Old 04-09-2014, 10:51 AM   #751
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
Thumb stardom!
...I do believe these lil guys where featured in Motorcyclist this month...good for Ned!
Only mirrors I use....IF THAT'S WORTH ANYTHING ;)
Rapid Dog screwed with this post 04-09-2014 at 11:08 AM
Rapid Dog is offline   Reply With Quote
Old 04-12-2014, 09:09 AM   #752
Tallbastid
Let's get tropical
Oddometer: 1,341
I'll never go back to eom mirrors, double take is the way to go!
2013 Tay-Nay-Ray
Tallbastid is offline   Reply With Quote
Old 04-12-2014, 08:16 PM   #753
ssevy
Oddometer: 884
Quick mounting question
I finally got my 95 Tiger out of winter storage this weekend, and took off the stock mirrors and replaced them with my new Double Take mirrors. I noticed there was no place to put a wrench when tightening the balls into the threaded sockets on the bars. I tightened the arms tight and then used them to hand tighten as much as possible. The stock ones had a hex shape to use a 14mm wrench. Am I missing something regarding tightening these into place?
ssevy is offline   Reply With Quote
Old 04-12-2014, 09:44 PM   #754
the_real_wild1
Oddometer: 146
I used vide grips on the aluminum. Also one thing I have discovered. I can't explain why but I had the issues other did with the mirrors moving. One day I moved the arms 180 degrees so the internal spring is at the top instead of the bottom. Now the mirrors don't move. So if they move when going over bumps see if the spring is below the knob or above it. Move it to the top if not and retry.
Men do not stop playing because they grow old, they grow old because they stop playing - Oliver Wendell Holmes
the_real_wild1 is offline   Reply With Quote
Old 04-13-2014, 08:46 AM   #755
ssevy
Oddometer: 884
Thanks for the tips!
Old 04-13-2014, 08:57 PM   #756
coyote223
Oddometer: 42
That's what I was wondering myself. I used pliers, but they really tear up the aluminum. They came loose on my ride today. Are you supposed to lock-tight them to keep them from moving?
coyote223 is offline   Reply With Quote
Old 04-14-2014, 05:56 AM   #757
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,684
Clean all the threads and Loctite worked for me. Some of the threads on one of my mounts were a bit screwed up from the factory mirrors so I drilled in from the side and put a pin through it.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 05-02-2014, 03:51 PM   #758
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,108
Coupon Code ?
I was ordering and there's a "coupon code" box on the checkout page. Is there a code ?
GlennR is offline   Reply With Quote
Old 05-03-2014, 04:48 AM   #759
Baggi'tard
Assventure rider
Baggi'tard's Avatar
Oddometer: 807
fan
great product, had one on my 640ADV for a year now, works perfectly to move out of the way when hit. Congratulations on the short review in Motorcyclist.
The Tellico Adventure Trail and Tellico Farmhouse Inn Loops
"Welcome to Tennessee, the patron state of shootin' stuff." Bob Lee Swagger.
KTM 640E/ADV, KTM Duke II, KTM 990 ADV
Baggi'tard is offline   Reply With Quote
Old 05-03-2014, 03:15 PM   #760
Baja Ho
Baja Ho's Avatar
Location: Central Coast, CA. USA & Cabo San Lucas, Baja Sur
Oddometer: 773
Originally Posted by glennr View Post
i was ordering and there's a "coupon code" box on the checkout page. Is there a code ?
+1
Baja Ho is offline   Reply With Quote
Old 05-03-2014, 05:41 PM   #761
neduro OP
Addict
neduro's Avatar
Oddometer: 11,957
Originally Posted by Baja Ho View Post
+1
None right now, we can barely keep up!
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 05-04-2014, 10:11 AM   #762
Somber
Oddometer: 350
I find the easiest way to "tighten" the ball adapter is to use a RAM arm - I just use a longish ram arm (can have the mirror on the other end, or put another ball adapter on that end, or just leave it empty and bottom the two clamp faces against each other), then position it parallel to the bars for max torque capability, then I crank the arm tightener wing nut it down until the arm is clamped extra tight, then I "tighten" the ball into the socket using the RAM arm as the lever/torque arm.
The arms, especially the metal ones, can put a pretty amazing clamp on the ball adapters, which is why you can get them tightened up enough for the mirrors to not move in all but the worst rough and vibey situations. And remember, you are aren't likely to have your arm and mirror in that max torque to loosen/tighten position during normal riding so it isn't like the wind or a branch is likely to break it back loose. There is plenty of "sticktion" to get a very strong torque. Some blue thread locker on top of that can't hurt.
Anyway - this method - no tools needed, you can use what you are installing as the tool, you don't chew up the ball or the stem with pliers/grip teeth.
Hope this helps
Somber is offline   Reply With Quote
Old 05-29-2014, 01:56 PM   #763
tyrsmkkyle
off the ground.
Oddometer: 250
I called and left a message, my local dealer
Has been trying to order from you since tuesday
With no return call, theres no message stating
Your out of town. Is the number on your site
The correct one?
tyrsmkkyle is offline   Reply With Quote
Old 05-30-2014, 07:30 AM   #764
Plane Dr
Plane Dr's Avatar
Oddometer: 857
Preferred a set of these a couple weeks ago. Awesome so nice to see again.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 06-02-2014, 10:43 PM   #765
AteamNM
Wonna Be ADVrider
AteamNM's Avatar
Oddometer: 3,775
Ned donated a DT mirror and Ram mount for a NMOHVA dual sprt event in northern New Mexico last weekend. The crowd was drooling on their ticket when this was given away. I did not win. Everyone there was wanting that bad ass mirror. I love mine on my DRZ. Many in our group were using Double Take, many that didn't will soon be me thinks.
Thank you Ned.
AteamNM is offline   Reply With Quote
Times are GMT -7.   It's 01:54 AM.
