Old 06-13-2010, 08:16 AM   #121
tirebiter
tirebiter's Avatar
Oddometer: 468
You scoot's looking Good!
I'm on my 5th? KTM since '79, Great bikes.
Keep an eye on those subframe bolts, little buggers like to work loose.
If you have any play in your shock to swingarm, your heim joint is probibly shot. I've found they usually last about 2 years if the bike's ridden every weekend.
The OEM joint's not too hard to replace, but this one's easier and comes with a zerk.
Available here..
http://www.shop.synergyseals.com/pro...6&categoryId=3
I'm 6'2", tried the Fastway footpegs in the lower position, had a hard time adjusting my brake lever to match- my SIDI boots might have had something to do with it. Went back to the stockers, all good again.
If you'd like to try the Fastways, shoot me a pm- I'll drop'm in the big brown truck, N/C..
As far as bikes that sorely need a makeover..My KTM can barely stand being in the same garage..
tirebiter screwed with this post 06-13-2010 at 08:25 AM
tirebiter is offline   Reply With Quote
Old 06-13-2010, 08:25 AM   #122
nevada72 OP
Klaatu barada nikto
nevada72's Avatar
Oddometer: 538
Available here..
That's a very kind offer on the Fastways - thanks! I had them on other bikes - nice platform. But, I'm not displeased with the stockers on the KTM. I know the Fastways would get me a little closer to the bars when standing, but I worry about the levers and especially clearance. Another rider and I noted that were our pegs any lower we would have been scraping rocks in some high and narrow sections on Porterfield Trail in Upper Michigan.
As you know, being tall we learn to compensate. It may translate into what looks like poor technique, but bikes aren't designed for 6-2 and up guys. Anything we do to them is a band aide anyway. As we all know, some band-aides are better than others.
I'm keeping an eye on the swingarm bushing. I inspected it and it looks good so far. This winter I'll end up doing a whole bunch of other stuff such as those zerked bushings.
edit - that 'Berg looks like it has a lot of 07 exc parts on it! Did they wrap the exhaust left just to be different, or does it work better over there?
2003 DR650
1976 Triumph Bonneville
2014 Harley Davidson Street Glide Special
1964 Honda Dream
1967 Honda CA Touring
nevada72 is offline   Reply With Quote
Old 06-13-2010, 08:55 AM   #123
tirebiter
tirebiter's Avatar
Oddometer: 468
Everything's bassakwards on the Berg- chain, clutch, exhaust, kickstarter, etc.
The Bergs share allot of the same parts with the KTMs- suspension, wheels, brakes, plastic bits and such. The thing it doesn't share is the weight.
It's actually easier to work on than the RFS, more room to get your hamfisted mitts in.
As far as bars go, The Orange 300 in my orig pic has Renthal "Carmichael High" bend, the white 355 has Trailtech "X" bars. I like them both about the same, nice & tall with minimal pullback.
tirebiter screwed with this post 06-13-2010 at 09:01 AM
Old 06-13-2010, 10:22 AM   #124
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 10,671
Funny you should mention the Fastways...I was just singing their praises yesterday, that huge platform saved my ass on more than one occasion, and being 6'3" with a size 14 foot I love the extra room. Had to put a larger brake pedal on though.
Love those white plastics....been thinking about changing for a while now.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is offline   Reply With Quote
Old 06-13-2010, 03:41 PM   #125
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 2,969
On the Motosportz stabilizer - I may be rethinking that one. At 1st I liked the idea of dampening both ways. It works great on fast fire roads. But, on tight single track it's kind of a pain. Even turned all the way down I feel like the steering is very sluggish. My bike's response to my inputs are delayed a split second which throws my line off - especially on single track. I don't like it. I'll try to adjust, but I'm not sure this is gonna fly. I wish the Motosportz would go completely inactive on it's lightest setting.
How about Scotts? Do they go full off? Are they better on single track because the dampening kicks in on turn and not return?
There supposedly is Scotts "dirtbike" damper that will only damp on turn and not return. I'm puzzled with that feature. How can a mechanical/hydraulic device tell whether your left bar end is in "return" or your right bar end is in "turn"? I dunno...
What I know? You can adjust a Scotts to the radius where the damper is active in the lock-to-lock bar turn. It can be a narrow radius, say 10 degrees right/left of center, all the way to damping in the full lock-to-lock range. See page 8 of this manual: http://www.scottsperformance.com/litrack/257.pdf
One added benefit of the Scotts I really like is a high speed damping circuit. The high speed damping is still 100% active when you have the manual/low-speed damping adjustment set at full loose. (see pg 6 of the manual above.) In other words, if you're running the adjuster all the way loose and you whack that rock or root, the high speed damping will keep the bars from getting ripped out of your hands.
Scotts FTW!
nevermind is offline   Reply With Quote
Old 06-18-2010, 05:35 PM   #126
nevada72 OP
Klaatu barada nikto
nevada72's Avatar
Oddometer: 538
Lighter throttle spring for wimpy wrists
I ditched the return cable already. Not good enough. I like a light throttle action. The Tokyo Mods spring (on right) helps a lot. A G2 cam throttle tube will probably help even more.
2003 DR650
1964 Honda Dream
Old 06-11-2013, 06:07 PM   #127
Petrolburner
Noise Maker
Petrolburner's Avatar
Oddometer: 557
Thanks for the info!
2007 Honda XR650R, 2005 Gas Gas EC 250, 2004 Sherco 2.9, 2002 aprilia ETV 1000 Caponord, 1993 Kawasaki KLX 650
Petrolburner is offline   Reply With Quote
Old 08-26-2014, 01:31 PM   #128
Longdraw
Oddometer: 4
Very good info! I just bought a 2007 KTM 525 EXC with 1200 miles on it. Went riding and found out it's geared too low for my taste. I couldn't even go 70mph without the motor whining so I kept it at 55mph. Good for trails though. Going to gear it higher with a 14/48 or a 15/46. Any recommendation of what type of motor oil to use? I am new to owning a KTM. I've had Husqvarna and Honda in the past. Any advice sure would be helpful! Also looking for a good rear rack as well. I saw the one on this thread so I emailed them. I hope they reply.
Colin
Longdraw is offline   Reply With Quote
Old 08-26-2014, 04:15 PM   #129
ChasM
Oddometer: 269
I prefer 14/48 for a good overall gearing ratio. 14/48 is actually the stock gearing for 520/525's prior to 2007. It cruises nicely at higher speeds however it is a little tall for the tightest single-track but the Revloc auto clutch easily compensates for that. The auto clutch actually makes 1st gear a very useable gear unlike the useless super low granny gear in the low geared bikes. I suspect that 15/46 would too high for most any kind of riding.
Trailbike Sportsmen Assoc/AMA
'14 BMW R1200GS LC
'09 Beta 565 RS (with Revloc)
'08 KTM HTR 350 XCF-W(Revloc
'74 Norton 850 Commando
ChasM is offline   Reply With Quote
Times are GMT -7.   It's 05:47 AM.
