Old 04-22-2010, 09:38 PM   #1
Mr. B. OP
Climate Controlled
Mr. B.'s Avatar
Oddometer: 148
Airhead Wiring Question
I'm wondering if anyone out there has moved the fuses in the headlight bucket to a remote location. Say under the seat or somewhere easily accessable. I've got a '74 R90/6 with an "S" fairing on it and am concidering this mod. using car type fuse holders. Any advice out there? Wire size etc.
Thanks, Brent
Mr. B. is offline   Reply With Quote
Old 04-22-2010, 09:47 PM   #2
norton73
drinkin'
norton73's Avatar
Oddometer: 8,306
I'm with you there. I'm putting a R100RS back on the road. scares me to think I might have to pull the fairing just to replace a fuse.
Luftmiester made a relocation kit, but it's NLA.
Surely some one has a better idea.
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 04-22-2010, 10:31 PM   #3
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
Photobucket
Used these two fuses on my RS
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 04-22-2010, 10:37 PM   #4
Middleweightboxer
Middleweightboxer
Middleweightboxer's Avatar
Oddometer: 680
I have soldered blade type fuse holders to the existing fuse posts and left them in the shell on S bikes and run the wires through the existing holes in the headlight shell on RTs leaving the new fuse holder exterior to the shell. Also I have used panel mount Buss fuse holders again mounted exterior to the headlight shell. Both worked fine but after modification I was more worried about shorts than blowing a fuse. In hind sight the original design and fuse was fine and I never burned a fuse other than from my probing.
Bill
Tiger 800XC, R1, FZ1, RD400, CB400F
R80ST, R90S, Monster S2R, Penton 125 JPS, T25T
Middleweightboxer is offline   Reply With Quote
Old 04-22-2010, 11:03 PM   #5
Kismet
vagrant philosopher
Kismet's Avatar
Oddometer: 387
Years ago had a 90S with Shoei fairing with external fuse holders. Worked a charm, but don't remember ever having a problem with them.
Now, the /7 with the Rabid Transit always needed fuses for one reason or another, and for each change, had to drop the fairing. I was younger then.
Kis
enjoy every sandwich
'75 R90/6
'78 R100/7, well really, R80/7
'87 Radian/fj600
'81 C70--IT'S ALIVE !!!!
Kismet is offline   Reply With Quote
Old 04-23-2010, 07:10 AM   #6
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,474
Front glass intact with the rubber surround, headlight off, one screw..there it is. No need to pull the fairing.
It is tedious though, when the fuses are easy enough to relocate. Plenty of weatherproof modern fuse holders available.
boxerboy81 is offline   Reply With Quote
Old 04-23-2010, 08:13 AM   #7
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
I just did this on my 79 RS. The front glass (plastic) must be removed to access the 4 screws, then the rubber channel pulls right out. Not too difficult. And even with 30 year old rubber, still supple and no damage.
Neither the factory manual or Hayes addresses this set up and their procedures are for different types. No way mine can be detached with the glass in place.
I did a fuse relocate to the dash of my S fairing years ago. 65k miles and never blew a fuze. I have left mine as is. Inside shell was all clean and dry. And after getting the light out, it just isn't that difficult so why bother.
DoktorT is offline   Reply With Quote
Old 04-23-2010, 08:18 AM   #8
Pelicanglider
Oddometer: 231
Check Eastern Beaver for some neat electrical solutions just like you are talking about. They sell assembled fuse blocks meant for accessory circuits but looks like they could be easily adapted.
Pelicanglider is offline   Reply With Quote
Old 04-23-2010, 08:34 AM   #9
Jasper ST4
Guest
Oddometer: n/a
I had mine relocated in holes in the shell with the screw type cap, standard glass holders, back when I had a Luftmeister, then Rabid Transit, then RS. It was very rare that I blew a fuse, usually it was me fumbling around in the garage.
I'm back to stock since I have removed the RS fairing and may not put it back on. It wasn't very time consuming to get into the shell with the RS fairing, not sure about the S but it looks easier.
Old 04-23-2010, 09:21 AM   #10
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
As I recall, pulling the headlight with the S fairing is no problem at all. Just tilt the pod back to access the lower rim, pull it loose then tilt the pod down to pop off the rim at the top.
I have seen the Eastern Beaver goods and they will be where I go for setups I might need in the future. Pricing is such that you will not save much out of pocket to make up your own from scratch and I would expect the quality to be better unless you have the spendy, quality crimpers to do it right.
Old 04-23-2010, 09:29 AM   #11
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,014
Used to be a product called move-a-fuse advertised in BMW MOA magazine designed specifically for this purpose.
Since I find fuses burn out maybe only every 15 years, I've never contemplated it.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 04-23-2010, 12:03 PM   #12
Mr. B. OP
Climate Controlled
Mr. B.'s Avatar
Oddometer: 148
Thanks for all the input. I never have fuses blow out either. Just had everything apart and thought I'd save myself some grief if one blew out on a road trip. You know how it is when you get a wild hair up your ass, and think something sounds like a good idea. I'd rather be putting some miles on than sitting by the side of the road with too much stuff torn apart. I may rethink this great idea. Thanks again
Old 04-23-2010, 12:32 PM   #13
bmwloco
bmwloco's Avatar
Oddometer: 1,417
I think Rick at Motorrad Elektrik has a kit for moving the fuses.
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Old 04-23-2010, 06:12 PM   #14
Mr. B. OP
Climate Controlled
Mr. B.'s Avatar
Oddometer: 148
Just wondering if there are any downsides to moving the fuses. I dont want to mess up the circuit by using the wrong size wire,extending the fuses too far away etc. My worry is that the circuit functions as it should. Any electrical gurus have some input. Thanks
Old 04-23-2010, 06:22 PM   #15
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,801
In direct current applications, the length of wire and ampacity of the wire are directly related. In other words, make the wires as short as possible with a good thick wire! In general, and within reason, a 15 amp fuse requires a 14awg , and a 20 amp fuse requires a 12 awg (don't know the metric equivalents, but for the bike, 14 ga. should be fine if you are only running a couple of feet....
And don't forget that one side of the fuse is un-fused, i.e. unprotected by any fuse until it goes "through" the fuse. Again, short wire runs are far better than long ones.
And, frankly, rather than using a fuse, use a pop-up circuit breaker.... you could mount one in a hole through the headlight shell, with the wiring within the shell, quite easily. To reset, you simply push the "pop up" back down...
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Times are GMT -7.   It's 04:52 AM.
