Old 02-29-2012, 12:06 AM   #106
Slimie
Oddometer: 1,057
Instruments...
My speedo died!
It worked perfectly when I put the bike away but was completely blank next time I went out.
No idiot lights and no LCD!
I've checked that there is a voltage present at the connector (the blue wires show 12v) but can anyone think of a check for the unit itself? There is one on fleBay at the mo' which appeals more to me than modifying the wiring to use a Vapour or similar.
All ideas gratefully received.
TIA
-Simon
Slimie is offline   Reply With Quote
Old 02-29-2012, 02:12 PM   #107
Luke
GPoET&P
Luke's Avatar
Oddometer: 3,777
Originally Posted by Slimie View Post
My speedo died!
TIA
-Simon
What year is your bike? On the '11, blue is supposed to be ground. You may have a bad ground connection.
Luke is offline   Reply With Quote
Old 02-29-2012, 02:29 PM   #108
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 1,537
+1 I was noticing that it was 12V to blue and All the newer models ground to the solid blue wires.
On the 2010 and possibly other models there is one spot on the wiring loom that is particularly prone to wear right by the coil. There's a good thread with pics over HERE at Cafe Husky. Worth a look...
TaterHarry is offline   Reply With Quote
Old 03-01-2012, 12:00 AM   #109
Slimie
Oddometer: 1,057
Thanks folks, it's a 2008 bike.
Will have at the Cafe thread, I must have missed that when I searched before!
Thanks again
-Simon
Old 03-01-2012, 04:34 AM   #110
Slimie
Oddometer: 1,057
There's no sign of any chafing as shown in the CafeHusky thread, or anywhere else, thanks for the heads up tho'. Also my horn and high beam, brake lights, head, tail and parking lights are all working as they should be (no indicators fitted).
Checking the speedo socket, to earth I'm getting 12 volts from the yellow and black, the red, the white and yellow and the brown wires. There must be an earth through the plug as the fixing bolts are all insulated.
I'm thinking more and more that it has to be the unit that's faulty, but that could be because there is one available!
-Simon
Old 05-08-2012, 11:51 AM   #111
tigrebleau
tigrebleau's Avatar
Oddometer: 641
Coolant hose relocation
I saw somewhere that it was a good idea to relocate the coolant hoses. Anyone have any specifics? I'm buying a 2012 TE250 and would rather set it up right at the start. Any other (useful) advice appreciated.
"To them, the bike is just garage clutter. To us, it's a loaded Beretta, a half-million in cash, and a forged passport under the floorboards." - Dan Walsh
tigrebleau is offline   Reply With Quote
Old 05-08-2012, 12:08 PM   #112
Slimie
Oddometer: 1,057
I don't know if it's still a problem but bikes of the age of mine - 2008 or thereabouts had a hose connecting piece made of plastic that sometimes broke.
A couple of companies made more substantial replacements, Up-Tite Racing for one.
CafeHusky has more information and is a great resource for these bikes.
Cheers
-Simon
Old 05-08-2012, 12:10 PM   #113
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 1,537
No need to swap hoses on the X-Lite bikes as the hose has been updated. It does pass very close to the exhaust pipe but I haven't heard of any issues.
+1 on checking in at CafeHusky.
Old 05-08-2012, 04:42 PM   #114
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,176
Send a message via Yahoo to swamp
Thumb Te-250
other advice for tigrebleau :
I have a 2012 TE250
make sure you get all the smog crap off of it and plug the hole between the motor and throttle body with a rubber nipple thingy.
I put a 12 port fuel injector in mine (stock is 6 port), changed the 2 bolts that hold the injector in (made of cheese) to good alan head bolts from home depot.
installed the ECU from the TXC model.
reset the TPS and used ibeat to set everything to 100%
i also removed the stock stearing stops (too long for me). purchased some shorter alan bolts from home depot. huge difference. shorter turning radius . still no contact with radiators.
i installed a larger rear sprocket (the stock one was only a 40T.. gay) and a smaller front sprocket.
the stock rear tire is going to rub a hole in your mud flap (why they chose that tire im not sure of) so push the mudflap towards the front of the bike before you go out riding. once you burn through the stock tires changed to a "normal" size knobbie and you're good to go.
i also installed cycra bark busters onto my bike. if you do this make sure you get the "magura bend" type.
also, be careful not to over fill your oil , the husky doesnt like that.
I'm 5'10 and weigh 155 lbs. the suspension was pretty much dead-on perfect for hard single track riding. i think i removed 2 clicks or rebound damping on the shock just to mess with something
after you get the bike set up and de-tree-huggered you will love it. the thing eats single track for breakfast, its amazing.
Enduro Earth
YOUTUBE
swamp screwed with this post 05-08-2012 at 04:51 PM
swamp is offline   Reply With Quote
Old 06-17-2012, 09:25 AM   #115
ohenry
ohenry's Avatar
Oddometer: 280
Great video!
I just traded my 05 DRZ400s for a 08 TE250 because I wanted a better more dirt bike.
Here is my old DRZ400s which I liked.
Here is my ''New" bike.
http://www.youtube.com/watch?v=jHfbi...ature=youtu.be
http://www.youtube.com/watch?v=C0Qfq...ature=youtu.be
http://www.youtube.com/watch?v=PRCgK...ature=youtu.be
http://www.youtube.com/watch?v=2upEf...ature=youtu.be
http://www.youtube.com/watch?v=fEEuU...ature=youtu.be
http://www.youtube.com/watch?v=BPRNr...ature=youtu.be
I like it! I had the DRZ400s which was so heavy and the WR250r which was an OK 50/50 bike but I tried to make it more dirt and hated it.
I think the first owner used it off road and removed the odometer and the guy I got it from put it back.
The TE250 hits like a 2 stroke and it is so light. The box the guy gave of blinkers and stuff was 11.8 lbs alone.
Crazy bike!
Ohenry
2009 KLX250s
ohenry screwed with this post 07-09-2012 at 04:15 PM
ohenry is offline   Reply With Quote
Old 06-24-2012, 07:28 PM   #116
Tachedoutoffroad
Tachedoutoffroad's Avatar
Oddometer: 479
In the market for a Husky 250-310 with a tag if any of y'all need some quick cash.
Needs to be located within $300 of Alabama and cost less than $4000.
Thanks.....
...... Waiting for the magic PM...
'09 Husky 510 TE/SM
'07 Husky 610SM SOLD
'96 Honda XR250/300R (plated)
'96 Honda XR600R (plated) FOR SALE
Tachedoutoffroad is online now   Reply With Quote
Old 07-03-2012, 04:35 AM   #117
swamp
swamp's Avatar
Oddometer: 1,176
Thanks.....
Hi Tach
Enduro Earth
YOUTUBE
Old 07-08-2012, 08:31 PM   #118
Tachedoutoffroad
Oddometer: 479
Look what I put a deposit on....
'09 Husky 510 TE/SM
Old 07-08-2012, 08:32 PM   #119
Tachedoutoffroad
Oddometer: 479
Originally Posted by swamp View Post
Hi Tach
Howdy neighbor
'09 Husky 510 TE/SM
Old 07-10-2012, 06:51 PM   #120
sparrow
sparrow's Avatar
Oddometer: 954
Anyone know what the hp is for a stock 2010 te250? Also what's the shop manual say about when to check/change the piston and rings?
sparrow is offline   Reply With Quote
Times are GMT -7.   It's 11:25 AM.
