just sign the title and leave it under the seat. I'll be down Tue to collect my new bike.
T.
Infracaninophile is offline   Reply With Quote
Old 04-18-2010, 09:24 AM   #17
The Raven
The Raven's Avatar
Oddometer: 4,811
Originally Posted by Infracaninophile
Steve:
T.
+1, except I don't have a spare 3k now.. and even worse, have no way of getting it out of Texas as I am unable to enter that state again in my lifetime.
The Raven is offline   Reply With Quote
Old 04-18-2010, 11:40 AM   #18
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,278
Then use someone else's lifetime! Duh
Old 04-18-2010, 06:28 PM   #19
dduelin
Oh boy that was close
Oddometer: 1,617
Originally Posted by Boon Booni
How do you neglect a rotor? When a winding opens up what could have been done to prevent it?
I am sorry I implied that rotors fail from neglect. They are a crap shoot and can go for 100,000 more miles or fail tomorrow.
I meant that airhead Bosch charging systems in general fail from neglect. The original system is simple but won't last forever if neglected. This means 20-40 year old wiring still in place with the original terminal fittings, corrosion in wires & fittings, never checking output to benchmark the system, failing to renew heat sink paste, leaving batteries chronically undercharged from low revs, lack of riding, add-on loads of lighting/heated gear or a combination of these.
Aside from an open rotor there are usually signs and symptoms things aren't right for a while before you are stranded.
Triumph Tiger 800
Honda ST1300
Honda CH80
Dave
dduelin is offline   Reply With Quote
Old 04-18-2010, 06:33 PM   #20
StephenB OP
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Strike the heatsink paste, that is ignition related for 1981-on bikes.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 04-18-2010, 07:13 PM   #21
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,903
Got ya. I had a rotor go bad on me last summer. Was wondering if there was more that I could have done, besides installing one of Motorrad Elektric's rotors preemptively.
Old 04-18-2010, 07:48 PM   #22
StephenB OP
StephenB's Avatar
Oddometer: 2,044
No, nothing. What I do for prevention is alternating two charging systems on a yearly basis, so I always have known good spares and check cables and connectors once a year. I don't mind the breaking down bit, it's part of the journey. What I do mind is not being prepared when it happens!
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 04-19-2010, 07:21 AM   #23
Joerg
Joerg's Avatar
Oddometer: 1,356
Wicked Use a Voltmeter!
Hi,
Nope, there is no preventive maintenance for an alternator rotor ... but since this is the part that most frequently fails ("frequently" in terms of Pareto charts, not in terms of absolute numbers) I have a simple voltage indicator installed on all of my bikes, and AFAIK Stephen has also a (digital) voltmeter on his GS. These things solve at least two issues:
(1) The provide an immediate warning when the rotor fails. The GEN light will usually not do this during a ride, only after the next stop/start cycle ... and you may well have drained the battery during those 200 km you have covered in the meantime. On the voltage indicator, the red LED will light up in the same moment the rotor fails, leaving largely 'nuff time to implement "plan B" (switch off the headlight, look for buddy or dealership with spare rotor in 250 km radius, etc)
(2) Diagnostic status about the battery being charged: When I know (= visible indicator) that the battery is being drained, not charged, I know that I should switch off the heated grips . The GEN light does not do this.
- Joerg
1990 BMW R80GS and K100LT * Lausanne, Switzerland
My Motorcycle WebPages - LED voltage monitor (aka charge light)
Joerg is offline   Reply With Quote
Old 04-19-2010, 07:31 AM   #24
Gringo
simple by nature
Gringo's Avatar
Location: a small drinking village with a fishing problem
Oddometer: 1,349
in 17 years with my '92 PD, I've had 3 electrical failures. First was the original rotor, which went out after a long, hot day of an XC trip. A couple years later I wanted more lights so upgraded to the Motorrad Omega charging system, and about a year after that I began having charging issues and discovered the new diode board was slowly melting down, one diode at a time, for reasons I've never been able to figure out - Rick sent me a new one under warranty and I've had no further issues to this day, at least 5 yrs later.
My third failure is embarassing - my 8-yr old Westco battery slid back and was rubbing against the rear fender for some time and eventually the grit wore a hole in it and drained 2/3 of the acid. The bike was starting hard and I needed a jump once to get home from work; without investigating I just figured the battery was finally tired after a pretty good run, but when the new Odyssey arrived and I took the old one out I discovered the hole - pretty amazing how less than half of an 8-yr old battery was able to keep the bike mostly running for as long as it did. I made sure to strap the new one down better... hopefully others will learn from my stupidity.
All in all I've found the airhead electrical system, in spit of its limitations, to be pretty robust and forgiving, and in all three cases I was able to keep limping along for hundreds of miles or weeks of daily riding until the problem was fixed.
- Gringo
"I mean seriously, what is funnier than Helen Keller" - Mutineer
"Ah, yes, Greasing the nipples is really the cure all for a whole host of ailments." - Stagehand
Gringo is offline   Reply With Quote
Old 04-19-2010, 07:48 AM   #25
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
My ears are burning..
crazydrummerdude is offline   Reply With Quote
Old 04-19-2010, 08:34 AM   #26
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,112
With five airheads and twenty years I have had one rotor fail (I did run the bike up to redline numerous times) and one diode board go.....
I have a one complete charging system, and another spare diode board on the shelf now...
Riding in today, no accessories, I was shoing 13.6 volts at 4K rpm's... I have my GPS set to display battery voltage and just keep an eye on that.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 04-19-2010, 06:36 PM   #27
Steverino
Arrogant Horse's Ass #1
Oddometer: 36,668
Mine was the rotor. Luckily some very nice Texans helped and one even had a spare air head motor in the garage to borrow a rotor from. So I lost 18 hours and got home with no more problems.
Also, there was no neglect on this bike. Every connection was spotlessly clean and protected with dielectric grease.
Roll of the dice rotor failure. Although I do ride ALL my bikes hard.
Steverino is offline   Reply With Quote
Old 04-19-2010, 06:42 PM   #28
bmwrench
Oddometer: 2,350
After rotor failures held up enough trips, I don't leave town without a spare. A new one is carefully wrapped in the bottom of my tank bag and the removal tool is tucked in my tool kit. Haven't had one fail since I started carrying it!
bmwrench is offline   Reply With Quote
Old 04-19-2010, 07:10 PM   #29
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,903
You going to test that new rotor out at Laurel Forks this weekend?
Old 04-19-2010, 07:14 PM   #30
Steverino
Oddometer: 36,668
Nope, I got a long list of "chores" to do on the bike after my little 4000 mile jaunt. I have a few issues to resolve. Nothing major, just a bunch of small things that drive me crazy.
Times are GMT -7.   It's 01:36 AM.
