Old 04-30-2010, 12:45 PM   #1
MCCadders OP
Oddometer: 134
MRA Windscreens on an 800GS
Anybody got input on MRA Vario windscreens for an 800GS? Any good? Quality? Alternatives thats aren't so pricey I'd have to sell my first born?
The stock one is fine for peeing about, but as good as a chocolate teapot on the highway!!
Cheers
Cadders
2000 F650GS (2003-2010)
2009 F800GS (2010 -????)
"Just drop yer elbow and give 'er, once you're committed f*ckin hang on" DRCOOL EOAR 2012
MCCadders is offline   Reply With Quote
Old 05-03-2010, 02:19 AM   #2
syaufu
Oddometer: 144
windscreen
don't know what too expensive is but the Aeroscreen is excellent..bj
syaufu is offline   Reply With Quote
Old 05-04-2010, 01:02 PM   #3
Barbadi
Oddometer: 132
never and I mean NEVER...
buy an MRA screen. I got one for my F 650 gs 2008 mod. On city speeds its a tiny bit better than the low factory item. It diverts your air stream from your neck to your face and uper helmet. Over 120 klm/h the air stream hits the helmet mid screen in a way that you caqnt see anything from the vibration. I am 173 cm tall and my helmet is a bmw integral one. Further more, I send the company an email requesting any help or suggestions. No answer. So never...
Barbadi is offline   Reply With Quote
Old 05-04-2010, 03:48 PM   #4
MCCadders OP
Oddometer: 134
Thanks both, I'll keep looking at other options then, or sell that kidney i've been keeping for a rainy day and get the Desierto 3!
Cheers
Cadders
Old 05-10-2010, 12:05 AM   #5
Ide508
Easy Does It...
Oddometer: 42
another consideration...
I have recently swap the OEM windscreen of my 800 for a Touratech highscreen + a MRA spoiler on top of it.
As far as I'm concerned, it's quite close to perfect !
Ide508 is offline   Reply With Quote
Old 05-10-2010, 05:01 AM   #6
Tor
Imported Viking
Tor's Avatar
Oddometer: 835
How tall are you?
2005 ST1300 / 2015 BMW R1200 GSA
Tor is offline   Reply With Quote
Old 05-10-2010, 06:59 AM   #7
Ide508
Easy Does It...
Oddometer: 42
1.83 Meter, a lot less wind noise in the helmet than with the oem screen. It think that it would be absolutely perfect if I were 1.80 M !
And in case you've asked helmet is a bmw system 5
Ide508 screwed with this post 05-10-2010 at 07:06 AM
Old 05-27-2010, 11:36 PM   #8
thleon
Theo
Oddometer: 52
I have the TT screen and I was considering using the MRA spoiler from an old screen I have.
The issue with the TT screen is that is not stable making all the instrument panel shaking in strong wind. If I use the MRA spoiler, I am afraid it will be worse.
Have you tested the screen with the MRA spoiler on top with strong wind?
thleon is offline   Reply With Quote
Old 05-28-2010, 11:50 AM   #9
MCCadders OP
Oddometer: 134
Which Touratech screen do you have on?
I was thinking of just adding the touratech spoiler to the stock OEM screen, but doubting if it'd make much difference?
Cadders
Old 05-29-2010, 11:20 AM   #10
Adventure boy
Adventure boy's Avatar
Oddometer: 572
Ive just fitted one and used it for the first time today, first impression is that its so much better than the stock screen at 70mph the wind noise /buffeting seemed to be halved with the screen set to the top position on the way back set it at 2 clicks and it didnt seem as good, will go for a better ride on monday and try different positions but its better thats for sure
Live a little Love a little Ride a lot
Adventure boy is offline   Reply With Quote
Old 05-30-2010, 11:36 PM   #11
Ide508
Easy Does It...
Oddometer: 42
Hi,
Yes in strong winds the Touratech screen is kind of shaking, but not the instrument panel!
It does shake, but it certainly appears to be within tolerances. No cracking where the screws go...
I got this screen from a fellow who has ride +- 30.000 km with it.
Cheers
Old 06-04-2010, 12:41 AM   #12
Adventure boy
Oddometer: 572
Messed about with my one on a 100 mile ride Monday and had some thoughts on improving it for me
I made up some little flat metal bits out of some 1/8th inch flat steel measuring 30mm X 15mm drilled 2 holes in it and fitted them to the bottom screen mounts pushing the screen forward at the top by about 2 inches, the middle front mounts are out of whack but ive put 2 rubber spacers there now to stop the screen from trying to come back
the ride to work today was extreemly comfy 70mph with the visor open no problems at all the streem of air seemes to have been pushed over the top of my helmet and the wind noise is by far better, just an idea that has worked very well for me, if anyone wants to try I can post a pic of the little spacers
Old 06-04-2010, 11:03 PM   #13
Ide508
Easy Does It...
Oddometer: 42
Please do
Old 06-06-2010, 01:44 PM   #14
Adventure boy
Oddometer: 572
Please do
Ok then here we go, pic of the bracket I made
Old 06-06-2010, 01:46 PM   #15
Adventure boy
Oddometer: 572
and heres a pic of the screen it sits a bit more upright with the brackets fitted
Times are GMT -7.   It's 06:55 PM.
