Old 04-19-2015, 08:22 PM   #1
ManitouMoto OP
Oddometer: 86
Another HES failure
My 98 R1100GS is a victim of HES failure . Anyone want to sell a good used one, rebuilt or even new?
98 R1100GS, 99 DR650se, 2001 KTM 200 EXC
ManitouMoto is offline   Reply With Quote
Old 04-19-2015, 08:48 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,406
PM GSAddict He can fix you up. Or, www.beemerboneyard.com
JimVonBaden is online now   Reply With Quote
Old 04-19-2015, 08:56 PM   #3
dfwscotty
dfwscotty's Avatar
Oddometer: 3,414
While you have them on the line order a new belt for it too while you've got it apart
Traffick911
1999 BMW 1100GS
2012 Kawasaki Concours
dfwscotty is offline   Reply With Quote
Old 04-19-2015, 10:37 PM   #4
Corroded
Oddometer: 183
If you're not in a rush and want to fix it cheap you can buy the sensor elements from Alibaba direct from China, I made inquiries when I found mine was busted.
I didn't want to wait so I bought from BB
Corroded is offline   Reply With Quote
Old 04-20-2015, 03:51 AM   #5
rvt
Big Fat Trail Bikes
rvt's Avatar
Oddometer: 1,339
Good to know.
But usually the sensor is fine, its the cable insulation that perishes.
Some have pulled new silicon wires into the existing sheath.
I bought a waterproof setup from Cata Dan. Still going strong.
Cheers, RVT
This week's ride: http://share.findmespot.com/shared/f...Vcz6Icqrhsbbpq
rvt is offline   Reply With Quote
Old 04-20-2015, 09:57 AM   #6
Corroded
Oddometer: 183
Originally Posted by rvt View Post
Good to know.
My sensors were DOA, the alternator belt had failed badly and wrapped itself around the crank pulley behind, destroying the sensors.
Old 04-20-2015, 02:56 PM   #7
rvt
Big Fat Trail Bikes
rvt's Avatar
Oddometer: 1,339
Bugger.
Cheers, RVT
Old 04-20-2015, 10:07 PM   #8
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,767
Will you need a new interrupter cup also?
I'm now so old I forgot my last birthday. Does this make me younger?
def is offline   Reply With Quote
Old 04-24-2015, 04:24 PM   #9
ManitouMoto OP
Oddometer: 86
Sent it to GSAddict for rebuild/upgrade
I'll repost when i get it back to let you know how it worked out.
thanks,
Mark
ManitouMoto screwed with this post 04-24-2015 at 05:56 PM
Old 05-29-2015, 08:39 AM   #10
ManitouMoto OP
Oddometer: 86
Okay, I have had it back together for several weeks now and everything is fine. I just scribe marks around the AGS plate before removing it and reinstalled it to those marks. No need to reset position with LED light as some described. Notch on lower crank pulley lined up and installed just fine.
Old 05-29-2015, 01:57 PM   #11
dfwscotty
dfwscotty's Avatar
Oddometer: 3,414
Scribed mark worked for me too.
Nice work.
Traffick911
1999 BMW 1100GS
Times are GMT -7.   It's 08:54 PM.
