Old 04-27-2010, 10:19 PM   #16
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,944
Don't forget the pressure regulator. While there haven't been many reports of failure, there have been a few.
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 04-27-2010, 10:56 PM   #17
wrysingfeenix
Dust off those ashes
wrysingfeenix's Avatar
Oddometer: 633
Originally Posted by bananaman
The fuel pre-filter... it's a woven nylon, with a steel spring inside. Both ends were open. I stapled one end, and used baling wire to sew the other end. I don't know why it came apart.
Is there any chance that some of that nylon got into the fuel lines?
---'99 BMW R1100GS
---'96 BMW R1100GS Mod Project ???
---'80 Honda CB750 Street Tracker Project
---'09 Vespa GT200 Granturismo
wrysingfeenix is offline   Reply With Quote
Old 04-28-2010, 01:19 AM   #18
Zoef zoef
Oddometer: 373
Sir,
If pressure regulator fails, ie pressure much too high -> very low flow of petrol, the high pressure could also lead to fuel pre-filter failure.
Zoef zoef is offline   Reply With Quote
Old 04-28-2010, 09:22 AM   #19
bananaman OP
transcontimental
Oddometer: 7,541
It didn't look like any of the nylon had come off, but I have no idea why it would have burst at both ends. Does that nylon break down over time? It never seems to get very hot... even sitting in the sun, the tank is only "warm."
I am Charlie.
bananaman is offline   Reply With Quote
Old 04-28-2010, 09:25 AM   #20
bananaman OP
transcontimental
Oddometer: 7,541
[quote=Zoef zoef]Sir,
If pressure regulator fails, ie pressure much too high -> very low flow of petrol, the high pressure could also lead to fuel pre-filter failure.[/quote
Hmm... could you explain this to me? Are you saying that the fuel pump could try to suck extra-hard, thus somehow crushing the pre-filter?
After this experience I'm wondering if on another long adventure, I should pack a spare fuel pump? They're not very big and they don't look hard to replace.
I am Charlie.
Old 04-29-2010, 04:28 AM   #21
GeorgeinVA
Beemers Uber Alles
GeorgeinVA's Avatar
Oddometer: 603
[quote=bananaman]
Originally Posted by Zoef zoef
Sir,
A fuel pressure regulator failure can result in high or ow pressure. If a high pressure failure you may pop a line off, rupture a line, or split the aluminum housing of the fuel filter. I have seen all three happen from quick disconnects that were not plugged and clamps left on lines, return line that is.
As for the nylon pre-filter, they split on the ends fairly regularly and should be checked every time you change the filter.
GeorgeinVA is offline   Reply With Quote
Old 04-29-2010, 04:54 AM   #22
koenig
koenig's Avatar
Oddometer: 117
I don't know if this helps, but.... I had a similar problem with a car. I had all the same indications as you. Not enough fuel thinks I. Screw about with mixture settings (eay on older MB's). No good got worse. Found damaged fuel line. Easy fixed. Still no go, much the same as your problems. In the end found that it was too rich. Leaned it off, goes great. In the mean time it had fouled spark plugs, had to be replaced. (Were they all black and sooty?) I am thinking in your case, bad fuel or fuel with water in it. Ethanol based fuel (pet hate) which has attracted too much water? Me thinks; if it is mechanical, the fault will be there all the time. What is transient? Fuel. Good luck.
If it doesn't hurt
Your not doing it right.
koenig is offline   Reply With Quote
Old 04-29-2010, 06:18 AM   #23
bananaman OP
transcontimental
Oddometer: 7,541
hmmm...
When I'd add gas, it would bog down, as if it was WAAY too rich. But isn't the mixture controlled my the fuel injector controller thingy?
I am Charlie.
Old 04-29-2010, 06:20 AM   #24
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,097
did you readjust your TPS voltage when you swapped Bananaman?
maybe its not seated correctly in the slot that turns it?
I would think it being bad or badly adjusted would do as you describe.
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 04-29-2010, 12:38 PM   #25
bananaman OP
transcontimental
Oddometer: 7,541
Now you lost me. TPS voltage adjustment?
The only things I swapped were the fuel filter and the plugs.
I am Charlie.
Old 04-30-2010, 06:21 PM   #26
mouthfulloflake
Not afraid
Oddometer: 17,097
http://advwisdom.hogranch.com/Wisdom/tps3.1.pdf
Old 05-02-2010, 11:23 PM   #27
BobLoblaw
Comfortably Numb
BobLoblaw's Avatar
Oddometer: 1,507
BANANAMAN WHAZZUP
Did you find the problem?
Ride till you can't - Marty Hill
BobLoblaw is offline   Reply With Quote
Old 05-03-2010, 08:49 AM   #28
bananaman OP
transcontimental
Oddometer: 7,541
Originally Posted by BobLoblaw
BANANAMAN WHAZZUP
Sorry- last week was super-busy. I'll take the pig to the dealer in Beaver Dam this week.
I live an hour away from the closest dealer, and the only dealer I trust. There are a few mechanics here in Madison, but I prefer Jason & Co in Beaver Dam. The process is complicated- I have to take the bike to my office, where I have a loading dock. Then I have to run home and get my truck. At my office I need at least one other person to help me, so that I don't drop it in the truck.
Stay tuned...
I am Charlie.
Old 05-18-2010, 11:54 AM   #29
bananaman OP
transcontimental
Oddometer: 7,541
Art, the owner of Mischlers BMW: "Its running on one cylinder. Intermittently." He tapped the exhaust pipes. "The left one."
"You cracked the coil when you submerged it." Referring to the river in Panama.
Suddenly I realized that this problem started... in Ecuador. In a pissing rain from the Colombia border all the way to Quito. So it's probably a cracked coil or a bad sparkplug wire.
They'll know more on Thursday.
I am Charlie.
Old 05-19-2010, 04:27 PM   #30
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,560
Originally Posted by summerinmaine
When you get too old to serve as a bad example, you can always give bad advice.
'13 R1200GS
'08 WR250R
Dahveed is offline   Reply With Quote
Times are GMT -7.   It's 05:29 PM.
