Old 10-30-2013, 07:33 AM   #691
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
ontic,
Cool I did miss your post.
That makes three successful dowel mods. Anyone else, pro or con?
Ghost_Mutant is offline   Reply With Quote
Old 10-30-2013, 09:01 AM   #692
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
Someone should tell RAM Mounting Systems. They should modify their design to include the dowels.
Spud
Old 10-30-2013, 11:36 AM   #693
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,944
Hey Ned,,,,
how about selling dowels cut to the correct length?
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 10-30-2013, 12:38 PM   #694
neduro OP
Addict
neduro's Avatar
Oddometer: 11,965
Originally Posted by Nowwhat View Post
Hey Ned,,,,
Since reading about it (when first posted, and again now) I'm thinking I should make some that I can send to anyone who wants them.
I don't want to disassemble every RAM clamp that goes out the door, but we could sure have them available for anyone with "wiltage".
Update will follow, when I get a chance to figure out the easiest way to make them in some kind of volume.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 11-01-2013, 08:59 AM   #695
Ghost_Mutant
looking for bionics
Oddometer: 713
Ned,
I hope you have a test plan in place to figure out the optimal length of the dowels.
The reason I took such care to creep up on the right length with mine is because my RAM balls were already crushed quite a bit. Not having used the RAM system before, I didn't want to make the dowels too short which I thought might further reduce the life of the rubber balls.
The more sphere shaped the RAM balls are, the easier it is to adjust the angle. With the 'set' that mine now have, I find making fine adjustments to the clamp to ball angle to be limited to what I already have crushed into them That may be normal for everybody, wiltage or not, but I only have my one example set to draw experience from.
Of course this is not a big deal because the mirror side is still adjustable as if it were new.
The optimal length for a new/non-deformed RAM ball is probably longer than my dowels, but that's just a guess that should be tested.
All I can tell you is that I haven't made any further adjustments to my setup since I first posted about it. At some point I may have to shorten them some more due to wear/age, but it hasn't happened yet
The other reason I took the time to creep up on the dowel length for both the left and right side separately, is that I didn't know if the RAM clamps themselves were manufactured to tight enough tolerances to have the same length dowels. In retrospect, a difference of 0.3mm is probably not enough to justify custom lengths. And that difference is probably due to the crush difference between my right and left RAM balls.
You've probably already thought about this. At least the thread is now bumped back onto the first page
Old 11-01-2013, 03:53 PM   #696
neduro OP
Addict
neduro's Avatar
Oddometer: 11,965
One of the things that is tough about this is that I still haven't had a "wilting" mirror, so while I have no doubt that this happens, the ones on my bikes have all stayed put, making it tough to say if a change is a fix.
It seems like consistently a few percent of folks have the issue, leading me to wonder what the variable is. My best guess is that the aluminum plug inside the rubber of the ram ball is not round, meaning that there are presumably angles at which the ram ball is more firm, and less firm, so depending on how the threads are cut on a given bike, the RAM arm may be gripping at a different angle relative to the internal features hidden under the rubber of the RAM ball.
But I'm not very convinced of this explanation. :-)
In any event, I'd love to come up with a solution to offer people that have the issue. One option we already do is that we keep some 1" heat shrink tubing around, and are happy to send that to anyone who has a problem- it seems to universally solve it. A second are the pins you've (ingeniously!) come up with.
I was casting around the shop this week trying to figure out what I could use short of machining a part, and my eye settled on a clothes hangar, which appears to be roughly the right diameter, etc, to fit inside the spring. I was thinking of hacking one up and seeing how it worked, my suspicion is that there would be a small range that would accomplish a firm (enough) grip on the rubber ram ball while giving more strength with which to grab the Doubletake ball. But I have not yet done so, it wasn't the alligator closest to the boat, so to speak, this week.
Thought about, but haven't acted on yet. Fever of 104 Monday night and still not feeling right! But like you say, at least we're back on the front page.
Old 11-03-2013, 07:44 AM   #697
Ghost_Mutant
looking for bionics
Oddometer: 713
I always thought it was the vibrations that caused the wilting. My handlebars are mounted to the old style rigid upper clamp. Combine that with some out of balance tires with just the right vibrations at 50 mph, allows for the rubber RAM ball to give/oscillate just enough for the wind to push over the mirror. At least that was my theory.
After my last tire change, I took extra care to balance the tires. Noticeable reduction in vibes. Since I bought another pair of Doubletakes when on sale not too long ago (for my other XR which I want to plate), I will swap out mirrors and see if the wilting still occurs. If so, then there will be one bike on the front range that wilts. I'm in Broomfield.
Perhaps consider adding weights to the front wheel to unbalance it on purpose for testing?
Or consider building a test bed using a VSR drill clamped down to a 2x6. Use an offset weight in the drill's chuck to create the vibes. Mount the mirror on the board and then take a leaf blower to simulate riding in the wind
Then you can add the dowel/spacer and test the effectiveness. Compare with heat shrink.
Product testing
Whatever you do, use a better material for the dowels you send to customers, not the clothes hanger wire. Too much corrosion in most places of this world
Ghost_Mutant screwed with this post 11-03-2013 at 07:45 AM Reason: typo
Old 12-07-2013, 10:21 PM   #698
Falconfixer
It is what it is....
Oddometer: 576
Just ordered a pair for my KTM from the Doubletake website about two minutes ago. Didn't even think to look on here for a discount code for us inmates before ordering. Doh! Thems the breaks. Looking forward to the mirrors showing up next week though.
Falconfixer screwed with this post 12-07-2013 at 10:21 PM Reason: Spelling
Falconfixer is offline   Reply With Quote
Old 12-26-2013, 06:00 AM   #699
spaceman_spiff
spaceman_spiff's Avatar
Oddometer: 881
Is there a current discount code for advriders?
spaceman_spiff is offline   Reply With Quote
Old 12-26-2013, 06:42 AM   #700
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,046
Is there someone that has a picture of this "wilting"?? I do not think mine is doing it any bike( on either bike-KTM or Yami)...or just do not worry about because I accept that a bike with knobbies is gonna have vibes on road.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is online now   Reply With Quote
Old 12-26-2013, 06:47 AM   #701
neduro OP
Addict
neduro's Avatar
Oddometer: 11,965
I just made "2013wasawesome" which will give you (and anyone else) 10% off until the end of the year.
Old 12-26-2013, 06:56 AM   #702
Maoule
Maoule's Avatar
Oddometer: 497
FWIW, I made my dowels from 1/4" aluminum rod purchased from Home Depot. It was an exact fit for the spring.
Maoule is online now   Reply With Quote
Old 12-26-2013, 09:43 AM   #703
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,944
wilting for me isn't a "road" issue....it is a "whoops" issue....it just won't hold off road....
Old 12-26-2013, 11:10 AM   #704
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,046
Funny..soon as I am offroad...I fold mirror in....as do my buddies. Who needs mirror through technical offroad stuff?? :what:
Sent from my SCH-S738C using Tapatalk 2
Old 12-26-2013, 11:59 AM   #705
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,944
I do
nice to be able to see that I still have the rider behind me without slowing down...
Times are GMT -7.   It's 09:27 AM.
