Old 04-24-2010, 07:32 PM   #1
IBJim OP
WhoUB?
IBJim's Avatar
Oddometer: 307
Unbleedable rear brake on 990 (ABS)??
My rear brake on my 07 990 Adventure w/ ABS is driving me (more) crazy and I could use some help! Had next to no rear brake so I tried to bleed--no luck. Rebuilt the rear master cylinder and bled (conventionally)--no luck. Just tried the Mity Vac--no luck. Still have air in the system (continue to produce bubbles when bleeding conventionally).
I think I have an air leak somewhere and I keep pumping air back into the system. If the brake light switch has failed, would this allow air to enter? My brake light isn't working but I'm not sure if this is just due to lack of pressure at the switch. Anything else I should check??
Thanks!!
IBJim is offline   Reply With Quote
Old 04-24-2010, 08:58 PM   #2
brents347
KOTW 2010 Finisher
brents347's Avatar
Oddometer: 3,038
Your brake light switch is NOT a pressure switch. If the switchisn't working than I would start by assuming that it has failed and is introducing air into the system.
Brents347 Truckee, CA.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
brents347 is online now   Reply With Quote
Old 04-24-2010, 09:04 PM   #3
dmckiwi
Louder is always better
dmckiwi's Avatar
Oddometer: 66
I had the same issue with my 950, later found out I had to push the caliper in on the pins to get all the air out, there was a pdf of the service manual showing how to do it, after that it was great and never went away again.
In the words of Juan-Manuel Fangio "Brakes they only slow you down"
dmckiwi is offline   Reply With Quote
Old 04-24-2010, 09:24 PM   #4
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
You can find the correct bleeding procedure as part of the recall notice for the 950s, here.
brents347: I'm pretty certain that switch is pressure operated (not sure exactly what you mean by "pressure switch" though).
jamesbrown is offline   Reply With Quote
Old 04-24-2010, 09:37 PM   #5
big adv
I need supervision
big adv's Avatar
Oddometer: 1,050
You could also try using a large syringe (70-100cc aval at a vet supply store) to back bleed the system from the caliper, fill syringe with fluid, purge air from it and hose, connect to bleed nipple, and push the fluid to the master. On the bikes with ABS, the HCU sits at the highest point in the system, which can make bleeding it difficult. you can also try cracking the line loose (the one to the caliper) at the HCU and bleeding there first. then do the caliper.
Earl
BA
My dad's a TV repair man, he has an awsome set of tools. We can fix that!
big adv is offline   Reply With Quote
Old 04-25-2010, 01:44 PM   #6
dabracing
dabracing's Avatar
Oddometer: 441
Another reason to hate ABS.
07 950 SE
05 RMZ 450
08 R1200RTP
05 CRF 80
06 TTR 50
dabracing is offline   Reply With Quote
Old 04-26-2010, 02:02 PM   #7
IBJim OP
WhoUB?
IBJim's Avatar
Oddometer: 307
Thanks for the ideas guys. FYI- I LOVE the ABS. It's this bleeding issue (which was also a problem on the non-ABS 950s) that I could do without!
Old 05-18-2012, 01:56 AM   #8
Yascher
Yascher's Avatar
Oddometer: 301
So does anyone have a 100% effective procedure to bleed ABS, or bleeding, riding with ABS in dirt, bleeding again and then rifing with ABS working and so on till you give up or the brakes become responsive?
Yascher is offline   Reply With Quote
Times are GMT -7.   It's 11:37 AM.
