Old 09-19-2011, 11:35 AM   #361
blownaway
Oddometer: 273
HI-how does the double take mirror mount on the right side for a 04 950 ADV?
My right mirror broke off the master cylinder reservoir. The master cylinder works fine, just the mount broke off.
thanks
blownaway is offline   Reply With Quote
Old 09-19-2011, 12:18 PM   #362
Wings
marmaduked
Wings's Avatar
Oddometer: 14,246
thanks
I hope my last e-mail made it through! If not, per our conversation, take a look at the split clamp assembly here to relocate the mirror perch off your brake reservoir
Smugmug coupon code: CKZQ0vLPlmLFw
Wings is offline   Reply With Quote
Old 10-04-2011, 04:58 PM   #363
kbroderick
Oddometer: 1,041
Originally Posted by neduro View Post
Well, to be honest, I'm not 100% positive either. The oilhead GSs had a few different setups installed, and while I should be able to tell by year, I'm not enough of an expert to be positive.
If your stock mirror goes through the perch to a nut on the bottom, you want the plate. If your mirror threads into the perch, you want the BMW adapter. Both exist on 1100/1150s, so I'm not sure which you have without seeing the bike, but you should be able to tell pretty easily.
If you have any questions, you can reach us at 888.501.0599.
I'm trying to picture how this would work. My mirror stalks go through the control pods and attach via nuts on the bottom. If I went with the plate, would I need to find an appropriate-sized bolt to go through that hole? Or am I missing something?
Thanks.
kbroderick is offline   Reply With Quote
Old 10-05-2011, 07:43 AM   #364
Projected
Single Track Attack
Projected's Avatar
Oddometer: 228
Originally Posted by Projected View Post
I can't read this entire thread and the ADV search really doesn't work very well.
My doubletake mirrors slip out of adjustment on washboard roads or any bump I happen to hit. I like to see behind me on dirt roads too so it's pretty annoying.
No one else is having this issue? RAM rubberizes all their ball mounts for a reason.
EDIT: I'm using a 3" metal RAM arm and I have not tried sanding the plastic ball. I have thought about putting the fingertip of a Nitrile glove over the ball but haven't done it yet.....
Since I purchased the mirrors I had been putting the more open of the two ends of the RAM arm on the rubberized ball mount side (bike side) and the more closed end on the mirror side. This seemed to make the most sense for removing the mirrors easily to switch to another bike.
On my last ride I decided to flip the RAM arm over, with the open end on the mirror side and the closed end on the bike side. I rode 30 miles of washboard and only one mirror barely moved, which was acceptable to me. Prior any amount of washboard would have the mirrors dropping out of adjustment.
I'm not sure why this made a difference for me but it did and now I'm happy
[10 990 Adventure S] [13 250 XC] [08 YZ125] [07 YZ250] [04 DRZ400E plated] [09 GasGas TXT300 Pro] [14 200XC-W]
Projected is offline   Reply With Quote
Old 10-10-2011, 08:55 PM   #365
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
Just wanted to share my experience with these mirrors. I do love these folding mirrors, they have exactly the kind of versatility I had been looking for. I have them mounted on my plated XR:
They are not quite perfect, however, as I do experience movement of the mirrors at speeds above 50 mph. Vibration is noticeable on my setup, but I've seen worse. The main problem is that I would have to readjust the mirrors during my ride if the wind/air pressure was significant.
Looking over the mounting system last weekend to see what could be done, I noticed that the ball mounts were being somewhat deformed from the sphere shape due to my clamping/tightening efforts. It occurred to me that I could easily make a spacer dowel to prevent over tightening the ram side of the clamp. So I took the clamp apart and found out that a 5mm bolt would fit the inside of the spring without too much play. I think a 1/4 bolt would also work, but I used a spare 5mm bolt that looked to have a decent chrome coating to prevent early rusting.
Taking some measurements, I cut two sections off of the unthreaded portions of the bolt slightly longer than I thought I'd need, 18 mm. Then taking a file, I started shortening the dowel and test fitting on the bike. The dowel goes in the spring, and the spring side of the clamp is mounted on the RAM mount. I was taking off about 0.2 mm per trial, and I ended up with 16.7 mm on one clamp, and 16.4 mm on the other. To test, I would grab the mirror bracket/post and give a gentle tug. If things moved, then I went back to filing the dowel shorter. It didn't take too long to find the sweet spot where the RAM ball was clamped adequately and the rest of the clamp pressure went to the plastic mirror ball. Photos:
After this addition, I'm happy to report that the mirrors are staying in place now.
If this fix stops working, then I'll probably look into cutting up a rubber glove and using a finger end to slip over the plastic mirror mounting ball as suggested earlier. If anyone has tried this, post up and let us know how it worked.
Also, I suppose a small rubber stopper could fit into the recessed holes that are molded into the plastic mirror mounting ball. Those rubber stoppers are sold at any well stocked hardware store so that would be easier to try than making the dowels but I had the bolt handy in my bin of extras.
Ghost_Mutant is offline   Reply With Quote
Old 10-11-2011, 08:27 AM   #366
neduro OP
Addict
neduro's Avatar
Oddometer: 11,939
I really like that fix, Ghost_Mutant. Good thinking!
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 10-14-2011, 09:13 AM   #367
Projected
Single Track Attack
Projected's Avatar
Oddometer: 228
Nice work Ghost, please keep us updated on how it works for you.
I originally mentioned using a nitrile glove finger tip but ended up trying latex because I had one handy. It works, my mirrors did not move at all and this was before flipping the RAM arm. However the latex does not hold up, it dries out and disintegrates pretty fast, mine lasted about a week but looked like hell most of the time
I just returned from a day ride in AZ with 60% dirt and the flipped RAM arm with no glove tips did move some. Next I'm going to try the nitrile glove tip but will probably end up purchasing the tool handle rubber dip, this seems like a more permanent fix that will look better. The finger tip is really a quick fix if you're in a bind.
Your idea looks really good as well so I may give that try.
Old 10-15-2011, 12:31 AM   #368
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,163
Ghost, I also had the RAM balls deform too much when I tightened down the RAM arms enough to keep the Double Take mirrors from moving on my Husaberg FE390 while riding. Your mods inspired me to see what I could do for the short RAM arms, so I got after it:
Drill a few holes on one side
Bottom-tap some 8-32 threads
Insert in some stainless steel screws with Red Loctite
Grind the screws down until I got just enough clamping force on the RAM balls. Ground screws face down towards the RAM ball.
It works great!
cyborg is offline   Reply With Quote
Old 10-15-2011, 09:30 AM   #369
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,790
Thumb
Great stuff guys! Although mine have been superb for many many miles this leverageing idea is suberb and I'll have to give it a test.
It's especially noteworthy to me now that I want to try the plastic mounts vs the alum for some weight savings and this mod will help them to transfer force to the harder DT ball.
GREAT idea two thumbs up!
Jettn Jim is offline   Reply With Quote
Old 10-15-2011, 10:41 PM   #370
Ghost_Mutant
looking for bionics
Oddometer: 713
I rode the XR to work 4 of the 5 days this past week. Its 25 miles a day with 55 mph speed limits. On one day I had a decent head wind to overcome. But I didn't have to adjust the mirrors all week. No movement of the mirrors like I had before the dowel addition.
I still have to tighten the knob pretty tight, but now the dowel limits the pressure on the RAM ball side of the clamp. I'd like to be able to just cinch down the knob without feeling like I'm over doing things. So for grins, I stopped in at the local hardware store when I was going to the bank today. They don't appear to have rubber stoppers small enough to fit inside the mirror ball holes. I didn't feel like spending my time trimming the larger stoppers down to size. Scratch that idea.
However, I walked out of the store with a can of black plasti dip just like the left most can on this web page:
http://www.plastidip.com/home_solutions/Plasti_Dip
Now this may not wear any better than the latex glove that Projected tried, but it can't hurt anything (other than my wallet) to try.
I'll put a single layer on each mirror ball this weekend and see if it helps.
Cyborg, that is a pro installation
Old 10-17-2011, 06:59 AM   #371
neduro OP
Addict
neduro's Avatar
Oddometer: 11,939
Impressed!
Old 10-17-2011, 09:09 AM   #372
kbroderick
Oddometer: 1,041
Still trying to figure out the best way to attach this to a 2000 R1150GS, which has a threaded mirror stalk (M8x1.25) that fits through the clutch perch/master cylinder assembly and is secured by a nut from the bottom. I'm thinking the M8x1.25 RAM ball (as shown here) is the best bet, just not sure if the collar below the ball will be long enough to put the ball above the clutch reservoir.
Any thoughts?
Old 10-18-2011, 09:50 PM   #373
Ghost_Mutant
looking for bionics
Oddometer: 713
Plasti Dip update
I put a single layer of plasti dip on my mirror balls last weekend:
The upside is that the mirrors absolutely stay in place now with less clamping force required.
The down side is that the vinyl coating is soft and the aluminum clamps did immediately wear into the plasti dip where the sharper edges/ends of the clamps contacted the mirror ball.
The other down side is that the mirror is now harder to fine tune, because the plasti dip vinyl really is sticking to the clamps.
Since the mirrors have now lost some of their convenience due to the extra effort needed to fine tune their position before final clamping, I won't be recommending the plasti dip solution unless you have an especially hard case of keeping the mirrors in place.
If I were to do it again, I would not put the plasti dip on the mirror ball. Instead, I think I would only coat the inside of half (one side) of the aluminum clamp. I'm thinking that masking off the outside of the clamp (on one aluminum casting only) and then dipping the end which holds the mirror ball. Just after dipping, remove the masking tape before the plasti dip cures. I think that would probably work much better and I may try this if the coating I have now on the mirror balls wears off.
Its been a fun experiment, and I think I'm good to go for now. I'll just deal with the fact that fine tuning the mirrors for the street after riding the trails will take a bit more time.
Old 10-18-2011, 10:55 PM   #374
cyborg
cyborg's Avatar
Oddometer: 5,163
Good try on the Plasti-dip Ghost.
One thought I might toss out for coating the aluminum clamp on the plastic ball side, try a layer of stick-on polyurethane film on one or both sides of the mirror clamp mount. That stuff is unbelievably tough and puncture resistant. I've used it in numerous places on bikes to protect wires and such from vibration and metal parts abrasion, and paint from rock chipping, etc.
The polyurethane film comes in various thicknesses and is the stuff they use for stick-on headlight protectors (thick), and often as paint protector layers on cars and bikes (thin). They usually come with a high heat acrylic adhesive on one side, trim with scissors, peel-n-stick. I think it would work well in this app since it will allow adjustment. I have some and will try it.
Some examples:
Google: 3M urethane film
http://www.xpel.com/
http://www.amazon.com/Xpel-R3022-Cle.../dp/B003EP52BU
http://www.cleardefender.com/?gclid=...FQl1gwodomhcJw
etc etc
Old 10-19-2011, 11:35 AM   #375
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Oddometer: 1,790
Some examples:
etc etc
Good idea...
Times are GMT -7.   It's 05:39 AM.
