Old 08-26-2013, 01:28 PM   #646
Freakhead
Living Proof
Freakhead's Avatar
Oddometer: 325
Originally Posted by mommer View Post
comeon! got friends that rent ktm's out here (just started up) would love to have some of my internet friends to ride with again!
thanks ned
We are looking at a brief escape from Canadian winter in either November or February to Maui. Let me know their company name! Not interested in the Harley rental.
Thanks.
( Sorry for thread-jacking )
Freakhead is offline   Reply With Quote
Old 08-26-2013, 02:21 PM   #647
neduro OP
Addict
neduro's Avatar
Oddometer: 12,052
(Don't be, come February, everyone here will want to be in Maui)
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 08-26-2013, 05:25 PM   #648
Freakhead
Living Proof
Freakhead's Avatar
Oddometer: 325
AMEN!
BTW got my mirrors & love the ease of removal and durability!
Old 08-26-2013, 11:12 PM   #649
mjedude
Oddometer: 3
Does anyone know if the back half of the split clamp assy which you screw the stud ball base into will work as a perch mount on my crf250x?
I appreciate any replies!
Thank you
mjedude is offline   Reply With Quote
Old 08-27-2013, 06:00 AM   #650
neduro OP
Addict
neduro's Avatar
Oddometer: 12,052
I don't know that it will, but it might. It does serve this function on 950/990 ADV front brake master cylinders.
Old 08-27-2013, 06:39 AM   #651
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,103
Thank you
If you're talking about using the mirror mount side of this:
to replace your existing split clamp from your front master cylinder or lever perch? I've done it on both a Ducati Monster and a Suzuki DR350. I used the split clamp bolts with the Duc, but had to use the stock Suzuki bolts.
Measure center-center distance on your clamp - that's the key. I've got the SuzyQ here at work and can check it - or Ned can measure a new one? Otherwise, the clamp fits any non-cruiser (1") handlebar. Even fatbars are 7/8" at the control section.
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 08-27-2013, 10:11 AM   #652
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Thank you
Yes, I have mounted mirrors on my 2004 Honda CRF250X using this method.
Spud
Old 08-27-2013, 11:57 AM   #653
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,103
Spud
I note that this is also a possible alternative to a Yamaha left hand thread adapter. On my Duc, I had LH/RH threads. This gave me RH/RH.
Old 08-27-2013, 08:08 PM   #654
mjedude
Oddometer: 3
Perfect! Thanks!
Old 09-04-2013, 07:27 PM   #655
mommer
bring on the world!!!!
mommer's Avatar
Oddometer: 1,980
ned, love the mirrors! went on no problem! already tested a couple of em.. seem stronger and more forgiving than the clutch/brake levers on the little dr200
just ride it out!
go fast and hang on tight!
spot linky:
http://share.findmespot.com/shared/g...UkefvUtpvQzqzl
mommer is offline   Reply With Quote
Old 09-05-2013, 07:10 AM   #656
neduro OP
Addict
neduro's Avatar
Oddometer: 12,052
Old 09-25-2013, 08:50 AM   #657
dentedvw
Where did I put that
dentedvw's Avatar
Oddometer: 2,175
I have posted about it several times, but it's official. These mirrors I have don't work.
They fold back at any speeds above 65, and for whatever reason, my DR650 vibrates enough that I can't see if there is a car behind me at night or an airplane.
I wanted to like them so much. Everyone seems to love them. I have sanded the ball, I have crushed the snot out of the rubber ram ball to get them tight enough, the balls are about to split apart.
I want mirrors I can see out of. I have been using them for commuting on the freeway, and they simply don't work for road use on my DR or my DRZ.
Is it at all possible there is a batch of them that were not as good?
"Even though my trip turned out badly, I don't regret the kind of life I chose to live. Adventure!" RIP-Clay Schwartz 9/14/07
The bike never has been, never is, and never will be the limiting factor in my, your, or anyone else's ability to have an adventure. -jake28-
dentedvw is offline   Reply With Quote
Old 09-25-2013, 10:07 AM   #658
neduro OP
Addict
neduro's Avatar
Oddometer: 12,052
I'm really sorry to read this.
I'll PM you, I'd be happy to send you a replacement set and see if that changes anything. It's so odd that your experience is different from so many others and my own- not doubting you, just wish I understood why!
PM incoming.
Old 09-25-2013, 11:40 AM   #659
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,054
PM incoming.
I have one that works perfectly and one than falls down after every bump......
KTM 1190R...Adventure Beast, 950SE......Desert Beast, KTM 690 Quest...Rally Beast, Husqvarna 501...Trail Beast, KTM 300xc...Woods Beast
Nowwhat is offline   Reply With Quote
Old 09-25-2013, 11:45 AM   #660
dentedvw
dentedvw's Avatar
Oddometer: 2,175
I understand completely Ned, I tried various things to keep them in place, but no luck yet. I will try the replacements, I hope it works. I kept trying them anyway, partly because so many people have had good reports of them.
Times are GMT -7.   It's 01:02 AM.
